Alternate front master cylinder and rebuild kit - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
post #1 of 12 (permalink) Old 07-11-2015, 06:42 PM Thread Starter
Main Motorcycle: 2006 Sprint ST
Rollinslow84's Avatar
Other Motorcycle: 1999 Legend
Extra Motorcycle: 1998 TBS 1997 Adventurer
I located an alternate, non-Triumph front brake master cylinder and rebuild kit. This is for the single disk bikes with 11mm front master size. I measured the Triumph and Honda bits, I am 99% sure these Honda kit will work on the Triumph unit. Below are pictures of the components and measured sizes. I used a Mitutoyo ABSOLUTE 500 series caliper, I literately trust this caliper with my life
This unit is manufactured by Nissin, same supplier as the original Triumph part. There are several external differences but the inner workings are the same. Fitting to bike was not an issue, the front brake lever looks like the original Triumph parts but is slightly different. I'm working on modifying the cheap chrome adjustable levers I have installed.
Honda part number for master assembly is 45510-MGF-305
Honda part number for rebuild kit is 45530-MN9-305
The rebuild kit is half the cost of the one sold by Triumph and readily available at my local Honda shop.
Triumph measurements:
Honda on top, Triumph on bottom
Honda measurements:
Benefits to having the Honda unit, I can see the fluid level while bleeding the brake, rather than getting up and going around the bike to look. There is a small shield installed in the reservoir that keeps the fluid from squirting out while bleeding, no need to re-install the cover while bleeding. Very helpful!
Why did I go this route? My original unit was damaged beyond repair. All the correct ones I found for sale on eBay were damaged and pretty expensive. The used Honda unit with low miles and lever was very cheap (37$ shipped) and in great condition. I took a gamble and it seems to have paid off. The main take away here is that the Honda rebuild kit will work with the Triumph unit and it's half the cost of the Triumph rebuild kit.
Any questions?
He who dies with the most toys wins!
Triples Only
Rollinslow84 is offline
post #2 of 12 (permalink) Old 07-12-2015, 04:21 AM
Main Motorcycle: KTM 1290 Super Adventure
ArferBrick's Avatar
Other Motorcycle: '96 Adventurer
Nice one Rollins, and thanks for the pics and info . Don't know how I missed this thread!
Does the Honda have a matching clutch master? I don't think I could live with two different parts on my bike - I'd be constantly looking at them grinding my teeth .
EU politicians have just been informed that breathing air leads to certain death in 100% of all cases and are working hard to find a way to ban breathing in order to protect all EU citizens.
ArferBrick is offline
post #3 of 12 (permalink) Old 07-12-2015, 04:57 AM
Main Motorcycle: TBS
NeilD's Avatar
same here, had to change the clutch one as well when i went to a square 5/8 brake for the 4 pot brembos
nice bit of research Rollins.. is the brake light switch the same ?
NeilD is offline
post #4 of 12 (permalink) Old 07-12-2015, 11:31 AM Thread Starter
There is a matching Honda unit that might be used for the clutch but it is a 1/2" size bore. The Silverwing is a touring scooter and the rear brakes are on the left hand handlebar controls. Our original clutch master is 14mm. If I find one cheap enough ill buy it and try it out.
The brake light switch is basically the same. The mounting is the same but the Honda piece has the terminals slightly farther apart (no issue) and the body is a little bit longer. I'm using the Triumph switch because it works and I wanted to preserve the low mileage Honda switch.
Up next for research will be the Honda brake caliper seal fitment.
Triples Only
post #5 of 12 (permalink) Old 07-12-2015, 02:34 PM
Main Motorcycle: Tb Classic '96
Blackbird's Avatar
Other Motorcycle: Someday...
Blackbird is offline
post #6 of 12 (permalink) Old 07-12-2015, 02:57 PM
ArferBrick's Avatar
I just ordered this one from a mob called "Square deals online Triumph Emporium" in England -
http://www.squaredeals-ltd.co.uk/thu...kit-6845-p.asp
I believe it's the Tourmax MSB-108 kit, but I'll know for sure once it arrives. They state that it's Tourmax but not which part number.
They also offer an original "Triumph" master cylinder overhaul kit for twice the price.
It's not a bad find actually, they have lots of interesting stuff for our bikes, I also ordered a few other replacement parts for the front caliper and a seal overhaul kit. The whole order came out cheaper than the what it would have cost for just the original M/C kit if I'd ordered it from my usual source.
They also list a Billet 6-pot that also comes with a TÜV certificate! Quite pricey at 350 quid, but it might be an option for someone over here who wants to (legally) update their front brake.
post #7 of 12 (permalink) Old 07-12-2015, 04:41 PM Thread Starter
Glad I can help. I'm not a cheapskate I have four bikes I ride hard and need to maintain I save money where I can
The Triumph unit as you can see based in the measurements was wore in pretty good. I don't have the service limits in front of me but the Honda unit is working much better. Rock solid brake lever! going to give it a week and bleed it again. The 1997 Triumph unit had 13,000 miles on it and a hard firm lever only lasted a day after bleeding.
Triples Only
post #8 of 12 (permalink) Old 07-12-2015, 04:43 PM Thread Starter
What are the details on that part number?
Who makes it?
How will it help us?
Triples Only
post #9 of 12 (permalink) Old 07-12-2015, 05:46 PM
Blackbird's Avatar
Who makes it?
That's the Hond part number for the 14mm clutch master cylinder repair kit. Looks genuine Honda part to me.
There are cheaper alternatives such as Tourmax MSC-101. That's the one what use when I rebuild my master cylinder.
Sorry for the confusion. Maybe I should have been more informative.
Blackbird has spoken...
post #10 of 12 (permalink) Old 03-15-2017, 06:42 PM
Main Motorcycle: 08 t100
Other Motorcycle: 08 Thruxton
Extra Motorcycle: 72 Norton comando
[QUOTE=Rollinslow84;6644946]I located an alternate, non-Triumph front brake master cylinder and rebuild kit. This is for the single disk bikes with 11mm front master size. I measured the Triumph and Honda bits, I am 99% sure these Honda kit will work
Now you can be 100% sure. I just installed the honda kit in my 08 T100 front M/C, perfect fit. THANKS for your post.
R.
JRobyn likes this.
rweb is offline
Japanese alternative to Triumph master cyl rebuild kit? Forty2 Sprint Forum 2 05-18-2015 01:40 PM
Stainless steel master cylinder htown16 Classic, Vintage & Veteran 2 03-02-2015 09:17 PM
Bonnie Master Cylinder Rebuild Kit OldTownerVA Air Cooled Twins Technical Talk 1 02-01-2015 05:02 PM
