Exhaust Question - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
 8Likes
post #11 of 20 (permalink) Old 04-03-2017, 02:33 PM
Main Motorcycle: 2002 Triumph America
Wire-Wheels's Avatar
Other Motorcycle: 1995 Triumph Sprint
Extra Motorcycle: 2000 Triumph Legend TT
Something I have learned with these carburetted Triumph engines. They don't like premium grade fuel. If you are using it, go down to mid grade and it will pop a lot less. It may still pop. Just not as much. All three of mine grumble a little, but not bad. Even the one with stock pipes. ...J.D.
Wire-Wheels is offline
post #12 of 20 (permalink) Old 04-03-2017, 02:56 PM
Main Motorcycle: Thunderbird sport 2000
Zee9's Avatar
Originally Posted by imgnr View Post
Hi All,
Came back from a three day ride and my buddies are all complaining about my pipes. These are Harley guys. The PO put TORs on and it is loud. They refuse to ride behind me!
Anyhow, since two pipes go into one exhaust and one pipe goes into the other one, are the internals the same? I would think the one with the two headers would need to flow a lot more exhaust. Just wondering cuz there are a ton of Bonneville exhausts on E-Bay and thinking about picking a pair up. Since they'r two cylinders, I would think the Bonnie pipes would be identical.
Thank you!
Those are multiple questions and there are lots of choices but too much info to type. Pm me and we can chat on the phone. I've tried about 6 types of mufflers on my Tbs and would gladly share the insight
Zee
2000 Triumph Thunderbird Sport
2015 BMW F700GS
Zee9 is offline
post #13 of 20 (permalink) Old 08-06-2019, 11:34 AM
Main Motorcycle: 2004 TBS
Other Motorcycle: 2004 Speed Triple
Zee, I have a 2004 TBS running stock everything (air and silencers). Bike runs very well but so quiet....I have just ordered a set of Mistral silencers. In your learned opinion, will I need to make carburetor adjustments following installation? Thanks for your time!
Gottago is offline
post #14 of 20 (permalink) Old 08-12-2019, 01:17 PM
Main Motorcycle: 97 adventurer
bubi's Avatar
Other Motorcycle: 96 t309 cafe racer
I run with pea shooter togas, they are completely empty and criminally loud.
Only rejetted when I modded the air filter because the mix was too lean.
Never had an issue while interchanging pipes of different sorts, if not that with silent pipes I speed because I can't hear how fast I am going. And feel lame.
BUBI 0_0
www.lamiatriumph.it
bubi is offline
post #15 of 20 (permalink) Old 08-12-2019, 01:21 PM
bubi's Avatar
Nobody can ride behind me but I am soooo slow I generally eat dust.
BUBI 0_0
www.lamiatriumph.it
DaveM and Gottago like this.
bubi is offline
post #16 of 20 (permalink) Old 08-12-2019, 08:02 PM
Main Motorcycle: 2000 Adventurer
Landlocked's Avatar
I went and bought a set of Sprint pipes for my Adventurer. I liked the sound with the stock baffles but turned out they were to restrictive so I pulled them to which the pipes were way to loud for my taste so I went and made my own baffles with parts bought from e-bay and Tractor Supply!, Happy camper now.( pic's are of my first attempt, I have since made a better set )
ID:	652110   Click image for larger version
ID:	652112   Click image for larger version
ID:	652114   Click image for larger version
DaveM likes this.
Landlocked is online now
post #17 of 20 (permalink) Old 08-13-2019, 03:42 AM
CG1
Main Motorcycle: Daytona Super 3
Other Motorcycle: TM 250MX
When I owned my Adventurer I bought the factory TORS it was better than standard but still got some custom headers and cans made anyway, I still have the TORS and original headers in the shed somewhere 4 Triumphs later...
CG1 is offline
post #18 of 20 (permalink) Old 08-15-2019, 12:14 PM Thread Starter
Main Motorcycle: BMW gs
The OEM pipes are super heavy and so long that they need to be removed when taking my rear wheel off. Wish I can drop pictures in this forum wo having to link to somewhere else. The Emgo shorties are nice. Not too loud when idling but will roar when opened up. Hope I donít get pulled over.
imgnr is offline
post #19 of 20 (permalink) Old 08-15-2019, 01:02 PM
Zee9's Avatar
Usually jetting only needs to be changed if you remove the air box and add pods. Doubt you will need it just for a muffler change. I donít have the air box and am running 42/145 jets with factory pro needles one shim up.
Sent from my iPhone using Tapatalk
Gottago likes this.
Zee9 is offline
post #20 of 20 (permalink) Old 09-02-2019, 12:39 PM
Main Motorcycle: 97 triumph thunderbird
Other Motorcycle: 1974 Kawasaki H1
Extra Motorcycle: none
Thumbs up Exhaust Popping
Just noticed you have been trying Jets to stop the popping, I did the same for about 4 years and eventually gave up, just recently I changed the Mikuni carbs to Kei Hin(with a jet kit) and not a pop since. Better idle,smoother roll on throttle and no pops, only regret is I didnt do this years ago
Those that ignore the past are doomed to repeat its mistakes
ferger is offline
Street Twin's Vance & Hines exhaust option Scrambler900 Air Cooled Twins Talk 18 02-09-2019 01:19 PM
TOR exhaust for T100 question Detroitdawg Air Cooled Twins Talk 8 12-08-2016 09:30 PM
Exhaust building question Unit 650 Nickd Classic, Vintage & Veteran 11 09-14-2015 03:05 AM
2013 Bonneville Stock Exhaust Assembly Question hhk_222 Air Cooled Twins Talk 1 03-17-2015 05:48 PM
2014 T100 Exhaust & Header Question Whittle Air Cooled Twins Technical Talk 3 03-09-2015 07:40 PM
