Bafflectomy for 98 TBS?? - Triumph Forum: Triumph Rat Motorcycle Forums
 2Likes
post #1 of 13 (permalink) Old 07-12-2016, 04:17 PM Thread Starter
Zev
Main Motorcycle: 1998 Thunderbird Sport
I've searched the forum high and low. I've found many fantastic clinics on baffleectomy for many pipes on many bikes, but not for the original stacked 3 into 2 pipes that come with the 98 TBS. I would like a bit more bass out of the existing pipes. Any suggestions/links?
Zev is offline
post #2 of 13 (permalink) Old 07-15-2016, 10:39 PM
Main Motorcycle: 1998 TBird Sport
Loose Gravel's Avatar
Other Motorcycle: BMW R1150RT
I'd like to animate this topic--bump.
Loose Gravel is offline
post #3 of 13 (permalink) Old 07-16-2016, 01:55 AM Thread Starter
Zev
Loose, I'm not sure what you mean...please explain.
Zev is offline
post #4 of 13 (permalink) Old 07-16-2016, 09:06 AM
WSC
Main Motorcycle: '07 Dyna Low Rider
WSC's Avatar
Other Motorcycle: '99 Legend TT
Extra Motorcycle: Thunderbolt, T150V
He just posted nonsense to get the thread back to the top of the list.
As far as I know, there is no difference between the system with both mufflers on the right and that with one on each side. Just drill through the center baffle. I have both a drilled set and a set of TOR's. I can't tell much difference between the two.
John
Laconia Bike Week 2019 - See you all next year
2007 HD FXDL
1999 Legend TT
1975 T150V, 1968 BSA Thunderbolt, x2004 Thunderbird Sport
WSC is offline
post #5 of 13 (permalink) Old 07-16-2016, 11:10 AM
Yes, I was just trying see a little more on the topic.
I've read 7/8" is the consensus for the hole size. Is that correct?
post #6 of 13 (permalink) Old 07-16-2016, 07:44 PM
WSC
WSC's Avatar
I recall that's what I did. I can check; I used a step drill and put it all the way through.
John
2007 HD FXDL
1999 Legend TT
WSC is offline
post #7 of 13 (permalink) Old 07-17-2016, 12:39 AM
Was it worth it?
post #8 of 13 (permalink) Old 07-17-2016, 01:21 AM
Main Motorcycle: 2016 Moto Guzzi Griso SE
Zebraranger's Avatar
I drilled out both exhausts on my Thunderbird and it sounded much better. The larger diameter the hole, the deeper the tone. Here's a video of what it sounds like. It was recorder with a cell phone so if you're listening on computer speakers or a cell phone, the sound quality is going to suck.
Video link: https://youtu.be/2guoxiQroqI
Zebraranger is offline
post #9 of 13 (permalink) Old 10-15-2019, 12:05 PM
Main Motorcycle: 1997 Thunderbird
slowslave's Avatar
I realise that most of those interested have done this a loooong time ago. Searching for information on bafflectomy now itís difficult to find any clear photos and the link referenced a couple of times on different threads as being full instructions no longer works. Iím trying to work out if the standard silencers (not TOR) on my 1997 Thunderbird are in stock condition. Without having anything to compare them them to, is it possible to tell wether or not they have been messed with? Have taken pictures of the insides from both front and back but itís hard to see in there. Any help would be greatly appreciated.
slowslave is offline
post #10 of 13 (permalink) Old 10-15-2019, 09:33 PM
WSC
WSC's Avatar
I don't know for sure about the Thunderbird silencers, but you cannot see straight through an unmodified TBS silencer.
If the hole is 7/8" that's about as big as you can go (at least in the TBS).
slowslave likes this.
John
2007 HD FXDL
1999 Legend TT
WSC is offline
Comparing my TBS with other T3s rohart Hinckley Classic Triples 18 06-18-2016 04:49 PM
TBS side cover removal TBSrider Hinckley Classic Triples 6 02-18-2016 10:47 AM
value of a 2004 TBS front end? simplyj Hinckley Classic Triples 19 11-05-2015 06:38 PM
TBS Bar/Riser ? ovni Hinckley Classic Triples 7 05-27-2015 11:17 PM
