ever remove item from fuel tank? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 11 (permalink) Old 04-02-2010, 07:54 AM Thread Starter
Main Motorcycle: 99 Legend
jwolf's Avatar
Pulling the empty fuel tank off for some maintainence, I heard a rattling from inside. As I moved the tank, it seemed to roll around on the inside.
Removing the fuel tap, I discovered the filter on the tap was no longer there.
I've spent quality time trying to get that thing to a point where I could remove it from the fuel tap hole or even the fuel filler opening, with no success. Yet to even see or feel it.
Anyone have a bright idea???
jwolf is offline
post #2 of 11 (permalink) Old 04-02-2010, 08:06 AM
Main Motorcycle: MV 750 Sport 1972
Other Motorcycle: tiger 1050
Extra Motorcycle: Moto Guzzi Falcone
I had a similar problem some years back. Inside the tank was a transponder, from a Datatag anti-theft system, which I needed to remove. This thing was the size of an aspirin, and no amount of shaking would get it out! I eventually got it out using one of those long, springy things, with a 4 fingered claw at one end, and a spring loaded plunger at the other. It is a useful bit of kit. Most toolshops sell them.
M.Guy.Vig. is offline
post #3 of 11 (permalink) Old 04-02-2010, 12:50 PM
Slinky's Avatar
Other Motorcycle: Down to my last one
Get a long piece of stiff wire, like a coat hanger. Put a bend in one end, mould a blob of blue-tac or similar to the bent end, and go fishing.
'98 Thunderbird
Slinky is offline
post #4 of 11 (permalink) Old 04-02-2010, 02:49 PM
Main Motorcycle: 96 Bird
Other Motorcycle: 97 BMW R850R
Extra Motorcycle: 71 Bonnie
man I just had to grin when I saw this...I came up with the bright idea of filling my tank with pea gravel...the strapping it to a vibrating tumbler at my work place..to clean the inside..well the inside is clean ...but.....what a pain to get them all out..took a while plus a few years out of my back lol .....anyway isent that lil screen metalic?....maybe a small magnet of the telescoping type?....just a thought.....
its not leaking oil!!...its marking its spot!!!
tnsen is offline
post #5 of 11 (permalink) Old 04-02-2010, 03:40 PM Thread Starter
jwolf's Avatar
Glad to know I'm not the only one who has faced this.
The fuel tap filter has no metal on it. Darn!
The problem is mostly that while I can hear it rolling around, I can't see it.
Not sure whether to attack the problem from the fuel tap opening or the filler tube.
I like the idea of the 4 pronged claw.
Kind of worried that the blue-tac glob may come off of a coat hanger and double my problem.
That's okay, I need creative input.
Right now my back is so bad that I need to get a little relief before trying again, so different ideas are still being accepted.
jwolf is offline
post #6 of 11 (permalink) Old 04-04-2010, 11:51 PM
Main Motorcycle: my 1995 Triumph Tiger
ssevy's Avatar
Other Motorcycle: 1999 Triumph Legend
I have used an air hose from my compressor with no attachment screwed on the end for this sort of headache. Turn the tank upside down, put the hose up inside and open the air valve at the air tank. Some shaking and moving the hose around will usually do the trick. You could also fill the tank with water, shake it a bit upside down (with the cap on) to suspend the object, and then remove the gas cap to let the water rush out, hopefully with the object still suspended. Good luck - don't you just love these oddball headaches!
ssevy is offline
post #7 of 11 (permalink) Old 04-05-2010, 07:43 AM
Main Motorcycle: 1996 Thunderbird "Nessie"
cafetbird's Avatar
Other Motorcycle: 1973 Trump TR7RV "Loosie"
Extra Motorcycle: 1996 Triumph Super III
Actually, there is metal in it, just not ferrous metal. It will require some meddle.
Scot Dail, IBA #31553; 59 Club #29906
"Thunderbirds are GOOOOOOOO!"
cafetbird is offline
post #8 of 11 (permalink) Old 04-05-2010, 10:26 AM
Main Motorcycle: 01 Legend TT
Gone Cat's Avatar
Other Motorcycle: '74 Yamaha TX500A
Extra Motorcycle: 1965 Honda Sport 50
What's wrong with just ignoring it? Otherwise, if it was installed from the bottom it should be extractable from the bottom. flashlight? hemostat? needle nose pliers?, patience.?
It's not what you look like when you're doin' what you're doin', It's what you're doin' when you're doin' what you look like you're doin.
from 1970 song "Express Yourself" by Charles Wright and the Watts 103rd Street Rhythm band.
Gone Cat is offline
post #9 of 11 (permalink) Old 04-12-2010, 07:37 PM Thread Starter
jwolf's Avatar
Happy Ending!
Thanks for the creative ideas.
I could have let the fuel tap filter float around inside without issue indefinitly, but I like to have my bike as it should be.
I purchased a four pronged claw from home depot for about nine bucks. It had a built in light on the claw end that made all the difference. I rotated the tank around for about ten minutes before getting the filter to stop in a position where it could be seen with the light on the end of the claw.
Out she came, on the first try.
Nine dollars well spent in my book.
Maybe now I canget around to actually riding.
jwolf is offline
post #10 of 11 (permalink) Old 04-13-2010, 09:14 PM
Main Motorcycle: 1998 TBS
Other Motorcycle: sold it
Extra Motorcycle: sold it
I love the "fill it with water and flush it out" idea. I don't think I would have thought of that if I had a similar problem. I shall file that idea away for future use, as I think it would be most likely for success. It might take a couple of tries, but water is cheap.
Thunderbum is offline
How do you remove the gas tank? skygodmatt Speed Triple Forum 8 08-21-2014 01:08 PM
Remove tank Mattybee Tiger Workshop (archive) 8 11-23-2009 07:47 AM
why does my fuel still leak when i remove my tank? littlewhitewabbit Speed Triple Forum 31 10-27-2009 07:10 PM
Do these fuel tanks remove the same way? roady03 Hinckley Classic Triples 8 03-31-2008 08:04 PM
Sprint ST Fuel Line Question (fuel tank to/from fuel rail) Sprint Forum 7 01-26-2005 09:23 AM
