Fuel Tank Cap - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
  • 1 Post By WSC
post #1 of 4 (permalink) Old 09-10-2017, 06:13 PM Thread Starter
Main Motorcycle: Triumph Legend TT 2000
Fuel Tank Cap
Hi. I recently got my 2000 Legend TT on the road after a hiatus of several years. Enjoying it very much. Spent a pretty penny to clean the carbs and replace some of the electronics that had gone bad.
Am having one small problem -- the one-way valve on my gas cap which prevents the buildup of a vacuum inside the tank is failing. The result is that the engine gets deprived of fuel after some consumption reduces the contents of the tank, creating the vacuum pressure. To solve the problem I must briefly unscrew the cap, to relieve the pressure. That starts it all over, but the same problem returns after a few miles.
Does anyone know how to repair the gas cap? Is there a way to deal with the valve so it works again?
I would very much appreciate some input on this -- it's a small matter, but annoying.
Thanks.
4Patriot is offline
post #2 of 4 (permalink) Old 09-10-2017, 09:30 PM
WSC
Main Motorcycle: '07 Dyna Low Rider
WSC's Avatar
Other Motorcycle: '99 Legend TT
Extra Motorcycle: Thunderbolt, T150V
The vent line at the rear left corner of the tank should vent the tank regardless of what the cap does. There should be a tip over valve about 3 inches below the tank. It needs to be working, connected the right way, and positioned vertically.
CharlieS likes this.
John
Laconia Bike Week 2019 - See you all next year
2007 HD FXDL
1999 Legend TT
1975 T150V, 1968 BSA Thunderbolt, x2004 Thunderbird Sport
WSC is online now
post #3 of 4 (permalink) Old 09-11-2017, 10:11 AM
Main Motorcycle: Thunderbird sport 2000
Zee9's Avatar
Thanks.
I had a similar issue and luckily @simplyj had an extra older cap lying around for me to test if that was the issue. It was and luckily he gave me that cap. The funny thing is that his cap was an older cap and didn't even have a the vent like my oem cap had and I have not had issue since then.
Zee
2000 triumph thunderbird sport
2015 bmw f700gs
Zee9 is offline
post #4 of 4 (permalink) Old 09-11-2017, 07:22 PM
Main Motorcycle: 2001 Triumph Thunderbird
Other Motorcycle: 1981 Honda CB 750K
4Patriot. I have an extra gas cap. PM me if you need it.
Sent from my iPhone using Tapatalk
swaymix is offline
FuelBot - Fuel Level & MPG Gauge DEcosse Speed Triple Forum 53 02-10-2018 02:11 PM
New Tank ? GySchmit Air Cooled Twins Talk 8 02-23-2016 08:50 PM
New cap and tank ventilation. piff Air Cooled Twins Technical Talk 39 12-14-2015 04:59 AM
Fuel cap mod johned Tiger 1050 - Mods & Workshop 0 11-19-2015 06:22 AM
fuel tank cap bikedog Classic, Vintage & Veteran 19 08-29-2015 12:59 PM
