another tuneECU problem - Triumph Forum: Triumph Rat Motorcycle Forums
ECM and FI Tuning - Help, Tips & Tricks We invite members from across TriumphRat.net to post your questions, or share your expertise or experiences on TuneBoy, TuneECU and PowerCommander (etc).
post #1 of 9 (permalink) Old 01-06-2019, 07:42 AM Thread Starter
Main Motorcycle: Sprint ST 1050
Hi, I've had an intermittent problem for ages that is getting worse. I can only rarely make a successful connection and when I do, it doesn't always last. Often the connection light just flashes red a few times. Sometimes it speeds up and turns orange.
I've only just found a logging output! Which repeats the following..
Initialisation... ECU connected
Authentication... Access allowed
ECU identification
ECU type 2002-01
Initialisation.......
Etc
I've tried connecting a second battery (car, not running) to keep the voltage good, I always disconnect the lights to avoid any drain. I've checked fuses, relays, all the connections and writes i can think of for breaks. Damage etc
Can anyone help? I did post ages ago in the garage section but thought maybe this was a better place on reflection, apologies for posting twice with the same issue!
Nevstah is offline
post #2 of 9 (permalink) Old 03-25-2019, 11:44 AM
Main Motorcycle: '03 Speed Triple
rles's Avatar
have you followed all instructions? https://www.triumphrat.net/ecm-and-f...tallation.html
maybe your laptop is still connected to your wifi? that's where i went wrong...
is your laptop contantly connected to power?
rles is offline
post #3 of 9 (permalink) Old 05-16-2019, 03:55 AM
Main Motorcycle: Speed Triple 2006
Nobby15's Avatar
I had an issue with not being able to read or write a new map to my 2006 S3. I had previously been able to change maps using a Samsung S7 via cable. Now for some reason i can connect to the ECU but that's it. Also tried a Samsung S10, still not go. I'll have to try with a laptop i guess. Anyone else had this issue?
Nobby15 is online now
post #4 of 9 (permalink) Old 05-20-2019, 12:00 AM
Main Motorcycle: 2016 Triumph Scrambler
TalksToToads's Avatar
Other Motorcycle: 1977 Harley Sportster
Extra Motorcycle: 1973 Honda CL125
It may still be low voltage. When I did mine I ended up connecting a battery charger on the jump-start setting.
TalksToToads is offline
post #5 of 9 (permalink) Old 05-20-2019, 02:00 AM
Nobby15's Avatar
Thanks for the suggestion Talks. I found out from the Tune ECU FB page that the tune i loaded to the ECU via laptop is not one supported by Android. I had to go reload the previous tune and then i could use the phone, worked perfectly!
post #6 of 9 (permalink) Old 05-20-2019, 02:02 AM
No problem, glad to hear you got it sorted out.
Sent from my SM-J700P using Tapatalk
post #7 of 9 (permalink) Old 05-20-2019, 04:32 AM Thread Starter
Glad you got sorted!
I'm still not though, I've tried with a battery charger connected and volts showing around 13v and still no joy
Maybe I should try with an actual battery connected with jump leads. I'll let you know if that helps! Won't be until the weekend though
Cheers
Nevstah is offline
post #8 of 9 (permalink) Old 05-21-2019, 12:10 AM
Nobby15's Avatar
Hey Nevstah, Tune ECU just created a new forum. Maybe someone over there may be able to help out. http://tuneecu.boards.net/
post #9 of 9 (permalink) Old 05-22-2019, 01:40 AM Thread Starter
Thanks! I'll check it out
Nevstah is offline
Ignition problem '68 T120R tjwood Classic, Vintage & Veteran 28 11-20-2017 08:46 AM
TuneEcu and Map problem Martenas Triumph SuperSports 23 07-05-2017 08:57 PM
Interesting '09 efi model Bonnie battery problem LuckyBonnie Air Cooled Twins Technical Talk 208 04-30-2016 01:52 PM
TuneECU Problem JohnPol Air Cooled Twins Technical Talk 7 02-07-2012 07:42 PM
TuneECU Problem Centaur Daytona Deliberations 6 10-27-2011 05:52 AM
