Is it normal...? - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
post #1 of 20 (permalink) Old 05-16-2019, 10:23 PM Thread Starter
Main Motorcycle: 2001 Triumph TB 900 Std
kdunlap92's Avatar
Other Motorcycle: 2012 Yamaha XT250
Extra Motorcycle: Honda CRF110F (my son's)
Is it normal...?
So now that I have a few hundred miles of riding on my 2001 stock TB that I picked up last November... is it normal to have difficulty shifting between 4th to 5th gear? It seems to be harder to get it from 4th into 5th gear than any of the other gears. Also is it true that these bikes prefer to be above 3000 RPMs for maximum performance? Mine has a little over 13,000 miles and other than the 4-5 shifting it's perfect!
Keith in PA (USA)
01 TB Std
someday...TBS in yellow and black
"Whatever you do, be a good one."
kdunlap92 is offline
post #2 of 20 (permalink) Old 05-17-2019, 03:13 AM
Main Motorcycle: 1999 Thunderbird Sport
I have a 99, and have no issues between any gears, except maybe a false neutral In higher gears once in a while. And yes, you will find the most usable torque above 3000 RPM. Above 4000 RPM the bike pulls like a freight train.
PB9717
pb9717 is offline
post #3 of 20 (permalink) Old 05-17-2019, 07:50 AM
WSC
Main Motorcycle: '07 Dyna Low Rider
WSC's Avatar
Other Motorcycle: '99 Legend TT
Extra Motorcycle: Thunderbolt, T150V
How do you define "difficulty"? Is it the effort you need to apply to the lever, or are you missing shifts (false neutral)?
What kind of oil are you using? How long since it was changed? Is it at the proper level? The engine oil also baths the wet clutch and lubricates the transmission.
John
Laconia Bike Week 2019 - See you all next year
2007 HD FXDL
1999 Legend TT
1975 T150V, 1968 BSA Thunderbolt, x2004 Thunderbird Sport
WSC is online now
post #4 of 20 (permalink) Old 05-17-2019, 08:01 AM Thread Starter
kdunlap92's Avatar
Seems to be a false neutral sporadically when shifting between 4-5 usually at the 3000 rpm range. Changed the oil this winter level is good. I used Ravenol full synthetic motorcycle
Keith in PA (USA)
01 TB Std
post #5 of 20 (permalink) Old 05-17-2019, 08:26 AM
Main Motorcycle: 1996 Thunderbird
BRG-BIRD's Avatar
Other Motorcycle: 2009 Moto Guzzi Norge
Extra Motorcycle: 1975 Honda CB550F
That’s a pretty low rpm to be shifting at, these engine like to be run at higher rpms. Have you tried shifting at a higher rpm?
"You are either onto something or on something"........The Common Man
“Sometimes you are best off dealing with the Devil you know” anonymous
BRG-BIRD is offline
post #6 of 20 (permalink) Old 05-17-2019, 08:36 AM Thread Starter
kdunlap92's Avatar
Not consistently but I'll shift at higher RPMs today and see how that goes I'm used to shifting at about 3k. Is full synthetic oil ok for these bikes?
Keith in PA (USA)
01 TB Std
post #7 of 20 (permalink) Old 05-17-2019, 09:57 AM Thread Starter
kdunlap92's Avatar
I found my answer on recommended oils from a 2014 post where WSC and IRL Mike provide good information. Thanks all for your input
Keith in PA (USA)
01 TB Std
post #8 of 20 (permalink) Old 05-17-2019, 10:17 AM
Main Motorcycle: 2000 Thunderbird Sport
Simian5's Avatar
Other Motorcycle: 95 HD Sportster
Good info!!
Simian5 is offline
post #9 of 20 (permalink) Old 05-17-2019, 11:02 AM
Main Motorcycle: Bonneville
BonnieJon's Avatar
Other Motorcycle: bmw
I used to get plenty of false neutrals 4 - 5 .
I did need to make a positive / firm gearchange.
When I did a casual flick it was not a happy lady.!
The habit soon developed and false neutrals went away.
BonnieJon is offline
post #10 of 20 (permalink) Old 05-17-2019, 01:02 PM
WSC
WSC's Avatar
Consider adjusting the shift lever down slightly, that way you'll pull it higher by instinct.
[edit]Oh, wait, it's not a TBS. That may not be possible...
John
2007 HD FXDL
1999 Legend TT
WSC is online now
my S3 heats up so fast normal? CometMan Speed Triple Forum 12 07-11-2016 05:14 PM
Is it normal for brand new engine to weep oil... RussAlan Air Cooled Twins Technical Talk 20 06-07-2013 02:11 PM
Engine clicking - normal? FongP Street Triple Forum 10 01-21-2013 11:38 PM
'sweet' smell coming from engine - normal?? CARBONS3 Speed Triple Forum 12 10-07-2012 04:19 PM
Is this normal ????? NJC955 Daytona Deliberations 6 03-12-2012 03:08 AM
