Ignition Timing for 955i cams in 1050 engine - Triumph Forum: Triumph Rat Motorcycle Forums
RAT - United Kingdom Topics and Discussion for RAT Packs based in the U.K.
post #1 of 1 (permalink) Old 04-23-2019, 04:50 AM Thread Starter
Main Motorcycle: 2018 Speed Triple RS
Other Motorcycle: 2002 Daytona 955i
Extra Motorcycle: 2015 Speed III R
Iím currently building a special based on 80mm bore pistons with Daytona 955i cams in a 1050 Speed Triple R engine (see Daytona Deliberations/Daytona1075 R).
Ill need to make changes to the ignition map once I have the Cams and pistons installed to get the most from this configuration.
Using Tune ECU Iíve compared the two curves for the 955 and the 1050 engines and there is a fair difference on the graphical curves. Iíve written a spreadsheet to enable me to map the Sagemís 955i curve into the Keihin 1050 ECU however Iím unclear if I can do a straight copy of the map through as the two curves appear to be using different parameters. The Keihin map uses Throttle Position % while the Sagem system uses engine load %. Given there is only one atmospheric pressure sensor a cannot help think that the there must be link between the throttle position and the engine load for this Sagem ECU.
I plan to data-log my 955i using load, ignition and throttle position but just wanted to check if any forum users had experience of using the 955i cams in 1050 engines and what they did with their ignition timing curves in the Keihin ECU?
Name:	Ignition map comparison(1).JPG
rob blackburn is offline
1979 T140e with RITA electronic ignition - Timing BKD Classic, Vintage & Veteran 15 07-28-2016 01:09 PM
1969 TR6C ignition timing questions bardtrailrider Classic, Vintage & Veteran 9 08-27-2013 07:56 PM
Torque settings for 1050 engine casings triple3john Tiger Chat 2 06-16-2010 01:49 PM
Cam / crank / ignition timing - T400 sidecar_ray Maintenance & Workshop Talk 6 12-15-2007 08:14 AM
Black Magic? or things that make you say hmmm. Thrux-ton-up Club Cafe' 10 02-11-2005 02:08 PM
