Triumph T100C Bobber Build Thread - Triumph Forum: Triumph Rat Motorcycle Forums
Member's Restoration & Rebuild Projects Details of member's own projects.
 7Likes
post #1 of 18 (permalink) Old 06-12-2015, 02:35 PM Thread Starter
Main Motorcycle: 1967 Triumph T100C Bobber
Bobberman2011's Avatar
Hello everyone,
My bike is currently at Slim's Fab Farm having custom fabrication completed. While there, I decided to snap some photos and included them here.
Sean Patrick likes this.
Bobberman2011 is offline
post #2 of 18 (permalink) Old 06-12-2015, 02:40 PM Thread Starter
My 1970 T100 gas tank needed a little work done on the forward right mounting hole. I ordered the mounting kit and had Slim weld the studs into place and repair the hole. As you can see the tank sits nicely on the frame, I really like the stock tank. I also temporarily installed the brass risers and Biltwell 1-inch Tracker bars. I cut 1-inch off of both ends to narrow the profile. just a bit.
Slim also custom fabricated rear fender mounts with hidden mounting hardware and I think he totally nailed it on the rear fender mounting. The bike is long, low and narrow and is the exact look I wanted. The last few items that are being fabbed is a brake stay for the front brake, a new axle and two threaded bungs to mount the rear turn signals/brake lights.
Last edited by Bobberman2011; 06-12-2015 at 02:43 PM. Reason: Added additional text
post #3 of 18 (permalink) Old 06-12-2015, 02:55 PM Thread Starter
Slim also fabricated a custom hidden electrical box under the engine that installs between the frame rails and mounts using stock hardware and locations. I will send photos of that when it is completed prior to my tear down and preparation for paint and powder coat. My plan is to install and Exile Cycles internal throttle and internal frame wiring. I will also route most of my clutch and brake cable inside the bars to clean up the front end. I ordered a 7-inch headlight bucket from Benjie's Cafe Racers and will install a replica Smiths speedometer in the bucket for a really clean look. I will post pictures as soon as I have it mocked up. Slim will fabricate a trick headlight mounting bracket as soon as he receives the bucket.
post #4 of 18 (permalink) Old 06-12-2015, 08:38 PM
Main Motorcycle: 1965 Triumph T120R
Other Motorcycle: 2004 Yamaha YZF R6
Extra Motorcycle: 2004 Honda CR250R
Awsone bike bro. I got a 1965 t120 three months ago that was totally stock and beat up. I built this. Should have it finished i the next week or so. Having lots of trouble with the timing. I put a Pazon electronoc ignition and a podtronics battery eliminator on it.
IRISHKIDPAT is offline
post #5 of 18 (permalink) Old 06-12-2015, 09:11 PM Thread Starter
Hi Irish,
Thank you for the compliments! Your bike is nice as well. I am also thinking of installing a Pazon and a voltage regulator with the built-in capacitor and Zener diode. What sort of problems are you having?
post #6 of 18 (permalink) Old 06-12-2015, 09:17 PM Thread Starter
I am also having Slim remove the stock Triumph gas tank filler and will install a solid brass crown gas cap with a steel bung.
post #7 of 18 (permalink) Old 06-12-2015, 09:32 PM
Main Motorcycle: 2013 America
Jeez these hard tails bring back some memories this is what I built and rode back in the 70's. Cheers Eric ( p,s check the tail lights ) .I also put the one with my son on together in the early 80's
aussiettrump is offline
post #8 of 18 (permalink) Old 06-12-2015, 09:34 PM Thread Starter
Here is a photo of the brass crown gas cap I am installing.
post #9 of 18 (permalink) Old 06-12-2015, 09:36 PM Thread Starter
Aussie,
That is a nice bike. Just curious, I assume a front fender is required in the land Down Under?
post #10 of 18 (permalink) Old 06-12-2015, 09:41 PM
Just a stage I was going through Bobber,the tank was given to me and it had a speedo at the top right side(vintage not Triumph)so I was going for that old bike look. cheers Eric.
is there a "guys on motorcycles" thread that I am not seeing? PurpleFox Biker Hang-Out 53 04-01-2015 05:18 PM
Crossed thread bodge Adrian1 Biker Hang-Out 10 03-29-2015 05:41 AM
Help identifying parts on a Custom Build scrambledpegs Air Cooled Twins Technical Talk 1 03-19-2015 08:15 PM
50th Birthday Build Gulpstella Member's Restoration & Rebuild Projects 8 03-10-2015 07:57 AM
70 Triumph "special" build Photos Truckedup Member's Restoration & Rebuild Projects 7 02-16-2015 01:38 PM
