Legend TT 99 repair - Page 11 - Triumph Forum: Triumph Rat Motorcycle Forums
 20Likes
post #101 of 113 (permalink) Old 08-12-2019, 12:59 PM Thread Starter
SzBalogh's Avatar
Originally Posted by WSC View Post
Knock the center out of an old spark plug. Tap it for a 1/8" pipe and put a pipe extension and a fitting for a compressor on it. Turn the compressor down to about 20 psi and blow air into the cylinder with the piston at TDC. See where it comes out.
Hmmm, simple. I can make it, need to make a M12 thread (edited, not M12 but 12x1.25!!), no useless spark plug around I dont need to drain engine oil to remove right side crank cover right?
I have ordered a simple compression gauge from China, one month to get it. Cant wait to continue :/
The carb to engine rubbers arrived today, they are fantastic, super fit on the carbs (bike is not here), has a small angle, the dimensions just like i measured.
Remember? I had cranking problems first, which i thought is the broken kickstand switch. Dismounted this and connected the wires. Later i found the neutral switch cable was torn and simply interwound inside the cover. So the kickstand switch was covered with silicon at the bottom which i thought is the result of tinkering. Now i found pictures showing that this is originally like that. Now i have to solder new wires on the switch. :/
SzBalogh is offline
post #102 of 113 (permalink) Old 08-12-2019, 01:41 PM Thread Starter
SzBalogh's Avatar
One more thing. I made two heat up then let it cool cycles to make sure the fan (original switch working) and cooling system working. Topped up coolant after the cycles. First it had smoky exhaust but this is because of the remaining oil from tank (rust removal, drying, left covered inside with oil), but after a while there was no smoke at all. I think this as a good sign that the head gasket change worked
WSC likes this.
SzBalogh is offline
post #103 of 113 (permalink) Old 08-14-2019, 12:38 PM Thread Starter
SzBalogh's Avatar
This grease pint was almost empty. The others needed less grease to fill.
SzBalogh is offline
post #104 of 113 (permalink) Old 08-24-2019, 03:09 AM Thread Starter
SzBalogh's Avatar
Hmmm, something is missing. Is it possible to get a new one somewhere?
How is it called in english so i can search for it?
The engine and frame numbers should match right? But not on my bike. I know it had a crash, so the frame was replaced.
SzBalogh is offline
post #105 of 113 (permalink) Old 08-24-2019, 08:56 AM
Nope, nothing missing. I think all the frames have this two rivets. Mine has them and I had the bike since new. I was actually looking at them yesterday wondering if they were mounting points used on another model that used the same frame and those are just blanking plugs.
SzBalogh likes this.
As long as it has more than one wheel, I'm game.
strange21 is offline
post #106 of 113 (permalink) Old 08-27-2019, 02:01 PM Thread Starter
SzBalogh's Avatar
Bowl gaskets arrived. Bought for Kawasaki (ZX600A 85-87 ZR750 ZX750 ZL900 ) for six quid, pack of four. Perfect fit for the CVK36.
No info of the taillight and indicators yet
Is this baffle the same as on my Legend? Already made six 12mm holes in the outer layer. It says there are still two more walls to drill and get that bass.
https://www.triumphrat.net/air-coole...omy-guide.html
Finally digitalized this old photo
Name:	float bowl gaskets.jpg
ID:	653604   Click image for larger version
SzBalogh is offline
post #107 of 113 (permalink) Old 09-07-2019, 12:21 PM Thread Starter
SzBalogh's Avatar
Pod restrictors
ID:	654784   Click image for larger version
SzBalogh is offline
post #108 of 113 (permalink) Old 09-07-2019, 08:20 PM
WSC
Main Motorcycle: '07 Dyna Low Rider
WSC's Avatar
Other Motorcycle: '99 Legend TT
Extra Motorcycle: Thunderbolt, T150V
Originally Posted by SzBalogh View Post
Pod restrictors
Wait, why?
John
Laconia Bike Week 2019 - See you all next year
2007 HD FXDL
1999 Legend TT
1975 T150V, 1968 BSA Thunderbolt, x2004 Thunderbird Sport
WSC is online now
post #109 of 113 (permalink) Old 09-08-2019, 01:13 AM Thread Starter
SzBalogh's Avatar
Wait, why?
The idea is to restrict air flow, since pods letting to much air in.
Still need to figure out how many holes to cut in the plate.
SzBalogh is offline
post #110 of 113 (permalink) Old 09-08-2019, 08:43 AM
WSC
WSC's Avatar
I still don't get it. The engine needs air to make power. Why would you want to install pods, then restrict the air flow? Heck, just put a stop on the throttle at half way open...
John
2007 HD FXDL
1999 Legend TT
WSC is online now
