Air box pipe location - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
  • 1 Post By Nobby15
post #1 of 7 (permalink) Old 11-24-2018, 03:04 AM Thread Starter
Main Motorcycle: Speed Triple 2006
Nobby15's Avatar
Hi all, so I decided to change my air filter and found when I went to put it all back together I cannot see where these 2 pipes should go!! Anyone care to help me out? I also now have the engine light on. Cheers Danny
ID:	628208   Click image for larger version
Nobby15 is offline
post #2 of 7 (permalink) Old 11-24-2018, 06:31 AM
Main Motorcycle: '05 1050 Speed Triple
Other Motorcycle: '77 T140V Bonneville
Hi Danny,
The first pipe goes to an air pressure sensor on the left side of the air box
The second pipe is the air box drain shown as item 12 in the diagram below. I believe it has some sort of valve in the end (item 14) to let waste drain out but not be sucked in. I'm sure other owners have left this open with no problem.
The engine light has probably come on because you switched the ignition on whilst the tank was off and not everything was connected. This should sort itself after a run and the bike gets up to temperature.
Rob.
1050rob is offline
post #3 of 7 (permalink) Old 11-24-2018, 07:13 AM Thread Starter
Nobby15's Avatar
Thumbs up
Thank you Rob, that worked It ran like a pig before I re-attached the pipe. Now to give it a blast and get rid of the light
Nobby15 is offline
post #4 of 7 (permalink) Old 11-24-2018, 08:35 AM Thread Starter
Nobby15's Avatar
Took it for a run but the light is still on. Once I get the cable Iíll connect to tuneecu and see what faults there are and hopefully get rid of it.
Nobby15 is offline
post #5 of 7 (permalink) Old 11-26-2018, 06:31 PM
Start the bike but don't touch the throttle at all. Let it go through 3 heat cycles - radiator fan comes on 3 times - switch off. Hopefully your bike will have reset itself and that engine light will have gone out.
Rob.
1050rob is offline
post #6 of 7 (permalink) Old 11-26-2018, 07:24 PM
Main Motorcycle: Black 2010 Speed Triple
Other Motorcycle: Black '96 Speed triple
Extra Motorcycle: Black 2004 Speed Triple
Just ride it. The engine light will look after itself. (3 heat cycles as Rob said)
John
I want to die peacefully in my sleep like my grandfather, not screaming
in terror like his passengers.
Legman is offline
post #7 of 7 (permalink) Old 11-27-2018, 03:26 AM Thread Starter
Nobby15's Avatar
Thanks Rob and Legman, the light has indeed gone out now
1050rob likes this.
Nobby15 is offline
British Customs Air Box removal kit? CooterNAB Air Cooled Cruisers - America, Speedmaster 1 03-07-2018 10:23 AM
Loss of power after installing K&N Air filter? Detrexion Street Triple Forum 42 12-12-2017 01:50 PM
Why triumph air box removal kit needed? shmalick Kicking the tires 1 01-19-2017 10:18 AM
Power Mods: Power Increase Going From Arrow 2-2 to Air Box Baffle Removal & TTP Map? sconley Air Cooled Twins Technical Talk 2 10-13-2015 02:32 PM
Engine missing / popping after EFI remap jdgullett Air Cooled Twins Technical Talk 55 03-31-2015 07:19 PM
