Clutch Adjust - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 8 (permalink) Old 07-29-2019, 11:45 AM Thread Starter
chvvvr's Avatar
Clutch Adjust
Hello I recently purchased a 2001 Legend TT. This is the first time i’ve had a bike with a wet clutch and my haynes manual isn’t here yet. the clutch doesn’t grab until 90% out. Is there a way to adjust this? Or is this suggesting i need a anew clutch. The bike only has 6000 miles. Thank you
chvvvr is offline
post #2 of 8 (permalink) Old 07-29-2019, 01:48 PM
WSC
Main Motorcycle: '07 Dyna Low Rider
WSC's Avatar
Other Motorcycle: '99 Legend TT
Extra Motorcycle: Thunderbolt, T150V
Don't confuse a wet clutch (runs in an oil bath) with a hydraulically actuated clutch. Many (most?) bikes have wet clutches. A hydraulically actuated clutch is self adjusting. If it's slipping then there's a mechanical problem; most likely it's just worn. I wouldn't expect this with only 6000 miles, though.
One possibility is someone put the wrong oil in the engine. Wet clutches don't like "Energy saving" oils. Make sure any oil you use meets the JASO-MA or -MA2 spec.
John
Laconia Bike Week 2019 - See you all next year
2007 HD FXDL
1999 Legend TT
1975 T150V, 1968 BSA Thunderbolt, x2004 Thunderbird Sport
WSC is offline
post #3 of 8 (permalink) Old 07-29-2019, 02:50 PM
Slinky's Avatar
Other Motorcycle: Down to my last one
You may just need to bleed the clutch. 18 years old and 6000 miles means it's done a lot of sitting around. Clutch fluid degrades over time.
'98 Thunderbird
Slinky is offline
post #4 of 8 (permalink) Old 07-30-2019, 08:07 AM Thread Starter
chvvvr's Avatar
I’ll give her an oil change and bleed the clutch once i get the manual in the mail. I’m hoping that’s all it is with such low mileage. What type of oil is recommended?
chvvvr is offline
post #5 of 8 (permalink) Old 07-30-2019, 01:50 PM
WSC
WSC's Avatar
That's a good way to start an argument...
Anything with the JASO-MA rating will do. I like Shell Rotella T-6. It's reasonably priced, full synthetic, and has the right rating. Find it in the Diesel oil section at Walmart for $20/gallon.
John
2007 HD FXDL
1999 Legend TT
WSC is offline
post #6 of 8 (permalink) Old 07-30-2019, 07:39 PM Thread Starter
chvvvr's Avatar
hahah yeah i’m sorry i even felt it as i was typing the question. but yea that is all was looking for just a base answer. i appreciate it. i’ll give it a go in a few weeks and see what difference it makes. thank you gentlemen and/or ladies
chvvvr is offline
post #7 of 8 (permalink) Old 08-12-2019, 02:33 PM Thread Starter
chvvvr's Avatar
I’ve been a fan of castrol and i saw triumph now recommends castrol. it’s hard to tell what’s jaso-am rated, will the gtx sae10-40 work? https://www.napaonline.com/en/p/COR1...CABEgKXAPD_BwE
chvvvr is offline
post #8 of 8 (permalink) Old 08-12-2019, 03:25 PM
WSC
WSC's Avatar
No, that one is not and I would not use it with a wet clutch. Castrol has a line of motorcycle oils called "4T" that are JASO-MA2 rated.
https://www.walmart.com/ip/Castrol-P...1-QT/292569005
John
2007 HD FXDL
1999 Legend TT
WSC is offline
