T3 Running Badly - Triumph Forum: Triumph Rat Motorcycle Forums
 2Likes
post #1 of 32 (permalink) Old 05-03-2019, 04:35 PM Thread Starter
Main Motorcycle: Bonneville
Other Motorcycle: Adventurer
Extra Motorcycle: Sportster
T3 Running Badly
My 1999 Adventurer has a chronic miss in the engine. I replaced the jets previously and have pods on the carbs and it has run strong in the past.
Before the last two times I cleaned out the jets and float valves, I had trouble with rust in the tank. Once I coated the tank, gas leaks stopped and the bike ran fine.
I suspect my problem is not in the carbs this time. I just cleaned them out and the jets looked OK. The bike took the throttle until about 2000 RPMs and then would break-up and stall.
I noticed today the right side cylinder ran cooler than the other two. Left and center pipes were 275 F. degrees, but the right pipe was 225 F. degrees. The temperature varied, but the right side pipe was always 50 degrees cooler.
I plan to change out the plugs, maybe switch the right and left plugs.
Does anyone have ideas?
Thanks,
Bonavent
Bonavent is offline
post #2 of 32 (permalink) Old 05-04-2019, 04:18 AM
Main Motorcycle: TBS,Daytona 900
Other Motorcycle: Speed Twin
Itís also probable that a coil is on the way out. Swap the coil over and see if the problem follows.
Burren Boyo. is online now
post #3 of 32 (permalink) Old 05-04-2019, 10:22 AM
Main Motorcycle: 2002 Triumph America
Wire-Wheels's Avatar
Other Motorcycle: 1995 Triumph Sprint
Extra Motorcycle: 2000 Triumph Legend TT
The pipe running cool is a dead giveaway that there is an ignition problem on that cylinder. To confirm it is a coil, switch around the coils to see if the problem moves to another cylinder. The original coils on these things are notorious for causing problems. Might consider replacing all of them if you don't have a history with the bike. Saves a lot of headaches. ...J.D.
Wire-Wheels is offline
post #4 of 32 (permalink) Old 05-04-2019, 03:12 PM Thread Starter
Thanks for the suggestions on switching coils. I'll do it!
The T3 is my favorite.
Bonavent
Bonavent is offline
post #5 of 32 (permalink) Old 05-04-2019, 05:20 PM Thread Starter
The right side exhaust pipe is still 50 degrees cooler after changing the coil, wire, and plug. I have 10.5 volts at the coil feed wires, same as other coils.
The engines misses at 2000 RPMs. Could it be a valve issue? Is it possible the right side carb is not getting sufficient fuel ? I see the ignition sensor wire at the crankcase has sealant on it. Would a bad sensor cause the engine to miss?
Thanks again,
Bonavent
Bonavent is offline
post #6 of 32 (permalink) Old 05-05-2019, 02:58 AM
Normally if the pick up coil is bad it will run fine then when hot give up, which might be your prob since the bike is stalling. Bike will then usually start and run fine after itís cooled down.
Certainly worth checking out the pick up coil and resetting the gap.
You said you had issues with rust previously and you donít think itís fuel issue but did you check the little witches hat filter at the carb?
post #7 of 32 (permalink) Old 05-05-2019, 06:29 AM
The voltage at the coils is kinda low. Should be above 12. Check your battery and alternator output. This could be causimg some of your problems. I would certainly check in to valve clearance as well.
post #8 of 32 (permalink) Old 05-07-2019, 08:08 AM Thread Starter
Thanks again.
The battery is a year old. I charged it yesterday and voltage today was 12.5 volts. Voltage at the coil feed wires read 10.9 volts.
I assume the witch hat filter (duckbill?) resides at the point where the fuel line connects to the carb bank. It was missing.
For some time, yesterday the right side exhaust pipe was cold. After I changed the coil, wires, and plugs around, the cylinder was firing, but still runs 50 degrees cooler than the others.
Before I check the valves and pick-up coil, I'll check for a voltage drain somewhere, ensure the right side carb is getting sufficient fuel, and then switch jets around on the carbs.
I have been cleaning the jets with a piece of wire from a wire brush, done gently I think, but may have scored a jet. I've been doing that all along especially when I had the rusty tank problem. I don't think that's the problem.
I appreciate expert thoughts and time taken to respond.
Thanks, Bonavent
Bonavent is offline
post #9 of 32 (permalink) Old 05-07-2019, 05:51 PM Thread Starter
I forgot to add. The alternator is charging: 14 volts at the battery.
Bonavent
Bonavent is offline
post #10 of 32 (permalink) Old 05-09-2019, 06:50 AM Thread Starter
This forum has been great help. Thank-you.
I'm almost ready to replace the igniter. I read 11.5 volts at both leads feeding each coil which is puzzling to me.
It also appears sources for igniters are OEM from Triumph or the Czech version.
Thanks again.
Bonavent
Bonavent is offline
Intermittent Poor Running (Carb - fuel/air issue?) Gooberkat Air Cooled Twins Technical Talk 19 06-26-2012 05:40 AM
05 Bonne: Was not starting, now barely running MohawkBri Air Cooled Twins Technical Talk 85 03-20-2012 05:31 PM
May Be Running Lean? beerzerker Air Cooled Twins Technical Talk 1 03-12-2012 02:01 AM
Lean running engine and vibration? Sparti Speed Triple Forum 7 02-06-2012 08:11 PM
How to install Bonny Running LightsÖ biker7 Air Cooled Twins Technical Talk 30 07-21-2011 05:43 PM
