OK Basket Bike home now to I.D. - Triumph Forum: Triumph Rat Motorcycle Forums
Member's Restoration & Rebuild Projects Details of member's own projects.
 7Likes
post #1 of 64 (permalink) Old 08-09-2019, 08:08 PM Thread Starter
Main Motorcycle: Restoring 1969 Triumph 65
Frame # XC06944 T400R F4161
Motor43 2NI
Then inside the motor case 70-9035
Not seeing an engine plate, or raised area with an engine #
But on the Cylinder Head it has E695
Name:	Triumph frame.jpg
69Bonneville58 is offline
post #2 of 64 (permalink) Old 08-09-2019, 08:54 PM
Main Motorcycle: 66 Triumph TR6
Other Motorcycle: 66 Triumph T120R
Looks suspiciously like a T100, 500cc machine.
Rod
Redmoggy is online now
post #3 of 64 (permalink) Old 08-09-2019, 09:04 PM Thread Starter
Thanks Rod, it's a bi*tch being a newbie
I had the frame numbers with me for a 69 650 Bonn
so when I seen these numbers it threw me off.
Now trying to figure it all out what I have and what I can do from here.
Thanks for the info
post #4 of 64 (permalink) Old 08-09-2019, 10:08 PM
I believe you are correct about it being a 69 but the model code T100R is for a 500cc Daytona.
Rod
post #5 of 64 (permalink) Old 08-09-2019, 10:29 PM Thread Starter
Thanks Redmoggy, it says T400r on the frame after the frame #
Any thoughts on the engine?
Thanks
Can take more pics tomorrow, allot missing
post #6 of 64 (permalink) Old 08-10-2019, 12:49 AM
Sorry, meant to add. Are you sure it is a four? you are obviously in a better position to see than me but Triumph never used T400 as a model code.
The engine number is in the same place as the 650's under the barrel flange on the left hand side but not on a raised plinth. It should be stamped onto a section that looks almost to have been milled flat. Not sure about the first number you posted but the second would be the part number for the case half your looking at.
Thats about the extend of my knowledge on 500's so hopefully someone else will pop along and be more helpful.
Rod
post #7 of 64 (permalink) Old 08-10-2019, 01:19 AM
Main Motorcycle: T160
Moderator
Other Motorcycle: T100, T150
Post
Hi Pat,
Definitely a 500. Amplifying Rod's posts:-
"XC06944" was part of the the second batch of '69 500's and 350's built from mid-December 1968 through to around the end of January 1969.
"T400R" should be "T100R" (the model code).
The flat area under the letters and numbers should be covered in tiny Triumph logos.
We could do with a close-up picture of the frame number area?
"F4161" is the 'part number' of the steering head lug - aside, the numbers you see in parts books are those of 'finished' parts, ready to bolt on a motorcycle; however, Meriden used the same pattern of letters and numbers for raw castings and to track work-in-progress.
Not seeing
Motor43 2NI
Uh-uh, not an engine number.
Original engine number would've matched the frame number, it was stamped on an area of the drive-side crankcase just under the cylinder block; on the 350/500, the area was machined flat, it was stamped all over with tiny Triumph logos.
Again, we could do with a close-up of the area.
If they're raised, they're the original casting part numbers; if they're stamped but don't match the numbers of the corresponding parts in the '69 350/500 parts book, they're WIP numbers.
If you mean the plates that mount the engine in the frame, they're loose on a 350/500, they bolt to lugs on both frame and engine.
If you decide to continue with the rebuild/restoration, much of what's been posted for you already still applies.
Not seeing any pictures apart from the one of the frame?
Hth.
Regards,
Stuart
StuartMac is online now
post #8 of 64 (permalink) Old 08-10-2019, 06:36 AM Thread Starter
Thanks rod, the 43 2NI number is a plate tagged onto the motor casing and has a tiny lever centered on the plate.
I will look for the engine number when I get some light this morning
Thanks
post #9 of 64 (permalink) Old 08-10-2019, 08:10 AM Thread Starter
OK, getting somewhere.
The frame number though it looks to be T400, has a scratch across the T and the 1 making it look like a 4
So as Stuart says more than likely a T100, as he said Triumph didn't make a T400 frame.
There is a tag on the frame stating 1969 by Triumph stating the frame meets US specs.
Having measured the piston wall/bore (No pistons, it comes out to the dimensions for a E6899 for a 500 cc Engine.
Now onto the frame again, I need to check to see if everything is there.
post #10 of 64 (permalink) Old 08-10-2019, 09:59 AM
Legend
Thanks
That is the gear indicator on the transmission
Marc Beaudry likes this.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
GrandPaulZ is offline
