Need Thunderbird Keihin Jet Holder or Emulsion Tube? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 7 (permalink) Old 09-19-2019, 11:17 AM Thread Starter
Main Motorcycle: 2004 Thruxton
craigo's Avatar
Other Motorcycle: 2002 Thunderbird
Extra Motorcycle: 2013 Bonneville Gold
Hi folks,
I have a new-to-me 2002 Thunderbird with Keihin Carbs. The bike sat for along time, so I disassembled and cleaned the carbs. Some parts were damaged/stripped and not re-useable. I've found almost everything needed on schematics at Hermy's Triumph or from Sprint manufacturing. But I cannot find the needle jet holder or what you might call the main jet holder. The main jet screws into this piece and it is also threaded to screw in the carb, and abuts the needle jet collar. Some may call it an emulsion tube, it has small holes in the body. In the attached photo it's labeled the "holder".
If anyone has one (or more), or has actually purchased one that fits, just let me know. I expect it's a Keihin part made just for Triumph, and that a Suzuki or Kawasaki might work, but an exact fit would be ideal.
Thanks,
Craig in DE
craigo is offline
post #2 of 7 (permalink) Old 09-19-2019, 11:54 AM
WSC
Main Motorcycle: '07 Dyna Low Rider
WSC's Avatar
Other Motorcycle: '99 Legend TT
Extra Motorcycle: Thunderbolt, T150V
Interesting that the part is not shown. What is wrong with yours? Unless it's physically damaged, a good ultrasonic cleaning should make it good as new.
At the risk of stating the obvious, any replacement has to duplicate the size, number and placement of the air bleed holes. I don't remember if there's a number stamped on the part or not.
John
Laconia Bike Week 2019 - See you all next year
2007 HD FXDL
1999 Legend TT
1975 T150V, 1968 BSA Thunderbolt, x2004 Thunderbird Sport
WSC is offline
post #3 of 7 (permalink) Old 09-19-2019, 05:24 PM
Main Motorcycle: 1996 Thunderbird
BRG-BIRD's Avatar
Other Motorcycle: 2009 Moto Guzzi Norge
Extra Motorcycle: 1975 Honda CB550F
Originally Posted by craigo View Post
Hi folks,
Thanks,
Craig in DE
I think I have a set, will look later tonight
"You are either onto something or on something"........The Common Man
“Sometimes you are best off dealing with the Devil you know” anonymous
BRG-BIRD is offline
post #4 of 7 (permalink) Old 09-19-2019, 06:38 PM Thread Starter
craigo's Avatar
Thanks BRG and just let me know.
I have read on the forum that perhaps Suzuki part number 13331-26e00 will fit. But this tube will have a different arrangement of air holes.
If anyone can confirm it works, please do post.
Thanks,
Craig
craigo is offline
post #5 of 7 (permalink) Old 09-19-2019, 07:08 PM
WSC
WSC's Avatar
If you can't match up a part number then I'd look for a carb feeding a cylinder of about the same displacement, RPM range and power output.
John
2007 HD FXDL
1999 Legend TT
WSC is offline
post #6 of 7 (permalink) Old 09-19-2019, 10:36 PM
BRG-BIRD's Avatar
I do have a set. Also here is a set of carbs that appear to have very similar if not the same emulsion tubes.
https://www.ebay.com/itm/Keihin-CVK-...UAAOSwul9dOKt-
BRG-BIRD is offline
post #7 of 7 (permalink) Old 09-20-2019, 11:17 AM Thread Starter
craigo's Avatar
Thanks BRG, PM sent.
craigo is offline
