Sagem TPS Reset Procedure - Triumph Forum: Triumph Rat Motorcycle Forums
ECM and FI Tuning - Help, Tips & Tricks We invite members from across TriumphRat.net to post your questions, or share your expertise or experiences on TuneBoy, TuneECU and PowerCommander (etc).
post #1 of 5 (permalink) Old 03-26-2013, 05:33 PM Thread Starter
Main Motorcycle: Black '04 Sprint RS
TE Lifetime Contributor
KitNYC's Avatar
Other Motorcycle: Blue '04 Sprint RS
I greatly appreciate the effort that's been put into TuneECU and the associated documentation; I do not mean this as an insult to anyone associated with the project, but I just don't understand this procedure and I'm hoping someone can explain it to me.
Reset Adaption Triumph-Sagem-Lambda-models
1. Ensure bike is seeing a closed throttle position (CTP),
if not, then perform TPS reset.
2. Bike in Neutral
3. Coolant temperature between 80-96°C
4. Minimum air box temperature of 21°C
5. Now with clutch pulled, the speed even bring about 3000 1/min, hold the clutch pulled and let the engine
run at idle for at least 30 seconds.
Check bike is adapted by viewing Lambda Fuel.
Figures should be "toggling" +4 to -4
Don't forgot to check IACV steps are 20 - 35
•How do I ensure that the bike is seeing a closed throttle position? (And what do I do if it's still not after a TPS reset?)
•Step 5... Can someone correct my understanding if it's wrong? I think it means "pull in the clutch lever and bring the engine up to 3,000 RPM, then let it drop to idle and continue to idle for at least 30 seconds while keeping the clutch lever pulled in." or "blip the throttle to 3k and let it drop back to idle for at least 30 seconds, all with the clutch lever pulled in."
•What is "Lambda Fuel?" Is that the value labeled "IACV?"
•How do I check IACV steps?
Thanks,
-Kit
KitNYC is offline
post #2 of 5 (permalink) Old 04-04-2013, 10:54 PM
Main Motorcycle: 04 Sprint St 955
Other Motorcycle: 99 Sprint St (retired)
Hey Kit, thanks for asking the questions that I also want to know....Anyone?
SeddoniaPhil is offline
post #3 of 5 (permalink) Old 04-23-2013, 02:26 AM Thread Starter
KitNYC's Avatar
Bueller?
KitNYC is offline
post #4 of 5 (permalink) Old 05-26-2019, 04:50 AM
Mashers's Avatar
I really need to know these answers too! Its a minefield and as much documentation there is, its never crystal clear! Can anyone help?
Mashers is offline
post #5 of 5 (permalink) Old 06-04-2019, 06:03 AM
Main Motorcycle: Rocket 3 Roadster
Tom-Hamburg's Avatar
Other Motorcycle: Speed Triple 1050
Thanks,
-Kit
This description was for the then Windows version, the values could all be read on the diagnostic and test screens.
In how far that is also possible with the Android version, please inquire with Alain.
Tip: Alain runs a small TuneECU forum.
http://tuneecu.boards.net/
Regards,
Tom
Tom-Hamburg is offline
Reset settings on ECU on Sagem Sprint: DaveM Maintenance Tips and Tricks for your Sprint 53 05-13-2017 04:17 PM
TuneECU DATA NEEDED!!! - Sagem Users Please! DEcosse ECM and FI Tuning - Help, Tips & Tricks 11 09-08-2010 04:43 PM
Help!!! Sagem or not Ant1 Sprint Forum 10 03-05-2010 03:39 AM
F.I.Tuning all Sagem,Keihin. AndyMetric Maintenance & Workshop Talk 3 04-10-2007 11:58 PM
SAGEM or Keihin timoteusmunk Tiger Chat 2 10-02-2006 03:56 AM
