TBS winter project checklist and questions - Page 21 - Triumph Forum: Triumph Rat Motorcycle Forums
 111Likes
post #201 of 228 (permalink) Old 07-03-2017, 11:09 PM
Main Motorcycle: None anymore
Other Motorcycle: 1970 Yamaha XS1B
Somethin just don't seem right here! Like there is something mechanically holding the pan away? Warped pan? Bolts bottoming out or threads poorly cut? I would not expect to see that much leakage with NO gasket (except maybe on a Harley). I don't remember if the inner surface of the pan is flat, but if it is, a piece of thick glass or a polished stone countertop and some 400 grit paper will quickly tell you if it's warped AND will leave a good sealing surface.
JRobyn is offline
post #202 of 228 (permalink) Old 07-08-2017, 02:36 PM
I've been following this thread and I would suggest you change the subject to "TBS Winters Project..." 😁
2000 TBS Cafe Racer :: 2000 Frankenmille
TBSstunta is offline
post #203 of 228 (permalink) Old 07-10-2017, 02:57 PM Thread Starter
Main Motorcycle: 2004 TBS (modified)
Other Motorcycle: 1998 TBS (stock)
Extra Motorcycle: 2008 Daytona 675
took off the pan and it appears the crappy paper gasket folded a bit upon install. Chalk it up to installer error. Even so, I took the pan off my parts bike and cut a new gasket out of the aforementioned gasket material. Everything is back on the bike and oil tight at the moment.
to be fair, I did run the bike for most of last summer. 3k mostly trouble free and glorious miles before grenading the engine.
JRobyn likes this.
simplyj is offline
post #204 of 228 (permalink) Old 07-12-2017, 07:32 AM
No criticisms as I love what you've done with the bike. Just having a little fun.
simplyj likes this.
post #205 of 228 (permalink) Old 07-17-2017, 12:39 PM Thread Starter
No updates on TBS, just wanted to show off my most recent acquisition.
Sent from my iPhone using Tapatalk
BRG-BIRD, CharlieS and avu3 like this.
simplyj is offline
post #206 of 228 (permalink) Old 07-17-2017, 04:54 PM
WSC
Main Motorcycle: '07 Dyna Low Rider
WSC's Avatar
Other Motorcycle: '99 Legend TT
Extra Motorcycle: Thunderbolt, T150V
I don't see no engine... Is that one of them e-lec-tric bikes?
John
Laconia Bike Week 2019 - See you all next year
2007 HD FXDL
1999 Legend TT
1975 T150V, 1968 BSA Thunderbolt, x2004 Thunderbird Sport
WSC is online now
post #207 of 228 (permalink) Old 07-17-2017, 07:26 PM Thread Starter
Judging from the growl through those factory cf pipes, it's in there and those cosworth fellas did it right.
simplyj is offline
post #208 of 228 (permalink) Old 08-28-2017, 08:23 AM Thread Starter
Still at it with the build, slowly chipping away at the wiring. With the help of WSC, I got the rear half of the bike buttoned up and am slowly moving forward.
Current state of the bike.
Trying to get this done in the next 4 weeks for the DGR with enough time for a proper shake down. Gonna be tight
Rollinslow84, avu3 and Zee9 like this.
simplyj is offline
post #209 of 228 (permalink) Old 08-28-2017, 08:56 AM
Main Motorcycle: 2001 Triumph Thunderbird
Other Motorcycle: 1981 Honda CB 750K
Looks freaking awesome SimplyJ.
swaymix is offline
post #210 of 228 (permalink) Old 09-13-2017, 11:39 PM Thread Starter
Been plugging away on the wiring and have it about 90% done. All that's left is to run the motone switch wiring and wire in the horns and front signals. Picking up a set of woodcraft clip ons tomorrow to allow me to run the wiring through the clip ons (hollow vs the zx6r clip ons I have now).
Tonight I finished up the rest of the front end wiring which was a big PITA due to the need to have every component individually removable while also being able to hide most of the wiring. There is precious little room in the headlight bucket due to the Thruxton R headlight and heatsink for the stock led running lights, so all the plugs for the gauges and front end lighting and switches had to be hidden under the tank.
End result is I have powah!
Next up, paint. Just 10 days to go...
simplyj is offline
