Mag/cast Wheels To Replace Spoked - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 15 (permalink) Old 07-05-2009, 09:50 PM Thread Starter
Main Motorcycle: TRIUMPH 2000 SPRINT ST
TRUMPYJEFF's Avatar
Other Motorcycle: TRIUMPH 1977 T140V
Extra Motorcycle: TRIUMPH 1961 6T
Gday all, looked through heavily modded classics, the Suzuki Hayabusa wheels seem to be the easiest to slot in with minimal modification.
Im looking for front & rear cast/mag wheels to slot into the existing stock 2000 thunderbird swingarm & forks.
Ive fitted a sidecar to my tbird & the engineer recommends fitting a mag rear wheel. If Im going to do that, I might aswell change front & rear to suit.
This topic has probably been covered somewhere- apologies for not finding it.......regards jeff
IN TIMES OF PEACE, PREPARE FOR WAR!!
TRUMPYJEFF is offline
post #2 of 15 (permalink) Old 07-05-2009, 09:59 PM
Main Motorcycle: '98 Thunderbird Sport
denny's Avatar
Other Motorcycle: '95 Tbird - Project
Some searches for ZZR, ZRX, Kawasaki wheels should reveal some of the old threads about this.
The Kawasaki conversion seems to be the most popular.
Cheers,Denny
denny is online now
post #3 of 15 (permalink) Old 07-05-2009, 10:35 PM Thread Starter
TRUMPYJEFF's Avatar
Thanks Denny, checked out the kawasaki wheels link, nice wheels. But all I need is a cast rear wheel to slot in-
Id prefer something not far from t bird size. The trident or trophy 900or 2 sided swing arm wheel from early 900 sprint??
Its not for looks or sporting performance, purely to replace a spoked rear wheel with a cast wheel for strength.
I'll leave the front spoked, as I dont want be changing whole front ends or fork legs & calipers, rotors etc.
Never driven a car & the tbird is my only transport currently, so I dont have months to play with various bits, a weekend maybe.
Will look at the models above & see if i can source something from a wrecker.
Any thoughts or suggestions much appreciated. regards jeff
post #4 of 15 (permalink) Old 07-06-2009, 10:47 AM
denny's Avatar
A rear from one of the T3 Sprint, Trophy, Daytona, etc. is probably the easiest. The spacers need to be cut down. The rear brake needs to be changed. If you source all of those parts from a Trophy I think that works pretty good.
The difference is... The sport bikes used a smaller rotor on the rear. Some of the sport bikes use an underslung brake, and that is not compatible with the TBird swingarm.
Some have had a larger rotor made to fit the Cast wheel.
I've not done this so I don't know a lot about the details.
Unfortunately the TBird rotors don't fit the cast wheels.
Cheers,Denny
denny is online now
post #5 of 15 (permalink) Old 07-06-2009, 11:53 AM
Main Motorcycle: Well, Duh!
MickMaguire's Avatar
The process / challenges are exactly the same for a Kawasaki wheel
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
MickMaguire is offline
post #6 of 15 (permalink) Old 07-07-2009, 12:52 AM Thread Starter
TRUMPYJEFF's Avatar
Thanks Mick & Denny-
to sum it all up-
Id need a whole swing arm, caliper, wheel & rotor...............change the whole ass end.
The sidecar people have 15 inch car wheels to slot in, which in the long run will be the way to go. When I want to ride the tbird solo, will have to change the rear wheel aswell as unhook the chair. Only another 20 minutes or so.
A daytona sports tyre or similar, will chew up pretty quick on the rear of an outfit. The kawasaki rims do look awesome, very similar to the rims I had on my 2001 955 sprint st.
But I just needed to know my options & weigh up- practicality vs time vs money vs effort. Thanks a million for your input, ride safe, regards jeff
post #7 of 15 (permalink) Old 07-07-2009, 08:42 AM
Unless the sidecar rig actually requires a different swing arm you don't need one. The ZZR or Triumph T3 sports wheel will go straight into the TBird swing arm and will run on the TBird axle. As Denny pointed out you will need to modify the rear brake. There are two options here
1. Swap to a over the swing arm style Trophy / Sprint rear caliper/ perch and brake arm - this will allow you to use the smaller Kwak or Trump rear rotor.
2. For the T3 rear wheel only - Contact Triumphant or Sprint in the UK as one or the other of those (I don't remember who) used to supply a custom rotor which would allow you to use the Tbird rear brake with the T3 mag wheel. IIRC Triumphrat member Saigon5 fitted one.
Mick...
post #8 of 15 (permalink) Old 07-07-2009, 02:40 PM
denny's Avatar
Vonbons also went with the custom rotor.
So he will remember where he sourced that.
Cheers,Denny
denny is online now
post #9 of 15 (permalink) Old 07-08-2009, 01:26 AM Thread Starter
TRUMPYJEFF's Avatar
Cheers again Mick & Denny, you guys rock.
Just checked out "TRIUMPHANT" website- specialise in mag wheel conversions, including rotors to suit it.
They have a dedicated thunderbird section. Lots of tasty customs etc.
Big Grin, from ear to ear jeff.
post #10 of 15 (permalink) Old 07-09-2009, 01:40 PM
Main Motorcycle: '04 Thunderbird
Other Motorcycle: 1998 Honda CBR1100XX
I swapped my TBird wheels (I have the TBS front end) for a set of Daytona wheels.
The rear is a straightforward bolt up job, but you need the early type 'above the disk' caliper, caliper mount, brake disk and torque arm.
The front end is more involved - I had to machine a spacer for the front wheel to fit the TBS forks and use Daytona disks. If I hadn't already got the TBS front end, I'd just have swapped out the whole lot for a complete Daytona front end.
I sourced most of the bits on eBay - but it took a while to find them all at a sensible price.
Jodel is offline
sealed spoked wheels Bbogie Hinckley Classic Triples 21 10-14-2012 09:41 PM
spoked or cast wheels tiger666 Tiger Chat 5 07-04-2009 11:04 AM
Difference in handling between cast/spoked Bonnies Icehawk Air Cooled Twins Talk 26 05-03-2009 11:19 PM
Cast Wheels rinkydink Club Cafe' 23 04-08-2009 06:20 PM
Cast wheels for the TB? Sprintster Hinckley Classic Triples 2 06-30-2005 11:08 AM
