TBS winter project checklist and questions - Page 11 - Triumph Forum: Triumph Rat Motorcycle Forums
 111Likes
post #101 of 228 (permalink) Old 05-06-2016, 06:40 PM Thread Starter
Main Motorcycle: 2004 TBS (modified)
Other Motorcycle: 1998 TBS (stock)
Extra Motorcycle: 2008 Daytona 675
Whipped up an upper fairing bracket using a spare stem nut I got from Bsgrimes, a threaded ball joint I picked up from Grainger, and some 1/4" aluminum rod I bent up and threaded.
mocking it up with some trusty bendy straws:
and now in aluminum:
I'm going to powder coat the stem nut and ball joint to make them blend in better but overall pretty happy with the result as the fairing is rock solid now.
IrlMike, ArferBrick, Zee9 and 1 others like this.
simplyj is offline
post #102 of 228 (permalink) Old 05-15-2016, 11:28 PM Thread Starter
Per my other thread, installed new plugs, swapped coils for tt600 units and reprogrammed the ignitech per IRLmike and closteaus recommendations. Bike starts better (although still not perfect) but runs like a champ.
Took her out on a nice long ride up to the mountains with some friends, and even 2up had plenty of power and felt great in the twisties. The suspension soaks up bumps and the bike gives confidence in the corners. Braking too is significantly improved. My girlfriend, who had been a passenger numerous times on the bike prior to the mods, kept on referring to this as the "new bike," forgetting completely that it is the same bike.
I had been worried about the riding position with the clip ons, but happy to say that even after over 5hrs, my wrists and back are fine. Sadly, can't say the same for my neck since I keep on forgetting to take my scorpion helmet out of storage and once again had to ride with my hipster special which has the aerodynamics of a brick.
Still a few little issues to work out. My speed reading went out halfway through the ride so have to check that connection. Also need to figure out an iPhone mount and wire in my USB port.
Overall, even with the small issues that need to be worked out, I'm extremely happy with how the bike turned out. Like my girlfriend mistakenly thinks, it really does seem like a whole new bike and certainly a keeper. I'm looking forward to a lot of miles together and already planning some road trips for the summer.
Size:  68.8 KBName:  ImageUploadedByMotorcycle1463369286.683749.jpg
IrlMike likes this.
simplyj is offline
post #103 of 228 (permalink) Old 01-08-2017, 06:44 PM Thread Starter
guess I should update this thread even though I've started several others on various topics pertaining to the build. As per my several other threads, the TBS suffered a blown head gasket so will be getting treated to a rebuild to 955 specs and some other upgrades. Due to other projects and family issues, I haven't touched it since mid September, but figured I needed to get a move on it if I want to get it squared away by the spring.
A few months back, I picked up a 955i parts engine and finally got it torn down and the pistons and liners removed. Looks like a coolant leak caused some bearing wear and corrosion in the coolant passages. The pistons, rods, and liners are in good shape with little wear but the liners were a real bitch to remove. Used a tool made from several 3" PVC test plugs, a carriage bolt, and a scrap of 2x4 to remove the plugs. Cost about $15 vs the $250 for the Triumph tool. Due to ton of gunk around the liners, they were very frustrating to get out. I can't explain to you the joy I felt when that first one popped up.
started cleaning up the pistons
got the carbon off and inspected the ring journals for wear
Also, picked up some other parts for the build:
CBR1000rr Tokico monobloc calipers
NRC tail light
Daytona 3-1 header
Now I need to remove and tear down the 885 engine, inspect the crankshaft and get the measurements for the correct color code replacement bearings then get the upper crankcase to the machine shop to accept the 955 liners.
IrlMike, avu3, Zee9 and 2 others like this.
simplyj is offline
post #104 of 228 (permalink) Old 01-15-2017, 06:27 PM Thread Starter
started tearing apart the bike to drop the engine. Oil and coolant drained and most accessories taken off and pretty much ready to be dropped tomorrow and blown apart.
Sean Patrick and bsgrimes like this.
simplyj is offline
post #105 of 228 (permalink) Old 01-16-2017, 05:14 PM Thread Starter
got the motor torn down today. Was pretty worried what I'd find as I started tearing it down.
Valve cover off and looks good. Followed the factory manual sequence and everything came apart easily
once the head came off, things started looking much worse.
Sludgecity, pop: ME
cases separated and crank removed. Looking like a complete mess at this point, but all bolts were bagged and tagged or placed into cardboard templates
Where it stands now.
simplyj is offline
post #106 of 228 (permalink) Old 01-22-2017, 09:21 PM Thread Starter
Head boxed up and on its way to Joe at DWMS racing. After working it through with Joe, I decided to stick with stock valve sizes so the head will be getting: porting the intake and exhaust ports, opening and port
matching the valve seats, cleaning the combustion chambers, polishing the valves, and a competition valve job.
I'll be getting a custom Cometic head gasket at a to be determined thickness (depending on whether the head has to be milled at all).
Scored a deal on a rack of gsxr FCR39's at almost $500 less than a new rack from Sudco. Spacing is very similar to the TBS and I think I can lob off a bank and mess with the spacing to get it right. If not, at the price I got it, I can easily sell on eBay.
simplyj is offline
post #107 of 228 (permalink) Old 02-02-2017, 10:30 PM Thread Starter
My used rack of Keihin FCR 39s finally arrived. I picked up the set of 4 for just under $600 shipped figuring that it'd be worth a shot trying to rerack them to 3 and hopefully saving about $500 off the price of a new set of 3. They just arrived tonight so I only had time to take a few measurements and start tearing them down to see how hard it will be to rerack. So far it doesn't look like it'll be too much trouble at all.
For those who are considering doing this in the future, here are some measurements and comparisons:
spacing isn't too far off
simplyj is offline
post #108 of 228 (permalink) Old 02-02-2017, 11:15 PM
Main Motorcycle: 2012 Tiger XC
CharlieS's Avatar
Other Motorcycle: My RED '02 Sprint ST
Extra Motorcycle: 99 Thunderbird Sport
That's a good find. It looks like, to me, that the carb rubbers might take care of the difference. What year and model did you get those carbs off of?
Stay safe out there,
---Charlie
---Charlie
CharlieS is offline
post #109 of 228 (permalink) Old 02-03-2017, 01:02 AM Thread Starter
Set of four off a Bandit 1200
simplyj is offline
post #110 of 228 (permalink) Old 02-03-2017, 01:26 PM
CharlieS's Avatar
Going by your pics, the FCR's are 40mm?
---Charlie
CharlieS is offline
