Fan temperature switch - Triumph Forum: Triumph Rat Motorcycle Forums
Maintenance Tips and Tricks for the T3 Classics Maintenance tips, tricks, performance suggestions and proven setups for the Hinckley Classic Triples. DO NOT POST YOUR QUESTIONS HERE!!
 2Likes
post #1 of 99 (permalink) Old 04-12-2011, 05:32 AM Thread Starter
Main Motorcycle: 99 Legend Sprint GT
IrlMike's Avatar
I've long felt that the stock 100 deg C (switch on temp) of the stock cooling fan switch is unnecessarily high. And having a temerature gauge & a manual overide toggle switch has firmly convinced me of this.
It's only an issue in stop go, crawling traffic. But the stock switch allows the temperature to go quite a bit higher than normal & by the time it reaches the 100 deg C of the switch, the fan struggles to bring the temperature down - takes several minutes to start it dropping.
With a manual overide switch I noticed that if the fan is switched on earlier, the normal temperature is resumed much more quickly & holds very well.
After seeing a thread by N5XL on the T3 Sport Touring forum - which uses a different mounting size switch -
https://www.triumphrat.net/t3-sport-t...an-switch.html
I went looking for options for our classic triples. There's only a small number of standard mounting types - this one is a 20mm 'push fit'.
This is the one I found:
http://www.purems.com/products/product.php/II=2243
VW / Audi part # 021919369
which switches at 93 deg C....or 95 deg C for the item I actually bought from ebay in Germany:
http://cgi.ebay.de/Thermoschalter-blau-2-polig-VW-Bus-T4-Neu-/200507889840?pt=Autoteile_Zubeh%C3%B6r&hash=item2e af3398b0
Same part number....there's obviously a small range of switching temperature that presumably meets VW/Audi's spec fpr this part.
Anyhow, it controls the temperature perfectly. After about 5 mins in a traffic jam, it picked up the rising temp earlier & quickly returned it to normal. Switching off almost as soon as I'd got rolling at a steady 30mph heading out of the traffic.
Fitting it.
The stock O-ring seal & clip works perfectly - I used the existing items, no problem.
I wasn't able to find out if the VW/Audi vehicles - one an 'S4' saloon, another a T4 Transporter (van) model - used the switch direct or via a relay. So I played safe and fitted one. Any standard or 'mini' type auto lighting relay will do. I fitted mine in the fairing cowl, but I'd be sure a 'mini' type would fit near the switch under the tank.
This switch is designed to take a common type (tho' didn't figure exactly which) of two-pin auto electrical plug, not the 1/4 spades of our looms. However I wasn't sure if a plug would be too long & foul the tank. So I soldered a couple of short wires to the pins with 1/4" male spade crimps to hook it up. Zip tying the wires to the body of the switch for strain relief.
If anyone has info - wiring diagram? - featuring this switch it would be handy to know if it can power the fan directly & reliably.
Not quite as slick a mod as N5XL's for the other T3s, but doable and worthwhile I think.
98 Tbird tank/seat, Sprint fairing, ZX7R forks+Racetech Gold Valves, 08 ZX6R shock, short sw/arm, Alcon 6-pots, Ignitech+TPS, T'bike 3-1+Beowulf can, airbox/jet mods, tubeless wheel mod, lots :) per mile, 55mpg ave(imp)
IrlMike is offline
post #2 of 99 (permalink) Old 04-12-2011, 01:24 PM
Slinky's Avatar
Other Motorcycle: Down to my last one
Good find Mike.. I'm curious as to why you think a relay might be necessary when the stock fan does not use one? I take it the relay is switched by the fan switch?
'98 Thunderbird
Slinky is offline
post #3 of 99 (permalink) Old 04-12-2011, 01:32 PM
Main Motorcycle: 2000 Speed Triple
ImagoX's Avatar
Other Motorcycle: 1998 Thunderbird Sport
Extra Motorcycle: 1976 Honda CJ-360T
Where does this mount to the bike? Can you write up a brief installation How-to (or even just show the stock part that will be replaced in a photo) for those of us not familiar with the stock unit? I'd really like something like this that will kick on the fan at a lower temp - I've only had one or two times when I was worried (both on hot days in stop-and-go traffic just like you said), but it sounds like this would take care of that.
Thanks, man!
- Matt C.
- 2000 Speed Triple ("Roxie") - Jet Black
ImagoX is offline
post #4 of 99 (permalink) Old 04-12-2011, 02:15 PM Thread Starter
IrlMike's Avatar
Yep, the relay is switched by the fan switch. It's very likely the switch is capable of switching the fan's current load, but I couldn't find the info to confirm VW/Audi used it to directly switch a fan.
There's so much electronic control on modern vehicles & if the switch was to be used via a control box, possibly with some other conditions or timers, they may not have spec'd contacts up to the job of a direct connection. Or...they might also have chosen to keep loom wiring around the often longer engine bay runs to thinner sizes, typical of other sensor wiring - not suitable for the higher fan current & attendant significant volt drop on 12V circuits.
Add in that relays are dirt cheap & the fan switches are not (in Europe, I'd seen prices over 45 from VW franchised dealers), it seemed safer/more reliable to let a relay do the heavier current switching of the fan.
Hope this explains!
IrlMike is offline
post #5 of 99 (permalink) Old 04-12-2011, 02:57 PM Thread Starter
IrlMike's Avatar
Thanks, man!
