TBS winter project checklist and questions - Page 15 - Triumph Forum: Triumph Rat Motorcycle Forums
 111Likes
post #141 of 228 (permalink) Old 03-08-2017, 05:45 PM
Main Motorcycle: 2006 Sprint ST
Rollinslow84's Avatar
Other Motorcycle: 1999 Legend
Extra Motorcycle: 1998 TBS 1997 Adventurer
That cylinder heads looks amazing!
Are those the Triumph valves or aftermarket stuff? Did you get any flow numbers on the head?
Rollinslow84 is offline
post #142 of 228 (permalink) Old 03-10-2017, 10:23 AM Thread Starter
Main Motorcycle: 2004 TBS (modified)
Other Motorcycle: 1998 TBS (stock)
Extra Motorcycle: 2008 Daytona 675
Those are stock valves but have been treated to a competition valve job. Sadly, no flow numbers as Joe, the owner of DWMS racing, is apparently not a fan of flow benches. The work does look flawless and once I get it all back together, I'll be heading to the dyno for final tuning and to figure out what sort of power she will be making.
simplyj is offline
post #143 of 228 (permalink) Old 03-12-2017, 06:12 PM Thread Starter
still waiting on the correct con rod bolts to come in so decided to do some more work on the rear half of the bike.
working on the rear subframe and electronics tray
drop for the battery. thanks to the subframe bracing, it's pretty much invisible from the side.
Also fitted the modified NRG tail light
Zee9 likes this.
simplyj is offline
post #144 of 228 (permalink) Old 03-12-2017, 07:13 PM
Main Motorcycle: Thunderbird sport 2000
Zee9's Avatar
What version of the NRC light did you get. As per my calculations the closest fit would be the old thruxton one. Is that it?
Zee9 is offline
post #145 of 228 (permalink) Old 03-12-2017, 09:09 PM Thread Starter
Yep, the Thruxton one. It's close but requires modifications
simplyj is offline
post #146 of 228 (permalink) Old 03-13-2017, 06:53 PM Thread Starter
decided the tail light looked unfinished just hanging off the end of the frame so I attempted to form an upper cover out of sheetmetal. I'm not going to pretend I have any skills, but it came out close enough. After some bodywork and paint, I think it'll turn out pretty good.
Also, my removable passenger peg mounts came in the mail. Not too bad for $10 shipped and I think they will work great.
I'll be welding m8 bungs into the insides of the angled supports so as to easily bolt these on when I have a pillion.
simplyj is offline
post #147 of 228 (permalink) Old 03-13-2017, 07:13 PM
Main Motorcycle: 2001 Triumph Thunderbird
Other Motorcycle: 1981 Honda CB 750K
Hey J, it may be the picture but the rear foot pegs look like they're going to interfere, or at least be very close to your chain. What bike are those pegs and mounts from? I will be attempting something similar. Cheers
Sent from my iPhone using Tapatalk
swaymix is offline
post #148 of 228 (permalink) Old 03-13-2017, 07:52 PM Thread Starter
It's the pic. The peg supports angle out and easily clear the chain. They are from an 89-99 fzr600.
edit: here's a pic illustrating the angle
simplyj is offline
post #149 of 228 (permalink) Old 03-13-2017, 08:24 PM
Got it! Thanks
swaymix is offline
post #150 of 228 (permalink) Old 03-13-2017, 08:44 PM Thread Starter
Got it! Thanks
If you're going to do this, this is the only source I found for m8 steel top hat bungs.
eBay seller: scottgfs
simplyj is offline
