Cold starting issue - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
  • 1 Post By surya
post #1 of 5 (permalink) Old 11-14-2017, 09:25 AM Thread Starter
Main Motorcycle: 05 speed triple
Other Motorcycle: 95 bandit 600
Cold starting issue
Just bought a "new" 2005 speed triple with 50.000km on the clock.
I took the tank and airbox out to connect new mini turns signals at the front (when I pulled the airbox out the throttle bodies got loose, maybe this is important...), and when I mounted everything up again the cold starting problem begun...
The bike starts and idles normally, but when I touch the throttle she responds with hesitation and if I overdo it she shuts down. If I let her warm up for a few minutes, the hesitation starts to go away and the throttle starts responding as it should.
I took it to a mechanic (not very experienced in triumphs) and he said he adjusted the injection, but the thing is that the problem remained and now when I roll off from standing, the first bit of throttle response is also hesitating. When properly warm she works like a charm...
English is not my native language and so I used the word "hesitation" in miss of a better one... I would use the word "choke" (she seems to be choking when I give it some gas when cold) but I was afraid it would be confused with the "choke" that enriches the mixture...
Any thoughts on what the problem might be? Thank you in advance for your inputs
johnnyvincent is offline
post #2 of 5 (permalink) Old 11-23-2017, 10:59 AM
Main Motorcycle: Speed Triple 1050
surya's Avatar
Other Motorcycle: '98 Ducati M900
Bem vindo and congrats on the best model year speedy. Your English is perfect and much better than my Portuguese. Sounds like either a vacuum leak or a cold temperature mixture issue. Assuming you chased down the throttle body looseness when you removed the airbox and fixed it, may be time for TuneECU diagnosis and it's pretty easy. Look for throttle-body balance and the ISCV stepper motor calibration features in TuneECU. If the t-body assembly moved and affected the ISCV stepper motor arm clearance, speedy would not choke" properly for smooth cold start/run, and this issue would disappear when warm. There's a forum sticky that covers ISCV stepper arm gap/voltage adjustment. Let us know what you find and if you have more questions.
johnnyvincent likes this.
'05 neon blue Speedy
surya is offline
post #3 of 5 (permalink) Old 11-27-2017, 10:28 AM Thread Starter
Thank you for your reply!
I'll have to take it to the dealer to run the diagnosis on the ECU, since I don't have way to do it myself... I will check in when I get it fixed.
post #4 of 5 (permalink) Old 11-27-2017, 01:31 PM
surya's Avatar
All you need is a laptop, a $15 OBDII cable from Amazon, and some patience. Even comes in Portuguese ! http://tuneecu.com/TuneECU_BR_PT/index.html
surya is offline
post #5 of 5 (permalink) Old 11-27-2017, 05:05 PM Thread Starter
Just ordered a lonelec "TUNE ECU KKL INTERFACE CABLE LEAD FOR TRIUMPH MOTORCYCLES" cable. When it arrives I'll give it a go! In the meanwhile I'll do some reading and youtube watching to try not to do some S**** wrong...
Thanks for the help!
1999 955i cold idle issue Dai-San Daytona Deliberations 0 04-21-2017 08:31 AM
Starting issue W_Edwards Air Cooled Twins Talk 7 10-06-2016 04:15 PM
Starting Issue joeysan Air Cooled Twins Technical Talk 4 05-04-2016 12:15 PM
Cold weather starting issues Mbennettphoto Air Cooled Twins Technical Talk 7 01-21-2016 08:43 AM
another starting issue cavi Triumph SuperSports 10 07-09-2015 05:02 AM
