Legend 900 Muffler - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
post #1 of 11 (permalink) Old 06-15-2019, 07:15 PM Thread Starter
Newbie
Main Motorcycle: 1999 Triumph Legend TT
Legend 900 Muffler
Long time listener, first time poster.
Has anyone had any luck fitting a these to a Legend or other Hinkley triple?
https://www.dimecitycycles.com/chrom...e-muffler.html
I'd like something a little louder and meaner than the stock megaphones, but I'd like to avoid having to rejet the carbs if i can avoid it.
Kale Auger is offline
post #2 of 11 (permalink) Old 06-15-2019, 09:03 PM
Main Motorcycle: 1996 Thunderbird
BRG-BIRD's Avatar
Other Motorcycle: 2009 Moto Guzzi Norge
Extra Motorcycle: 1975 Honda CB550F
A friend mounted a set on his Thunderbird Sport and didn’t have to rejet. They are loud however but if they have a removable baffle you could try stuffing one or two stainless pot scrubbers in the baffle and wrapping the baffle with high quality exhaust “wool” packing.
"You are either onto something or on something"........The Common Man
“Sometimes you are best off dealing with the Devil you know” anonymous
BRG-BIRD is offline
post #3 of 11 (permalink) Old 06-16-2019, 02:01 AM
turkpet's Avatar
Hi, I have the same on my TB 900, low cost but do a good job for me. Stock wool will soon tear, but there is an adjustable buffle on the market just for that muffer I instaled.
http://www.nichecycle.com/ncs/catego...s-by-emgo.html
No need to rejet, three screw on the buffle to set the loudnes
Pet
turkpet is offline
post #4 of 11 (permalink) Old 06-16-2019, 02:12 AM
turkpet's Avatar
On my TB
Pet
turkpet is offline
post #5 of 11 (permalink) Old 06-16-2019, 05:58 AM
Main Motorcycle: 97 adventurer
bubi's Avatar
Other Motorcycle: 96 t309 cafe racer
My experience is rejetting is only needed when fitting air filter pods necause you intake so much more air you need a it more fuel. Empty pipes just mean you have a bigger butt to fart louder nut the.meal stays the same.
BUBI 0_0
www.lamiatriumph.it
bubi is offline
post #6 of 11 (permalink) Old 06-16-2019, 09:52 AM
Main Motorcycle: 2002 Triumph America
Wire-Wheels's Avatar
Other Motorcycle: 1995 Triumph Sprint
Extra Motorcycle: 2000 Triumph Legend TT
BUBI 0_0
www.lamiatriumph.it
Actually improving both intake and exhaust flow should result in a need for re-jetting. In my book, if you don't have to re-jet for the exhaust system you put on, you wasted your money. You are not getting any more power. Just noise. Kind of reminds of the kid next door with his lowered Honda. ...J.D.
bubi likes this.
Wire-Wheels is offline
post #7 of 11 (permalink) Old 06-16-2019, 10:14 AM
bubi's Avatar
Yes, that is exactly the point for open pipes. Noise.
Arguably the stock pipes are open enough to yeald max power already
BUBI 0_0
www.lamiatriumph.it
bubi is offline
post #8 of 11 (permalink) Old 06-16-2019, 11:10 AM
Making noise is easy. If you want noise, I have a whole drawer full of drill bits out in my machinists chest. I can get you noise a lot cheaper. Or you can save up a little of your lunch money and do it right. (Been tuning engines since the late 1950's). ...J.D.
post #9 of 11 (permalink) Old 06-16-2019, 08:38 PM
WSC
Main Motorcycle: '07 Dyna Low Rider
WSC's Avatar
Other Motorcycle: '99 Legend TT
Extra Motorcycle: Thunderbolt, T150V
CV carbs meter fuel based on the difference in pressure between the float bowl (at ambient pressure) and the venturi. When you decrease the resistance to flow in the intake system you raise the pressure in the venturi for a particular flow rate, which reduces the motive force on the fuel, so the metering goes lean. Changing the back pressure from the exhaust does not effect the pressures in the carb, so, generally, has little to no effect on fuel metering.
John
Laconia Bike Week 2019 - See you all next year
2007 HD FXDL
1999 Legend TT
1975 T150V, 1968 BSA Thunderbolt, x2004 Thunderbird Sport
WSC is offline
post #10 of 11 (permalink) Old 06-17-2019, 02:53 PM
Not willing to get in to an 8 page thread on material that has been covered TOO many times. You tune yours and I'll tune mine. ...J.D.
