Triumph Adventurer owner from Iceland - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
post #21 of 23 (permalink) Old 10-09-2018, 07:37 PM Thread Starter
Main Motorcycle: 1996 Triumph Adventurer
Other Motorcycle: 1981 MZ TS150
Guys do you know whether this thing in the picture is aluminum corrosion or some sort of clear coat coming off? And what the best way to deal with it is without damaging the aluminum?
axes is offline
post #22 of 23 (permalink) Old 10-09-2018, 11:03 PM
WSC
Main Motorcycle: '07 Dyna Low Rider
WSC's Avatar
Other Motorcycle: '99 Legend TT
Extra Motorcycle: Thunderbolt, T150V
A little of both.
First you have to strip off the rest of the clear coat. Don't bother trying to polish it off; you'll drive yourself crazy. I use a product called Citristrip. Another good choice is called "Aircraft Remover." Whatever you use, make sure it's safe for aluminum. Some products can cause more corrosion and others can discolor the aluminum. It's easiest if you remove the triple clamp from the bike.
Once you've got the coating out of the way you can evaluate the corrosion. If it's not to heavy you can try some metal polish. If it's deep you can use aluminum oxide sand paper. Start with 220 grit and work your way up to 1600 or 2000. Avoid emery paper, steel wool, or any abrasive with iron or steel in it. Finish with the polish.
When you're finished polishing you can try to clear coat it again, but I've found it's hard to get good adhesion on a polished surface. There's a product called "Sharkhide Protectant" that works well.
John
Laconia Bike Week 2019 - See you all next year
2007 HD FXDL
1999 Legend TT
1975 T150V, 1968 BSA Thunderbolt, x2004 Thunderbird Sport
WSC is online now
post #23 of 23 (permalink) Old 10-14-2018, 09:08 AM Thread Starter
Originally Posted by WSC View Post
A little of both.
Thanks for the tip and instructions John, I've made an attempt to find those stripping products but without luck. But I think I know where to get it now though.
axes is offline
New 99 Adventurer Owner EckhoffB The Welcome Center 3 04-25-2018 12:47 AM
Hello, new Adventurer owner here. Odysseus41 The Welcome Center 1 03-15-2018 06:43 AM
New '98 Adventurer Owner Powdevil Hinckley Classic Triples 23 01-07-2018 08:09 PM
New Adventurer owner cusmanm The Welcome Center 4 10-16-2017 08:04 PM
99 adventurer, new owner DanJen88 The Welcome Center 2 07-27-2015 08:27 AM
