Oil: Semi Synthetic or Synthetic? TBS2k - Triumph Forum: Triumph Rat Motorcycle Forums
 3Likes
post #1 of 15 (permalink) Old 10-14-2019, 12:29 PM Thread Starter
Main Motorcycle: TBS2k
whiskeyzulu's Avatar
I'm ready to change oil on my 2000 TBS. Manual says to use semi-synthetic 10/40 API/SG.
I've been reading through the threads and there seems to be differing opinions about synthetic oil superior protection on the one hand and clutch slippage on the other. Also, apparently API/SG is now considered obsolete and modern Triumphs can use either semi or full synthetics with higher API ratings. I don't know if full synthetics were available in 2000 (if not, that might be why not listed as option in service manual) and whether its OK to use a 4T full synthetic oil, like Motul 5100 4T Motor Oil, without causing any issues or should I just stick to semi-synthetic?
What brand and type of oil does the Hinkley Triple community recommend?
Thx.
Bob
whiskeyzulu is offline
post #2 of 15 (permalink) Old 10-14-2019, 01:32 PM
Main Motorcycle: Bonneville
BonnieJon's Avatar
Other Motorcycle: bmw
I had my triple for ~20 years. I've now sold it but I see its still going strong..
Semi - Synth nearly all the time.
I treated her to fully syth if it was on special offer and therefore no extra expense.
If the manual says semi ... who am I to argue.
Those triple engines are strong (well except for the sprag clutch.!!)
BonnieJon is offline
post #3 of 15 (permalink) Old 10-14-2019, 03:48 PM
WSC
Main Motorcycle: '07 Dyna Low Rider
WSC's Avatar
Other Motorcycle: '99 Legend TT
Extra Motorcycle: Thunderbolt, T150V
Nothing wrong with full synthetic as long as it's rated for the wet clutch. JASO-MA (or MA2) rating is a must.
Lots of guys use Shell Rotella-T6. It's engineered for Diesels, but checks all the boxes for most bikes. (I think they have removed the SN rating at the request of their lawyers, but it once carried that rating). Anyhow, it's a full synthetic, SAE 5W-40, and it's available from Walmart for a reasonable price (~$20/gallon). It is suitable for use in gas engines prior to 2011 model year.
secondwindsteve likes this.
John
Laconia Bike Week 2019 - See you all next year
2007 HD FXDL
1999 Legend TT
1975 T150V, 1968 BSA Thunderbolt, x2004 Thunderbird Sport
WSC is offline
post #4 of 15 (permalink) Old 10-15-2019, 10:51 AM
Main Motorcycle: 2002 Triumph America
Wire-Wheels's Avatar
Other Motorcycle: 1995 Triumph Sprint
Extra Motorcycle: 2000 Triumph Legend TT
I have run semi-synthetic oils in both my old triples for many years. It is factory approved, which is good enough for me, AND it is a little cheaper than a full synthetic product. I am always careful to use the weight and grade specified by Triumph, but I use what brand I can find locally. I have been a gearhead all my 74 years of life (a lot of that as a time professional mechanic)...
but I do not pretend to know more than the factory engineers. ...J.D.
Wire-Wheels is offline
post #5 of 15 (permalink) Old 10-16-2019, 09:44 PM Thread Starter
Thanks fellas. Interestingly, while the Triumph Service manual says Semi the Haynes manual says Semi (10/40 weight) or Full synthetic (5/40 weight).
post #6 of 15 (permalink) Old 10-17-2019, 06:02 PM
Main Motorcycle: 2010 Triumph T-Bird
Other Motorcycle: 1998 triumph T-Bird
Extra Motorcycle: 1981 honda xl500
Whisky,
The thunderbirds always ran synthetic. Originally 15w-40w from dealer. I was too far away and when Mobil came out with the bike oil in 10-40 I switched. Only put 47K on it before moving to the big T-bird. By the way before that oil came to market , oil from dealer said MX4T. It is still on the stuff at autozone. (motorcycle for Triumph), no wonder the oil was expensive. If triumph had the oil made for them. Kinda wild.
ride safe
Dan
danr620 is offline
post #7 of 15 (permalink) Old 10-17-2019, 11:21 PM
WSC
WSC's Avatar
Originally Posted by danr620 View Post
MX4T... (motorcycle for Triumph)
You;re joking, right? We're talking motorcycle oil ratings, not texting.
slyster8879 likes this.
John
2007 HD FXDL
1999 Legend TT
WSC is offline
post #8 of 15 (permalink) Old 10-18-2019, 08:58 AM
wsc,
The quotes was a quip, the MX4T is on the bottle on the Mobil 1 motorcycle oil.
Dan
danr620 is offline
post #9 of 15 (permalink) Old 10-18-2019, 10:15 AM
WSC
WSC's Avatar
I wasn't sure!
For those interested, the "4" means 4-stroke the the "T" stands for some long word starting with "T" that means synthetic blend. Since it's a motorcycle rating, and many motorcycles have wet clutches, it's pretty safe to assume the 4T oils also meet the JASO-MA/MA2 specs and are OK for wet clutches.
As far as the question of whether full synthetics are OK when the recommendation is for semi-synthetic, I'd say the recommendation is a minimum spec, not a limit, in other words, no straight dyno oil.
John
2007 HD FXDL
1999 Legend TT
WSC is offline
post #10 of 15 (permalink) Old 10-20-2019, 10:52 PM
Main Motorcycle: 2002 Honda Valkyrie
Pappy!'s Avatar
Other Motorcycle: 1998 Honda Valkyrie
Extra Motorcycle: 2001 Triumph Adventurer
Gotta' love a good oil thread.....
Pappy! is offline
