Muffler Options for 3 into 2? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 6 (permalink) Old 07-09-2015, 07:45 AM Thread Starter
Main Motorcycle: 2007 KTM 950 Supermoto
Muffler Options for newer tbs?
Seems kinda sacriledge around here to even suggest, but I did buy some headers to possibly replace my 3 into 2 '99 stock, right side stacked exhaust with the left/right split. Don't get me wrong, I love'em both but I've always been a kind of dual pipe guy on bikes. Couple questions.
First, has anyone done this before and is mounting the muff on the left side a big deal for my older tbs?
Next and primarily, these newer tbs models seem to use the longer (not reverse cone) mufflers. What are some good options as far as these go?
Last edited by loutriumph; 07-09-2015 at 10:52 AM. Reason: Change to appropriate title
loutriumph is offline
post #2 of 6 (permalink) Old 07-09-2015, 07:08 PM
Main Motorcycle: 2006 Sprint ST
Rollinslow84's Avatar
Other Motorcycle: 1999 Legend
Extra Motorcycle: 1998 TBS 1997 Adventurer
I haven't done this to my TBS but a few notes on what you'll have to deal with.
The 1998-1999 TBS rear pegs are higher than all of the other models. The Legend/Thunderbird/Adventurer exhaust mounts for the mufflers are lower, the difference is in the subframe.
The original Legend/Thunderbird/Adventurer pipes would be your best option, but you would have to make some brackets to attach the mufflers to the subframe.
I can't recommend any aftermarket replacement chrome finish mufflers. In my opinion from what I've seen the chrome finish will not last, and is not a deep finish. What I recently did to one of my bikes was install a header from a Sprint and mufflers from a newer model Thruxton. I am extremely pleased with the result, looks good and sounds great.
If you are considering selling your stock TBS exhaust consider me first in line
He who dies with the most toys wins!
Triples Only
Rollinslow84 is offline
post #3 of 6 (permalink) Old 07-09-2015, 07:29 PM
gbc
Main Motorcycle: Rocket 3
gbc's Avatar
Other Motorcycle: 2014 Moto Guzzi Calf.
Extra Motorcycle: 1999 Triumph Adventurer
It can be done
Stock TBS headers for double sided year, muffler mounting brackets again from a double sided model, and muffler conversion adapters for the newer twins to mount old style exhaust. Walla, dual exhaust. I switch back and forth between my EPCO's (which I understand are no longer available) and 3 into 3 D&D's. Since my "Bumble Bee" never had the stock one sided system I decided to experiment.........
gbc is online now
post #4 of 6 (permalink) Old 07-10-2015, 07:05 AM Thread Starter
Thanks for the info, guys.
GBC, I like what you've done there with yours. I assume, however, I could mount them lower and similar to later stock tbs if I had an extended muffler hanger from the passenger pegs?
post #5 of 6 (permalink) Old 07-11-2015, 09:30 AM
gbc
gbc's Avatar
Absolutely, regardless the procedure is going to require some fabrication, good luck.......
George
gbc is online now
post #6 of 6 (permalink) Old 07-11-2015, 06:57 PM
Main Motorcycle: ThunderBird Sport
Jmac103's Avatar
Other Motorcycle: KTM 320SXF/XCF
Extra Motorcycle: Yamaha TTR125
I recently purchased a set of stock headers that do the left/right split. I decided to keep my tbird sport 2 on one side after all. I'm looking to sell the headers if you're interested.
Jmac103 is offline
Rearset options for 78 T140V Smoedog Classic, Vintage & Veteran 10 04-05-2017 09:08 AM
accessory muffler for Boneeville T100 mpmike Air Cooled Twins Talk 75 11-22-2015 03:54 PM
What cargo options have you tried? LiveOakForest Street Triple Forum 6 04-24-2015 07:27 PM
Accessory muffler for bonnevilke T100 mpmike The Welcome Center 2 03-28-2015 09:25 AM