I'm afraid I've not figured out being able to draw up neat custom wiring diagrams to put on the web. But this is a fairly simple job.
The fan switch faces out to the right & horizontally off the coolant filler/thermostat housing mounted on the top of the main frame tube under the tank. The switch is just to the rear of the coolant overflow/reservoir 'bottle'.
This is the type relay you want (bog standard, euro style 'micro' lighting relay):
Micro relays.
These are smaller than the standard relays
and have a different pin layout.
No brackets on these relays.
With diode protection for sensitive circuits. Pins 30 & 87 are 6.3mm
and pins 85, 86 & 87a
are 4.8mm blade.
Relay dimensions:
23x15x25mm (excluding pins).
Note the use of the smaller size, 4.8mm blade terminals!
The '4-blade' will do. I'd be sure it could be zip tied to the frame tube behind the thermostat housing & coolant overflow bottle with plenty of clearance for the fual tank to fit over.
The existing loom wires are unplugged & then connected to terminals 30 & 87 on the relay (either way round). Then, using a 'piggy back' crimp, connect a wire (smallest loom gauge is fine) from the terminal with the Blue/Black wire to one of the new fan switch terminals (by soldering).
(Note the Blue/Black wire is 12V positive all the time, even when the ignition switch is off - so disconnect the battery 1st before doing any wiring on this.)
The other fan switch terminal is then wired to one of the relay coil terminals - must be terminal #86 in this case as there's a diode connected internally.
Relay coil terminal # 85 is then wired to ground. A suitable option using a ring crimp is maybe an ignition coil mounting bolt or a thermostat housing mounting screw.
Reconnect the battery & bridge the new fan switch terminals together to test that the relay energises & fan starts running.
Tape up any exposed or potentially exposed parts of the connections & that's it.
I guess a photo of the area under the tank would be useful?, but, as I say, I fitted my relay under the fairing. (I left the toggle switch in circuit in mine because it has an LED in the toggle top which indicates both when the switch is on or fan relay is energised by the temperature switch.)
Anyhow, does this enable you to understand how to do it?
Last edited by IrlMike; 04-13-2011 at 04:52 AM. Reason: Correction to relay coil terminal nos. for correct polarity - #85 must be ground side.
IrlMike is offline
post #6 of 99 (permalink) Old 04-12-2011, 03:22 PM
Slinky's Avatar
Originally Posted by IrlMike View Post
Hope this explains!
Thanks Mike, that helps. I can see where you are coming from but I guess I just like to keep things simple. A relay is another link in the chain, so to speak.
I deffo like the idea of the lower temperature switch. 100c is cutting things a bit fine. Next stop, warped head
'98 Thunderbird
Slinky is offline
post #7 of 99 (permalink) Old 04-12-2011, 03:33 PM Thread Starter
IrlMike's Avatar
Yep, definitely Slinky, simple is always desireable. I forgot to mention that whilst trying to find out about the switch's contact Amp ratings, I did come across some items which had low ratings - only intended to drive a relay or electronics. Just couldn't get the spec on this one & thus couldn't be certain about it. There was no other options with the right mounting diameter/type & temperature unfortunately.
That said, these relays have 25A contacts & are an incredibly reliable item generally.
IrlMike is offline
post #8 of 99 (permalink) Old 04-12-2011, 03:48 PM Thread Starter
IrlMike's Avatar
On a side note, I definitely think a water cooled engine needs some sort of temperature monitoring device as well. If a fan or fan switch fails on our bikes I agree a warped head or serious damage isn't far off.
I guess our bikes were designed a little before the widespread use of LCD/digital displays integrated into the clocks.
I doubt there's a modern (water cooled) bike on the market which doesn't have the coolant temperature prominently & continuously displayed & I doubt this is consumer driven - the manufacturers want it there for good reason.
IrlMike is offline
post #9 of 99 (permalink) Old 04-12-2011, 07:59 PM
Puff98TBS's Avatar
Good find/information Mike! I too agree that the fan comes on too late which is why I've installed a manual switch last week. I just have to remember to shut it off when the light turns green or the traffic starts moving.
98 TBS, Green Cams, D&D 3 into 3, 180 Rear Tire, Ballistic Battery, Nology Coils & Hotwires, Pingel Fuel Valve, Factory Pro Jet Kit, Factory Pro Ignition Advance, K&N Pods, Brisk Silver Racing Plugs, HEL Performance Brake Lines, Ohlins Fork Springs.
Puff98TBS is offline
post #10 of 99 (permalink) Old 04-13-2011, 07:02 AM
Slinky's Avatar
Just a thought.. what temperature does the thermostat open at? I'm just imaging a situation where the fan comes on before the thermostat opens, would that be a problem?
'98 Thunderbird
Slinky is offline
Kill switch versus ignition switch? boredinocala Sprint Forum 16 07-18-2012 09:34 PM
outside temperature and mpg jjimmydutch Air Cooled Twins Technical Talk 1 09-22-2009 06:11 PM
Exhaust gas temperature 94Tango Air Cooled Twins Technical Talk 7 05-04-2009 01:04 PM
Oil coolers and oil temperature Curmudgeon Speed Triple Forum 4 07-03-2006 05:04 PM
Temperature shifting mathbeak Maintenance & Workshop Talk 8 09-09-2004 05:43 AM
