Dirty instrument-glass on inside - Triumph Forum: Triumph Rat Motorcycle Forums
 6Likes
post #1 of 26 (permalink) Old 10-02-2016, 03:15 PM Thread Starter
Main Motorcycle: 1995 Thunderbird 900
Mikholst's Avatar
I am having this urge to have a shiny bike. I have noticed that on the inside of both instrument glasses there are spots, and even a finger print. How do I get access to the inside of the glass without ruining anything? Itīs a 95 TBird. Pic attached.
Name:	Instrument glass.jpg
Regards, Mikael
The difference between men and boys is the price of their bike
Mikholst is offline
post #2 of 26 (permalink) Old 10-02-2016, 05:09 PM
WSC
Main Motorcycle: '07 Dyna Low Rider
WSC's Avatar
Other Motorcycle: '99 Legend TT
Extra Motorcycle: Thunderbolt, T150V
Find the guy who put the finger print there and ask him. They cannot be opened by mere mortals
denny likes this.
John
Laconia Bike Week 2019 - See you all next year
2007 HD FXDL
1999 Legend TT
1975 T150V, 1968 BSA Thunderbolt, x2004 Thunderbird Sport
WSC is offline
post #3 of 26 (permalink) Old 10-02-2016, 06:45 PM Thread Starter
Mikholst's Avatar
Thatīs what I suspected. Nothing to do about it. Thanks for the reply
Regards, Mikael
Mikholst is offline
post #4 of 26 (permalink) Old 10-02-2016, 09:28 PM
WSC
WSC's Avatar
There are people who have worked around the bottom of the chrome ring with a thin screw driver and gotten the glass off, but it's hard to do without doing some damage, and doubly hard to get it crimped back down again without it looking like it has been butchered.
John
2007 HD FXDL
1999 Legend TT
WSC is offline
post #5 of 26 (permalink) Old 10-03-2016, 03:54 PM
Main Motorcycle: None anymore
Other Motorcycle: 1970 Yamaha XS1B
There are a couple of old threads on here about successfully opening the cases. I did one and Arferbrick has done one using slightly different methods. It's no picnic, but I was OCD like you and did my tach just because it was foggy inside. It basically involves carefully cutting all around the plastic case, doing whatever is needed inside, and then rejoining the case halves. The other alternative is replacement new gauges which can be had for only about $300-$400.
JRobyn is offline
post #6 of 26 (permalink) Old 10-05-2016, 09:25 PM
Main Motorcycle: my 1995 Triumph Tiger
ssevy's Avatar
Other Motorcycle: 1999 Triumph Legend
You might try to do something similar to what I did to open my tach:
https://www.triumphrat.net/maintenanc...achometer.html
ssevy is offline
post #7 of 26 (permalink) Old 10-06-2016, 05:38 AM Thread Starter
Mikholst's Avatar
Hi Ssevy.
As I see it your way is the only way. I think itīs too much hassle to clean the glasses though. But thanks anyway.
Regards, Mikael
Mikholst is offline
post #8 of 26 (permalink) Old 10-06-2016, 07:45 PM
Main Motorcycle: 93 Honda ST1100
Other Motorcycle: 96 Yamaha Seca II (XJ600)
Extra Motorcycle: 95 Triumph TB
What I want to know is how in the blazes bugs can get into these spaces - not on a bike but a couple of our older cars. there's a dead mosquito behind the clear plastic on one and a dead, dried-up spider in another. It's almost like they had to hatch in there or something.
Bluewrench is offline
post #9 of 26 (permalink) Old 10-08-2016, 05:52 PM
WSC
WSC's Avatar
Ssevy: your PM mailbox is full...
You said to cut the housing in the area where the grommet contacts it (close to the glass). Any reason not to cut it farther down, where the metal cover, which has more clearance, covers it?
(My problem is the tach reads about 1000 RPM high and doesn't return to zero.) I'm thinking the spring on the needle may have come loose. I seem to recall Hondas plagued with that problem.
Do you know if the meter is a stepper? If so, maybe it's just not stepped back to zero, for whatever reason...
John
2007 HD FXDL
1999 Legend TT
WSC is offline
post #10 of 26 (permalink) Old 10-08-2016, 10:49 PM
ssevy's Avatar
Sorry John,
Just emptied my inbox.
If you look at the picture of the inside of the white plastic housing in my thread, you'll see there are some other things just below the spot I cut that would be affected if you cut it lower. Maybe no issue, but if you follow my lucky guess first cut, you know it's a proven thing. No reason you can't try whatever you want though.
ssevy is offline
Oil Sight Glass Rotated bikertucker Water Cooled Twins Technical Talk 35 11-08-2016 07:00 PM
Has anyone replaced the mirror glass on the stock Sprint GT mirror? DaveM Sprint Forum 16 12-21-2015 10:57 AM
How to clean inside of my gauge ? tommyz24 Air Cooled Twins Talk 4 08-17-2015 03:55 PM
Broken tach glass DanR Air Cooled Twins Technical Talk 1 06-13-2015 05:28 PM
