T3 Running Badly - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
 2Likes
post #21 of 32 (permalink) Old 05-15-2019, 12:15 PM
Main Motorcycle: 2002 Triumph America
Wire-Wheels's Avatar
Other Motorcycle: 1995 Triumph Sprint
Extra Motorcycle: 2000 Triumph Legend TT
Originally Posted by WSC View Post
You should look at the voltage drop between the battery and the coils. The problem is not necessarily the battery, as the alternator powers the bike when it is running, not the battery.
I see the same thing. With the engine not running you should test the voltage supplied to the coils from the ignition switch (meter connected from ignition to ground). That voltage should be very close to what your battery voltage reading is ( battery + to ground), on all three cylinders (min. 12 volts). If it is not, you need to find out why, and fix it. I DO suspect there is something going on with that cylinder that is running cool, but one thing at a time. Get the ignition problems cleaned up first, THEN see what you have. ...J.D.
Wire-Wheels is offline
post #22 of 32 (permalink) Old 05-15-2019, 01:14 PM
WSC
Main Motorcycle: '07 Dyna Low Rider
WSC's Avatar
Other Motorcycle: '99 Legend TT
Extra Motorcycle: Thunderbolt, T150V
Put the positive probe on the battery plus and the negative probe on the coil plus. The meter will read the voltage drop between the battery and the coil.
John
Laconia Bike Week 2019 - See you all next year
2007 HD FXDL
1999 Legend TT
1975 T150V, 1968 BSA Thunderbolt, x2004 Thunderbird Sport
WSC is offline
post #23 of 32 (permalink) Old 05-15-2019, 02:56 PM
No need. Your brain can do the math [joke]… I'm also thinking about the ground side. Maybe a bad ground ? But you are right. Using a volt meter to check the voltage drop can be useful. A good way to check the viability of battery cable connections. I'd start with the kill switch and follow the circuit through the ignition switch, all the way to the coils. Could even be before the kill switch. Something is being lost somewhere. ...J.D.
post #24 of 32 (permalink) Old 05-15-2019, 06:45 PM Thread Starter
Main Motorcycle: Bonneville
Other Motorcycle: Adventurer
Extra Motorcycle: Sportster
Thanks again. I'll do some voltage tests. The battery is weak, so it does need replaced.
Now that you mention the kill switches, battery cables and grounds, I won't be surprised. The kick stand switch has stuck before, plus sometimes I have to pull the clutch lever to make the starter work, even in neutral.
No doubt, I'll find more bugs - 20 years old, but a great motorcycle.
Thanks,
Bonavent
Bonavent is offline
post #25 of 32 (permalink) Old 05-24-2019, 03:09 PM Thread Starter
The Ignitech igniter is installed and the bike seems stronger.
The bike was slow to start and was blowing smoke for while, but evened-out. I plan to take the bike out later or tomorrow.
I was surprised I didn't have to hook up the computer to program the igniter. Evidently, the igniter is set up at Ignitech and I've ask them the question.
Thanks for help on this issue.
Bonavent
BRG-BIRD likes this.
Bonavent is offline
post #26 of 32 (permalink) Old 05-25-2019, 09:56 AM Thread Starter
After replacing the igniter, I attempted to take the bike out for a shakedown ride.
The bike stalls with I engage first gear. That's happened previously but I was always able to solve it by pulling in the clutch a few times and maybe shifting into gear a few times. I've lubricated the kickstand switch before thinking that was the problem. It didn't work this time.
I also noticed the tachometer was not working. It always did before I switched igniters.
Does anyone have experience with these problems? I'm searching now.
Thanks,
Bonavent
Bonavent is offline
post #27 of 32 (permalink) Old 05-25-2019, 10:27 AM
Main Motorcycle: Adventurer 900
gassa's Avatar
Other Motorcycle: Virago 1100
Bonavent
I am surprised too, because I had to programme my Ignitech, there is an excellent program on here from Irlmike.
gassa is online now
post #28 of 32 (permalink) Old 05-26-2019, 10:26 AM Thread Starter
Thank-you. I think the tachometer fault is due to the igniter programming.
The greater problem now is the clutch doesn't disengage, i.e. the bike won't roll in gear with the clutch lever pulled in. That explains the bike stalling when put in gear.
Plus, I can't get the clutch reservoir screws out. I'm using some lubricate and have an impact wrench that I'm gently using.
I'm also searching for solutions to the clutch problem.
Bonavent is offline
post #29 of 32 (permalink) Old 05-26-2019, 11:19 AM
Main Motorcycle: TBS,Daytona 900
Other Motorcycle: Speed Twin
Try rocking the bike back and forth clutch in and it might release.
Burren Boyo. is online now
post #30 of 32 (permalink) Old 05-26-2019, 03:56 PM
WSC
WSC's Avatar
The screws on the clutch reservoir are JIS standard, not Philips. If you use a Philips tip on them you'll almost certainly fail...
John
2007 HD FXDL
1999 Legend TT
WSC is offline
Intermittent Poor Running (Carb - fuel/air issue?) Gooberkat Air Cooled Twins Technical Talk 19 06-26-2012 06:40 AM
05 Bonne: Was not starting, now barely running MohawkBri Air Cooled Twins Technical Talk 85 03-20-2012 06:31 PM
May Be Running Lean? beerzerker Air Cooled Twins Technical Talk 1 03-12-2012 03:01 AM
Lean running engine and vibration? Sparti Speed Triple Forum 7 02-06-2012 09:11 PM
How to install Bonny Running Lights… biker7 Air Cooled Twins Technical Talk 30 07-21-2011 06:43 PM
