Triumph Forum: Triumph Rat Motorcycle Forums (https://www.triumphrat.net/forum.php)
-   Speed Triple Forum (https://www.triumphrat.net/speed-triple-forum/)
-   -   3-M Clear Paint protection (https://www.triumphrat.net/speed-triple-forum/945494-3-m-clear-paint-protection.html)
Tripletide 01-10-2019 03:54 PM
Thinking about putting some of this on the Triple. To protect the the front of the tank and flyscreen. Anyone else done this and if so any problems?
jakethedog 01-11-2019 02:31 PM
Do you have a link to the product? I'd be interested to know as well.
Also found this stuff, but can't tell what it even is. Sheets of plastic???
https://www.pure-triumph.com/p-2471-...-a9930268.aspx
jakethedog 01-11-2019 02:33 PM
Duh, it clearly says "film" so, yeah, sheets of plastic. Anyone tried it?
Automouse 01-11-2019 02:53 PM
I put two large sections on the sides of my Sprint GT excellent stuff, almost invisible and tuff, sticks well, heat to remove, wet to apply then rub out the air bubbles, you can lift and reapply to get a good application. Recommended.
The stuff I used was called " Rino tape "
Tripletide 01-12-2019 08:50 AM
Sounds good. Seems easy enough to apply. On the 17 r triple I picked up a chip on the tank , not bad , just noticeable. Thought I'd give it a try on the 19rs. I'll post up pick when ever I get around to it.
Tire Torcher 01-13-2019 09:30 PM
I bought a roll of this stuff, it works excellent. I copied the pieces from the Triumph factory protection kit I bought for my other bike, worked perfectly.
When I go on long trips I put it on the edges of the tank to keep my tank bag from scuffing my paint. When I get home I just remove it and chuck it. Make more pieces next time I go. Well worth it.
Tripletide 01-14-2019 07:33 AM
Sorry , here ya go
https://www.amazon.com/VViViD-Clear-...ion+film&psc=1
Red Baron 01-15-2019 10:26 AM
I read somewhere this works great too.
https://www.amazon.com/dp/B07FWRRD2F...8-d7e517c085e3
Automouse 01-15-2019 11:15 AM
Red Baron 01-15-2019 11:58 AM
Seriously now, check this Lamin-X.
https://www.lamin-x.com/motorcycle-products.html
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
