2014 Speed Triple R quickshifter questions - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 4 (permalink) Old 01-15-2019, 01:17 AM Thread Starter
Newbie
Main Motorcycle: 2014 Speed Triple R
I bought a 2014 Speed triple R a few months back and i was doing the research to get a quickshifter on it. However, for the life of me i can't find any place that sells one or any instructions or other stories of other people adding one to that model and year. Does anyone on here have any suggestions on how to add one to my bike or if it is even possible? Thanks in advance!
Kiraslite is offline
post #2 of 4 (permalink) Old 01-15-2019, 10:20 AM
Main Motorcycle: '04 Suzuki GSXR-1000
Red Baron's Avatar
Other Motorcycle: '88 Hurricane CBR-1000F
Extra Motorcycle: '17 Speed Triple R
If Triumph doesn't make one for your model, then here is the one you need.
The OEM from Triumph is a Translogic QS part. It's pretty much a Plug and Play.
https://www.translogicusa.com/quicks...php?page=order
Triumph Quickshifter for Speed Triple 1050 & 1050R models 2011 onwards with standard road shift gear lever set-up 1dn 5up road pattern TLS-QSX-U-DCSB-90 $349.00
Rick James: "Drink and be merry, it's a celebration, B!!!!"
Red Baron is offline
post #3 of 4 (permalink) Old 01-15-2019, 02:27 PM Thread Starter
Newbie
Thank you! This is exactly what i needed!
Would you happen to know if the quickshifter will work in conjunction with aftermarket fuel tuners?
post #4 of 4 (permalink) Old 01-15-2019, 03:30 PM
Red Baron's Avatar
As far as my limited experience with 2 Translogic QS, it should be fine.
TheTranslogic is a stand alone between the main coil harness and the coils.
I have a reprogrammed ECU in my Suzuki GSXR and the Translogic does not throw any codes. So in other words the Translogic is only cutting your programmed ECU input to the coils by milliseconds.
New Speed Triple coming (Jan 29, 2018) kawabunga Speed Triple Forum 374 11-27-2018 06:36 AM
Speed triple rs quickshifter failure. nm ace Speed Triple Forum 10 06-20-2018 09:06 AM
New Speed Triple for 2014? Hmmmmm..... ClimberClint Speed Triple Forum 12 01-30-2013 01:23 AM
Speed Triple Long Term Review shaughnessy Speed Triple Forum 19 05-28-2011 06:26 PM
Speed Triple Questions Stonecoldchavez Speed Triple Forum 6 07-05-2009 09:16 PM
