Messed up my carbs? - Triumph Forum: Triumph Rat Motorcycle Forums
 2Likes
post #1 of 37 (permalink) Old 04-07-2019, 05:50 PM Thread Starter
Main Motorcycle: 2000 Triumph Thunderbird
AvidRevs's Avatar
Messed up my carbs?
So I opened up the airbox on my '00 Thunderbird. Dismantled and rejetted my carbs. Put in 42 pilots and 140 main jets, set my slow screws to 2-1/2 turns out, put in new float needles and left the height at about 19mm. Now the bike won't start. Turns over but sounds like no gas. FRACK!
AvidRevs is offline
post #2 of 37 (permalink) Old 04-09-2019, 11:40 AM
Main Motorcycle: 2002 Triumph America
Wire-Wheels's Avatar
Other Motorcycle: 1995 Triumph Sprint
Extra Motorcycle: 2000 Triumph Legend TT
s km
Time to backtrack. "Where did I go wrong?" First time I did one of these [16-17 yrs. back], I got it a block down the street [downhill of course] and it quit. Had a neighbor help me get it back in my shop and found I kinked the fuel line putting the tank back on. Just have to go back over it carefully. ...J.D.
Wire-Wheels is offline
post #3 of 37 (permalink) Old 04-09-2019, 12:54 PM
WSC
Main Motorcycle: '07 Dyna Low Rider
WSC's Avatar
Other Motorcycle: '99 Legend TT
Extra Motorcycle: Thunderbolt, T150V
Open one of the bowl drains and see if fuel comes out.
Pull one of the spark plugs out. Wet or dry? Does it spark?
John
Laconia Bike Week 2019 - See you all next year
2007 HD FXDL
1999 Legend TT
1975 T150V, 1968 BSA Thunderbolt, x2004 Thunderbird Sport
WSC is offline
post #4 of 37 (permalink) Old 04-10-2019, 07:13 AM Thread Starter
AvidRevs's Avatar
Yeah, pretty bummed to not have it run after all that work. (For me it was all a new experience) There is fuel in bowls. It sounds as though it's sparking. I'd be surprised if it isn't.
I did change the plugs but the rest of the ignition ran before I did the carbs and air filter mod. I will pull one plug to make sure it's sparking. I guess Backtracking is my plan. Take the cabs off again and make sure everything is clear. Thanks.
AvidRevs is offline
post #5 of 37 (permalink) Old 04-10-2019, 03:28 PM
Main Motorcycle: 2002 Thunderbird
Jamanimal's Avatar
Other Motorcycle: T-Bird lives alone
Do you smell gas as you're cranking with no sputtering/sparking?
42 mains may be a little rich for startup at 2.5 turns, even with air intake mods. You may want to back down to 2 turns.
Mine are happy at 1 7/8 turns.
Also, since the carbs were off, hopefully you didn't disturb the balance screws...that will also add problems at cold starts.
One problem with these motors is that they can be very picky at startup.
Make sure your battery is nicely juiced up, and then go after confirming your spark if nothing fires.
Good Luck!
Dan
Jamanimal is offline
post #6 of 37 (permalink) Old 04-11-2019, 05:49 AM Thread Starter
AvidRevs's Avatar
Good Luck!
Dan
I did try charging the battery with my car. Didn't think it would help but figured it was worth a try.
The bike definitely cranked better but still no start. There is gas in the float bowls but I do not smell any near the engine or exhaust. Ballance Screws? Not sure. I looked at bench syncing the carbs but the the butterfly valves all seemed pretty tight in line with each other. I'll go over it all again this weekend.
AvidRevs is offline
post #7 of 37 (permalink) Old 04-11-2019, 04:47 PM
Don't really think your pilot jet or mixture adjustment would be the problem. If it is a little rich it would probably start easier. I am wondering what your bench settings are on your throttle butterflys. Should be a spec. for that somewhere [I don't have it at hand]. You would measure the distance between the butterfly and the throttle bore and set all three the same. Then after you get it running you can balance the carbs. ...J.D.
post #8 of 37 (permalink) Old 04-15-2019, 08:49 AM
Main Motorcycle: 2002 Bonneville America
Texstrom's Avatar
Other Motorcycle: 1996 Thunderbird
Extra Motorcycle: 71 BMW R75 (Project)
Maybe be sure the float needles are correct. If there is fuel in the bowls , not sure why it wouldn't run, even if it ran poorly still should start .
Texstrom is offline
post #9 of 37 (permalink) Old 04-15-2019, 08:47 PM
Main Motorcycle: 2001 Legend TT
Real dumb thought but I did it when I rebuild something on my bike. Did you hook the spark plug wires up to the right cylinder? I spent 4 days fighting my own stupidity.
clumsy is offline
post #10 of 37 (permalink) Old 04-15-2019, 09:15 PM
Did you block the air vent of the tank??
Sent from my iPhone using Tapatalk
prmurat is offline
Need help with new FCR Carbs Shelton04 Air Cooled Twins Technical Talk 10 07-15-2016 10:20 AM
Stock everything - confirming changes to carbs avu3 Hinckley Classic Triples 15 06-13-2015 07:32 AM
Aftermarket Accelerator Pump for FCR Carbs...Installed One Today sbpark Air Cooled Twins Technical Talk 10 03-24-2010 10:41 AM
switching out CR carbs dor FCR's... sbpark Air Cooled Twins Technical Talk 1 08-08-2008 07:51 AM
Synched my carbs with soap Panthermark Air Cooled Twins Talk 19 04-08-2006 09:14 PM
