The Infamous Alternator Rattle - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 10 (permalink) Old 03-11-2016, 07:35 PM Thread Starter
Main Motorcycle: 2016 Moto Guzzi Griso SE
Zebraranger's Avatar
Well my 03 TB developed the alternator rattle a couple of days ago. I was going to pull it this weekend, but was able to take off early today so I just pulled it. This is what I found. The bolt head has sheared off. I was just hoping it would be loose. I found the bolt head with about 1/4" of threads and both washers laying there. Anyone know if this can be repaired (drilled and tapped). Or, do I need to find another alternator.
Zebraranger is offline
post #2 of 10 (permalink) Old 03-11-2016, 07:58 PM
Main Motorcycle: Triumph thunderbird sport
Dimundo's Avatar
Other Motorcycle: Triumph rocket III
I had same thing. I had a machine shop get the bolt out and was able to salvage the threads.
Sent from Motorcycle.com Free App
Dimundo is offline
post #3 of 10 (permalink) Old 03-11-2016, 08:37 PM
Main Motorcycle: 1996 900 Trophy BRG
Other Motorcycle: 1998 Sprint Sport
Extra Motorcycle: 1996 1200 Trident
Hi Zebraranger,
You can fix it at home. Same thing happened to me. Use this, I think I bought it at Homedepot.
https://www.thegrabitstore.com/pages/how-to-use
greg96brg is offline
post #4 of 10 (permalink) Old 03-11-2016, 11:11 PM
WSC
Main Motorcycle: '07 Dyna Low Rider
WSC's Avatar
Other Motorcycle: '99 Legend TT
Extra Motorcycle: Thunderbolt, T150V
I bought a set of those through Groupon a while back and haven't had the dubious opportunity to use them yet.
The original bolt has a locking compound on it, so use some heat first to break the bond.
John
Laconia Bike Week 2019 - See you all next year
2007 HD FXDL
1999 Legend TT
1975 T150V, 1968 BSA Thunderbolt, x2004 Thunderbird Sport
WSC is online now
post #5 of 10 (permalink) Old 03-11-2016, 11:30 PM Thread Starter
Thanks for the links and the info, I'll get at it. Found a couple of older threads about it a little earlier today. Does anyone know if the bolt is a reverse thread?
post #6 of 10 (permalink) Old 03-12-2016, 05:55 PM
Main Motorcycle: '98 Thunderbird Sport
denny's Avatar
Other Motorcycle: '95 Tbird - Project
nope, it is a standard right hand thread.
Cheers,Denny
denny is offline
post #7 of 10 (permalink) Old 10-01-2019, 09:25 AM
Main Motorcycle: 1998 Thunderbird Sport
I am in Orlando and getting ready to do this. How hard is it and any concerns?
Jkosky is offline
post #8 of 10 (permalink) Old 10-20-2019, 11:02 PM
Main Motorcycle: 2002 Honda Valkyrie
Pappy!'s Avatar
Other Motorcycle: 1998 Honda Valkyrie
Extra Motorcycle: 2001 Triumph Adventurer
Ahhh a fellow Central Florida guy!
Pappy! is offline
post #9 of 10 (permalink) Old 10-21-2019, 01:08 AM
denny's Avatar
Here's what I did.....
Last fixed in 2010 and it's still holding.
Before I used a longer bolt I had fixed this problem 3 times with the parts supplied by Triumph.
https://www.triumphrat.net/hinckley-...ml#post3001473
This is the Image from the Parts Manual.
#17 is the hardened washer
#22 is the Bellville washer
#21 is the Bolt (clearly shows an Allen head bolt). This is where I used a 12.9 Allen head 6mm x 20mm bolt to replace the Triumph supplied part.
Cheers,Denny
denny is offline
post #10 of 10 (permalink) Old 10-23-2019, 01:17 AM
Main Motorcycle: 1997 Thunderbird
Tburd97's Avatar
Other Motorcycle: 1998 TBS
Extra Motorcycle: 2001 Tiger 955i
Wasn't there an update to the repair for this??? I've had my 97 TB for 7 years and I recall having the alternator rattle early on. From what I remember the shaft had bolts threading into it from both ends (alternator side & clutch side). When my sheared it was the bolt on the clutch side end. I believe the fix was a smooth-bore shaft with a long bolt going straight through and a washer/nut securing it.
Tburd97 is offline
Hello from the westcoast of Canada ekalbason The Welcome Center 2 04-05-2015 12:08 AM
