No spark - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 12 (permalink) Old 09-04-2019, 01:01 PM Thread Starter
Main Motorcycle: 2000 Legend
Mvich's Avatar
No spark
Got my fuel problem sorted out then the spark died. I bypassed the ignition cutout by grounding the neutral switch wire but still have no spark on all three cylinders. I forget the thread but someone said you should have 12 volts at the coils - I only have 10.8 volts at all three coils. What would cause that? The manual makes no mention of it.
Mvich is offline
post #2 of 12 (permalink) Old 09-04-2019, 02:42 PM
Main Motorcycle: 2001 Triumph Thunderbird
My experience has been that they need a fully charged battery to fire. Sounds like your battery needs charged or is bad.
Ron T. is offline
post #3 of 12 (permalink) Old 09-04-2019, 04:26 PM
WSC
Main Motorcycle: '07 Dyna Low Rider
WSC's Avatar
Other Motorcycle: '99 Legend TT
Extra Motorcycle: Thunderbolt, T150V
Bad contacts in the ignition switch. Wiggle the key and see if the voltage fluctuates, or measure the voltage drop between the feed going into the switch (white) and the feed coming back out (brown).
John
Laconia Bike Week 2019 - See you all next year
2007 HD FXDL
1999 Legend TT
1975 T150V, 1968 BSA Thunderbolt, x2004 Thunderbird Sport
WSC is online now
post #4 of 12 (permalink) Old 09-05-2019, 09:30 PM Thread Starter
Mvich's Avatar
The battery is fully charged 12.5 volts and as a backup I used a jumper battery also however the starter motor seems a bit slow so a bad connection somewhere makes sense. Thanks.
Mvich is offline
post #5 of 12 (permalink) Old 09-06-2019, 07:59 AM
WSC
WSC's Avatar
Put the positive probe of your volt meter on the positive terminal of the battery. Put the negative probe on the wire lug connected to the battery. Key on. Read the voltage drop of the connection. Move the negative probe to the other end of the battery cable, at the solenoid. Read the voltage drop. Keep marching down the wiring until you find the big drop.
That said, 10.8 volts at the coils should be fine...
John
2007 HD FXDL
1999 Legend TT
WSC is online now
post #6 of 12 (permalink) Old 09-07-2019, 06:54 PM Thread Starter
Mvich's Avatar
Found where someone sprayed heavy grease in to the main junction in the headlight housing. Cleaning that got me another half volt but no spark.
Mvich is offline
post #7 of 12 (permalink) Old 09-14-2019, 02:45 PM Thread Starter
Mvich's Avatar
Found this today. Now I know why the resistance value for the pick up coil was good. I'm going to rejoin the coil to its mount with epoxy.
Mvich is offline
post #8 of 12 (permalink) Old 09-14-2019, 02:47 PM Thread Starter
Mvich's Avatar
I noticed that there are two different kinds of ignition coils on my bike. Is the #2 coil a Nology?
Mvich is offline
post #9 of 12 (permalink) Old 09-14-2019, 04:39 PM
WSC
WSC's Avatar
All the Nology coils I've seen are clearly marked as such.
John
2007 HD FXDL
1999 Legend TT
WSC is online now
post #10 of 12 (permalink) Old 09-14-2019, 07:47 PM
Main Motorcycle: 2001 Triumph TB 900 Std
kdunlap92's Avatar
Other Motorcycle: 2012 Yamaha XT250
Extra Motorcycle: Honda CRF110F (my son's)
These are stock...Gil
Keith in PA (USA)
01 TB Std
someday...TBS in yellow and black
"Whatever you do, be a good one."
kdunlap92 is offline
