Bar end mirrors? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 30 (permalink) Old 03-07-2012, 02:52 PM Thread Starter
Main Motorcycle: Legend TT
Bar end mirrors?
Hi all.
I'm after some bar end mirrors for my Legend. I'm having trouble sourcing some that actually fit due to the threaded handlebars.
Has anybody got any reccomendations or know of any that fit without any problems??
Many thanks
Gaffy is offline
post #2 of 30 (permalink) Old 03-07-2012, 08:18 PM
Main Motorcycle: 2008 Triumph Rocket III
Shadowofleaves's Avatar
Other Motorcycle: 2014 Triumph America LT
Extra Motorcycle: 2001 Triumph Thunderbird
I swapped my stock bars for a set from a 2006 Speed Triple (around $20 on ebay) and went with the Triumph-branded Speed Triple bar end mirrors (they look just like Rizomas and cost around $100 on ebay but copies can be had for about half that). I had to slightly modify the switch housings to work with the new bars, but I think they worked out pretty well.
Shadowofleaves is offline
post #3 of 30 (permalink) Old 03-09-2012, 08:22 AM
Main Motorcycle: TBS
NeilD's Avatar
I just used a longer screw and screwed the mirror direct to the threaded bit of the bar without using any barend..
P1010984c by GUZZINEIL, on Flickr
NeilD is offline
post #4 of 30 (permalink) Old 03-09-2012, 12:07 PM
Main Motorcycle: '04 Thunderbird Sport
Wombat's Avatar
Other Motorcycle: I wish!
I have Napoleon mirrors on my TBS and to get them to fit snuggly, I removed the expanding rubber bit.
I then cut a small sleeve from a copper water pipe fitting to fit over the part that fits inside the bar to stabilize it and used a 5mm hex head bolt into the existing threaded plate.
You will find that the OD of the copper pipe is the same size as the ID of the bars.
From memory, the length of the copper sleeve was 10 mm.
No modifying of mirrors or bars required.
Bob
:AustralianFlag
Click to see My Photo Album
Age is of no importance, unless you are a cheese.
Wombat is offline
post #5 of 30 (permalink) Old 03-10-2012, 11:14 AM Thread Starter
Thanks guys, some good ideas.
I'm looking at possibly mounting the original mirror heads on, using a home made bracket.
I think Halycon do a set but £85
Gaffy is offline
post #6 of 30 (permalink) Old 03-10-2012, 12:06 PM
Main Motorcycle: 2013 Triumph T100
Kem770's Avatar
Location: Nestled in the heart of America and the Loess Hill
Other Motorcycle: 1978 Yamaha DT400
Extra Motorcycle: 2003 Honda Metropolitan
I installed Norman Hyde m-bars and a Speed Triple mirror.
Kem
I'm no gynecologist, but I'll take a look.
Kem770 is offline
post #7 of 30 (permalink) Old 03-18-2012, 11:46 AM
Main Motorcycle: Triumph Thunderbird Sport
This may be an obvious question but what are you guys doing with the hole where your stock mirrors attached? I thought about bar end mirrors but I didn't like the look of the empty hole on my handlebars.
stevefarra is offline
post #8 of 30 (permalink) Old 03-18-2012, 02:24 PM
NeilD's Avatar
rubber blanking grommet
NeilD is offline
post #9 of 30 (permalink) Old 03-18-2012, 04:58 PM
Main Motorcycle: 2012 800 Tiger
lovecuba's Avatar
Other Motorcycle: 1977 T140
Bar End Mirrors
How mine are fitted on OEM TBS bars-
lovecuba is offline
post #10 of 30 (permalink) Old 03-18-2012, 07:09 PM
Puff98TBS's Avatar
I went to my local hardware store and purchased some black plastic caps that fit into the holes nicely.
98 TBS, Green Cams, D&D 3 into 3, 180 Rear Tire, Ballistic Battery, Nology Coils & Hotwires, Pingel Fuel Valve, Factory Pro Jet Kit, Factory Pro Ignition Advance, K&N Pods, Brisk Silver Racing Plugs, HEL Performance Brake Lines, Ohlins Fork Springs.
Puff98TBS is offline
Replacing FActory Bar-End Mirrors w/ Factory Lollipop Mirrors bluesman77 Club Cafe' 0 02-27-2012 03:43 PM
Link for the homemade bar end mirrors from stock mirrors? cf04thruxton Club Cafe' 13 06-17-2008 09:04 AM
Bar End Mirrors Anchorbend Air Cooled Twins Talk 3 04-08-2006 07:38 AM
mirrors Rube Air Cooled Twins Talk 4 03-28-2006 07:39 AM
