Gear change clunky on 1995 T'bird - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
  • 1 Post By WSC
post #1 of 6 (permalink) Old 04-11-2019, 03:31 PM Thread Starter
Main Motorcycle: 2016 Bonnie
PatrickO's Avatar
Question for the spanner experts. I've just got a 1995 Thunderbird 900 with 20k miles. Took it for a first ride today for an hour or so. Generally very happy. Pulls really well especially when wound up a bit.
However, the gear changes are very clunky, especially changing up. I only tried 1st to 4th, but all seem stiff. On changing up most times it takes two goes. I push up on the gear lever and it won't move, then I take the pressure off and try again and it changes up easily.
Also changing from neutral to first is very clunky and loud. I know this is common to some extent with many bikes, but seems worse with this bike.
Perhaps my technique, but worse than I've had on any other bike. The garage I bought it off claim to have done an oil and filter change.
Any advice appreciated. What should I check first?
“Calling upon my years of experience, I froze at the controls.”
– Stirling Moss
PatrickO is offline
post #2 of 6 (permalink) Old 04-11-2019, 04:46 PM
WSC
Main Motorcycle: '07 Dyna Low Rider
WSC's Avatar
Other Motorcycle: '99 Legend TT
Extra Motorcycle: Thunderbolt, T150V
First, does the clutch release correctly? (Can you push the bike in gear with the clutch pulled in? If it drags a lot more than in neutral, the clutch may be dragging.)
What type of oil did they use for the oil change? These bikes use a wet clutch and different oils, even different oils recommended for wet clutches, will often perform differently. Look for oils that carry the JASO-MA(#) rating. I've had good results with Shell Rotella T-6. It's marketed as a Diesel oil, but it used to carry a spark ignition rating and it meets the above spec. It's also a full synthetic and is readily available here in the colonies for a reasonable price. (Since it doesn't meet the more recent specs for cars they have dropped the "S" rating, probably for liability reasons.)
Lastly, the transmissions do tend to be clunky, but you shouldn't have to try to shift more than once per gear change.
PatrickO likes this.
John
Laconia Bike Week 2018 See you next year!
2004 Thunderbird Sport
1999 Legend TT
1975 T150V, 1968 BSA Thunderbolt
WSC is online now
post #3 of 6 (permalink) Old 04-12-2019, 01:26 PM Thread Starter
PatrickO's Avatar
Thanks John. Just tried that and it's a little harder to push the bike in gear with the clutch pulled in than in neutral. Does that mean the clutch lever needs adjusting? Or a problem with the clutch itself?
Patrick
– Stirling Moss
PatrickO is offline
post #4 of 6 (permalink) Old 04-15-2019, 02:54 PM
Main Motorcycle: Triumph Thunderbird Sport
Patrick
Hi, I am in same situation as you. First I have to overcome a certain resistance with clutch lever pressed in first gear, which then releases, then it is just a little harder than in neutral. But when in first gear with clutch pressed engine do not pull.
I hope someone knows what to do with it.
M.
MarfiK is offline
post #5 of 6 (permalink) Old 04-15-2019, 10:04 PM
WSC
WSC's Avatar
The clutch runs in an oil bath, so it's always going to be a little stiffer than in neutral, but if the bike doesn't creep forward when you hold the clutch in in gear then it's releasing OK.
John
1999 Legend TT
WSC is online now
post #6 of 6 (permalink) Old 04-16-2019, 02:46 AM
OK. I know how it is when clutch do not release properly from my previous VT 600, when it was not adjusted right.
MarfiK is offline
Daytona 955i dont start after i have failed to change gear... HGB Daytona Deliberations 14 08-27-2012 08:47 PM
Right to left hand gear change? loxx101 Classic, Vintage & Veteran 7 07-16-2012 08:31 AM
Left to right hand gear change? loxx101 Classic, Vintage & Veteran 8 07-15-2012 08:41 PM
98 T509 Clunky Gear Changes thespirit3 Speed Triple Forum 3 03-24-2009 11:37 AM
Transmission Question ooobaby Classic, Vintage & Veteran 16 11-12-2007 01:36 AM
