Gazebox Foldable Cover System - Triumph Forum: Triumph Rat Motorcycle Forums
General News General news that doesn't make the Home Page or has been superseded on the Home Page.
post #1 of 1 (permalink) Old 12-17-2018, 04:52 PM Thread Starter
Sponsored Editorial Content
Itís on rainy, cold nights like this one that Iím glad I have a garage. Looking at your motorcycle parked outside as itís pelted with rain, sleet, hail, mud and other unpleasantness can make you weep with impotent rage. Cover it? Motorcycle covers are a hassle to put on and remove. First, you have to wait until the bike cools to avoid melting the cover to the exhaust. Plus, they can blow off your bike, get shredded and messy-looking, and trap moisture underneath, which can cause rust and mold. Nasty!
Meet Gazebox (say ďgah-ZEE-boxĒ). Itís basically a giant, folding box for your motorcycle. An easily installed modular garage system, itís a revolutionary way to store your motorcycle, car or other equipment. The unique design means your ride will be better protected from heat, cold, theft and punishing UV radiation, even without a garage or indoor storage space. Thereís no need to apply for building permits, as Gazebox is a temporary, easily moveable structure, so meddling neighbors canít object if you put it up in your driveway or sideyard. All you need is the space where you regularly keep your motorcycle, and Gazebox will Ėliterally Ėhave you covered.
Read More
Motorcycle.com is offline
Rob's (SnakeOil) 1966 T120R resto Snakeoil Member's Restoration & Rebuild Projects 515 11-02-2017 05:21 AM
Torque Setting List zucchina Water Cooled Twins Talk 4 05-10-2017 11:09 PM
Half Cover / Sun Cover vs Full Cover - Impressions JPTL Sprint Forum 0 04-21-2013 10:58 AM
Oil leak clutch Cover 2003 S3 Tobycatz Speed Triple Forum 6 10-01-2012 04:10 AM
ABS Brake System Bleed Procedure champ87 ECM and FI Tuning - Help, Tips & Tricks 1 03-04-2011 01:02 PM
