T3 Running Badly - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
 2Likes
post #11 of 32 (permalink) Old 05-09-2019, 08:39 AM
WSC
Main Motorcycle: '07 Dyna Low Rider
WSC's Avatar
Other Motorcycle: '99 Legend TT
Extra Motorcycle: Thunderbolt, T150V
Originally Posted by Bonavent View Post
I'm almost ready to replace the igniter. I read 11.5 volts at both leads feeding each coil which is puzzling to me.
That could cause it to not run, but wouldn't cause a miss. The igniter works like a set of ignition points. Then the "points" are open you'll see the same voltage on both sides of the coil. When they are closed you'll see (near) zero volts on the negative side and 11.5 or whatever on the plus side. If you're trying to read it while the engine is running all bets are off.
John
Laconia Bike Week 2019 - See you all next year
2007 HD FXDL
1999 Legend TT
1975 T150V, 1968 BSA Thunderbolt, x2004 Thunderbird Sport
WSC is online now
post #12 of 32 (permalink) Old 05-09-2019, 02:31 PM Thread Starter
Main Motorcycle: Bonneville
Other Motorcycle: Adventurer
Extra Motorcycle: Sportster
I understand, thank-you.
ACV on the negative side of all the coils reads .29 ACV.
I'm still searching for a conclusive way to determine if the igniter is good or bad.
The engine breaks up pretty badly at RPM>2000. The right side exhaust pipe is consistently 50 degrees cooler regardless of the temperature variation.
TY,
Bonavent
Bonavent is offline
post #13 of 32 (permalink) Old 05-09-2019, 08:40 PM
WSC
WSC's Avatar
It's not AC, it's pulsed DC. You can use a frequency meter or a dwell meter or a duty cycle meter. The frequency meter should vary in proportion with RPM. The other two will give you a (steady) reading somewhere between zero and 100%. (If it reads either 0 or 100 something is wrong.)
Regardless, I wouldn't expect the igniter to cause a miss. I would expect it to cause one or more dropped cylinders.
John
2007 HD FXDL
1999 Legend TT
WSC is online now
post #14 of 32 (permalink) Old 05-10-2019, 05:30 AM
Main Motorcycle: Adventurer 900
gassa's Avatar
Other Motorcycle: Virago 1100
When my igniter went south the center cylinder dropped out completely, occasionally run again but progressively got worse until it wouldn't start. no miss firing just no firing.
gassa is offline
post #15 of 32 (permalink) Old 05-10-2019, 10:57 AM Thread Starter
Thanks, I appreciate the responses. I have more than a miss in the engine; it breaks up pretty badly.
I had difficulty fitting one of the outside carburetor diaphragms, so I'm going to pull the carb bank & maybe change jets around too.
The cylinder wasn't firing at all just one time, other wise, the only difference is lower temperature by 50 degrees.
It seems like the igniter would fail completely rather than get progressively worse before it failed. I suspect my bike won't start either and I'll be replacing the igniter too. In the meantime, I'll keeping testing and locate a duty-cycle/dwell/frequency meter.
Thanks again,
Bonavent
Bonavent is offline
post #16 of 32 (permalink) Old 05-13-2019, 01:14 PM
Main Motorcycle: 2001 Legend
Other Motorcycle: Honda Magna V45
My legend was acting the same as your bike misfiring on one cylinder every now and again it would kick in long story short it turned out to be the igniter replaced it problem solved
MickB is offline
post #17 of 32 (permalink) Old 05-14-2019, 06:57 AM
Main Motorcycle: 2002 Thunderbird
Jamanimal's Avatar
Other Motorcycle: T-Bird lives alone
While reading through the string, I didn't see if you changed around your plug wires.
If they are the original wires, you could have one either breaking down, or a poor connection.
If you haven't already, do a resistance check on the wires, get a flashlight and look at the internal connecting clip at the base....etc.
I like to put a dab of dielectric grease on the boot connector interior to keep out moisture, and ease installation.
Good luck,
Dan
Jamanimal is offline
post #18 of 32 (permalink) Old 05-14-2019, 10:38 AM
Main Motorcycle: 2002 Triumph America
Wire-Wheels's Avatar
Other Motorcycle: 1995 Triumph Sprint
Extra Motorcycle: 2000 Triumph Legend TT
I'm still wondering about the low voltage readings at the coils. If your primary voltage is low, your secondary voltage will be very low. Garbage in- garbage out. ...J.D.
Wire-Wheels is offline
post #19 of 32 (permalink) Old 05-15-2019, 07:03 AM Thread Starter
Thank-you. I changed the coils and plug wires around and the temperature deficiency remained on the right side cylinder. I have a greater problem because how badly the bike runs. I've ordered the igniter from Ignitech.
After I charged the battery, voltage increased at the coils to over 11 volts. I've also ordered an Interstate AGM battery for the bike.
Much appreciated,
Bonavent
Gainesville, FL
Bonavent is offline
post #20 of 32 (permalink) Old 05-15-2019, 09:42 AM
WSC
WSC's Avatar
You should look at the voltage drop between the battery and the coils. The problem is not necessarily the battery, as the alternator powers the bike when it is running, not the battery.
John
2007 HD FXDL
1999 Legend TT
WSC is online now
Intermittent Poor Running (Carb - fuel/air issue?) Gooberkat Air Cooled Twins Technical Talk 18 06-26-2012 05:40 AM
05 Bonne: Was not starting, now barely running MohawkBri Air Cooled Twins Technical Talk 85 03-20-2012 05:31 PM
May Be Running Lean? beerzerker Air Cooled Twins Technical Talk 1 03-12-2012 02:01 AM
Lean running engine and vibration? Sparti Speed Triple Forum 7 02-06-2012 08:11 PM
How to install Bonny Running Lights… biker7 Air Cooled Twins Technical Talk 30 07-21-2011 05:43 PM
