TBS winter project checklist and questions - Page 14 - Triumph Forum: Triumph Rat Motorcycle Forums
 111Likes
post #131 of 228 (permalink) Old 03-06-2017, 10:26 AM
Main Motorcycle: Thunderbird sport 2000
Zee9's Avatar
Jason, any chance you have the plastic part of the rear fender lying around? I can desperately use one if you have it. The plastic part that gets riveted to the metal rear fender. Know what I mean?
Zee
2000 Triumph Thunderbird Sport
2015 BMW F700GS
Zee9 is online now
post #132 of 228 (permalink) Old 03-06-2017, 10:44 AM Thread Starter
Main Motorcycle: 2004 TBS (modified)
Other Motorcycle: 1998 TBS (stock)
Extra Motorcycle: 2008 Daytona 675
Zee
2015 BMW F700GS
I have a few of them. You're welcome to one.
Zee9 likes this.
simplyj is offline
post #133 of 228 (permalink) Old 03-06-2017, 10:56 AM
Zee9's Avatar
Sweet! I need one that holds the cylinder for the rear spring compression. I think there maybe two types as the TB and the legend don't have that on their fenders. I'll drive by someday when you're working from home.
Zee
2015 BMW F700GS
Zee9 is online now
post #134 of 228 (permalink) Old 03-06-2017, 11:09 AM Thread Starter
Zee
2015 BMW F700GS
I definitely have at least one of those.
Zee9 likes this.
simplyj is offline
post #135 of 228 (permalink) Old 03-08-2017, 10:36 AM Thread Starter
made progress on the engine rebuild. Took apart and inspected/measured the clutch plates and all were well within spec so I put it all back together with the Daytona clutch springs. Also, gapped all the rings and went to install the new con rod bolts, but came across this problem:
significantly shorter than the old bolts. Still enough threads for the nuts to thread on, but obviously different bolts. I double checked the parts numbers and everything is correct, so I'm stumped. The dealership didn't seem to know either and said "they will stretch when you torque them down." I haven't rebuilt an engine in years, but I don't recall con rod bolts stretching that much. Maybe a fraction of a mm at best.
Other than that, things are going back together pretty easy.
Another minor setback that ate up a bit of time was, having misplaced my tool for holding the alternator impeller, I had to make another. Made this one a little nicer than the last so if anyone needs this for any reason, happy to lend it out.
still stumped on those con rod bolts so would love some insight
simplyj is offline
post #136 of 228 (permalink) Old 03-08-2017, 11:40 AM
WSC
Main Motorcycle: '07 Dyna Low Rider
WSC's Avatar
Other Motorcycle: '99 Legend TT
Extra Motorcycle: Thunderbolt, T150V
When you say "Still enough threads for the nuts to thread on" do you mean the threads protrude from the other side of the nut? They need to protrude at least enough to get "full" threads engaged with the whole nut. Looks like almost 2 threads' length before you get to a full thread.
Are you using different rods from original? If so, I assume you ordered bolts to match the rods, not the original engine.
And, no, they won't stretch that much...
John
Laconia Bike Week 2018 See you next year!
2004 Thunderbird Sport
1999 Legend TT
1975 T150V, 1968 BSA Thunderbolt
WSC is offline
post #137 of 228 (permalink) Old 03-08-2017, 11:47 AM
Main Motorcycle: None anymore
Other Motorcycle: 1970 Yamaha XS1B
Since the rod big end is part of the rotating mass, and as such is factored into the engine balancing, the replacement bolts must be the same weight as the originals. That much shorter, I imagine they weigh less.
JRobyn is offline
post #138 of 228 (permalink) Old 03-08-2017, 12:11 PM Thread Starter
They do not protrude. I ordered the bolts bases on the new rods which were out of a 2000 Daytona. I did not have vin so it is a possibility that the dealer ordered for the updated motor by accident
simplyj is offline
post #139 of 228 (permalink) Old 03-08-2017, 12:34 PM
WSC
WSC's Avatar
DON'T USE THEM!!!!! There should be at least 1 complete thread protruding.
John
1999 Legend TT
WSC is offline
post #140 of 228 (permalink) Old 03-08-2017, 12:55 PM Thread Starter
Glad I asked. Definitely not planning on using them now. F that dealership I ordered the parts from. Looks like it should have been part number 1110060
simplyj is offline
