Fuel tap/petcock leaking - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 11 (permalink) Old 08-23-2019, 03:36 PM Thread Starter
Main Motorcycle: Thunderbird Sport (98)
98 Thunderbird Sport - the fuel tap/petcock has started to leak, not from the coupling to the tank but by the turn handle - is there a replacement available for it?
curlywurly is offline
post #2 of 11 (permalink) Old 08-23-2019, 04:27 PM
I replaced mine for a Pingel. No more leaks ( even after buying a new Triumph one!).
Sent from my iPhone using Tapatalk
prmurat is online now
post #3 of 11 (permalink) Old 08-23-2019, 05:01 PM
WSC
Main Motorcycle: '07 Dyna Low Rider
WSC's Avatar
Other Motorcycle: '99 Legend TT
Extra Motorcycle: Thunderbolt, T150V
I think there's an o-ring in there you can replace.
Go to a place that repairs light aircraft and ask if you can get a little "Fuel-Lub". They'll probably give you some. Use it to lube the plug in the valve and put a little on the new o-ring. Good for another 20 years.
A little Fuel-Lub goes a long way... Too much will plug up things downstream.
John
Laconia Bike Week 2019 - See you all next year
2007 HD FXDL
1999 Legend TT
1975 T150V, 1968 BSA Thunderbolt, x2004 Thunderbird Sport
WSC is offline
post #4 of 11 (permalink) Old 08-25-2019, 11:47 AM Thread Starter
Thank you both.
Using a Pingel, does it require any modifications? Or is it a straight swap? Do you have a part number? There are so many on the Pingel website!
Searching around, it seems that this might be the one - Pingel - 4211-CH - Power-Flo Petcock, 90deg. Outlet Facing Rearward - Chrome
And this previous post - https://www.triumphrat.net/hinckley-...lacements.html
I'll look into the lube, Wiley Post airport is very near too me, so I'll go and pay them a visit.
post #5 of 11 (permalink) Old 08-25-2019, 02:18 PM
WSC
WSC's Avatar
You'll have to enlarge the hole in the tank slightly. Not difficult. Use a round file or a reamer.
Tell them you want to lube a plug valve. A small smear in a plastic bag is all you need.
John
2007 HD FXDL
1999 Legend TT
WSC is offline
post #6 of 11 (permalink) Old 08-25-2019, 05:15 PM
You also need the 34mm adapter plate for the Pingle. Love it but it took three attempts at installing without leaking. Needed a judicious amount of solvent based gasket dressing.
First time I just used the included gasket and it leaked bad.
Second time I cut a new thicker gasket and coated with dressing. It still leaked but not nearly as bad.
This time, new gasket, cleaned mounting area down to bare metal, applied dressing using the “too much is always better than not enough” philosophy, let dressing cure for two hours before assembly, waited overnight before adding gas after assembly. Third time was the charm.
Pingle supposedly has an alternate rubber gasket that works better on our bikes.
As long as it has more than one wheel, I'm game.
strange21 is online now
post #7 of 11 (permalink) Old 08-26-2019, 10:03 AM
When you order a Pingel just ask for the rubber gasket and the problem is solved...
post #8 of 11 (permalink) Old 08-26-2019, 11:47 AM Thread Starter
Thank you, lots of great info.
BTW - I'll be visiting the UK mid October, so there is a possibility I can source one while over there, I have a friend there who specializes in British parts, and also a ton of others parts for Japanese bikes.
post #9 of 11 (permalink) Old 08-26-2019, 10:48 PM
Main Motorcycle: 1996 Thunderbird
BRG-BIRD's Avatar
Other Motorcycle: 2009 Moto Guzzi Norge
Extra Motorcycle: 1975 Honda CB550F
I’m one of the few that have sourced a Kawasaki vacuum operated fuel valve, Slinky is another member that has a Kawasaki model off a Zephyr? but his may not be vacuum operated? Don’t remember. Anyway mine is from an early 80’s Kawasaki 550/750 and it fit perfectly, the bolt hole spacing was exactly the same and the vacuum line is tapped into the middle carb vacuum port.
"You are either onto something or on something"........The Common Man
“Sometimes you are best off dealing with the Devil you know” anonymous
BRG-BIRD is offline
post #10 of 11 (permalink) Old 08-30-2019, 01:55 PM Thread Starter
Thanks BRG-BIRD, I remembering seeing something about using a Kawasaki one, fortunately, the aforementioned friend in the UK has a bunch of old Z650, Z1000 and the such like, so I'll try my luck there first, he is only a few miles from my UK hometown of Malvern, Worcestershire. I thought I'd read that a Suzuki RGV250 might fit, but I very might be wrong on that.
