TuneECU For Dummies -Installation Guide and Questions pertaining to Installation - Page 31 - Triumph Forum: Triumph Rat Motorcycle Forums
ECM and FI Tuning - Help, Tips & Tricks We invite members from across TriumphRat.net to post your questions, or share your expertise or experiences on TuneBoy, TuneECU and PowerCommander (etc).
 28Likes
post #301 of 336 (permalink) Old 08-16-2016, 01:19 AM
Main Motorcycle: '07 S3
Originally Posted by alistair59 View Post
Hi. I have downloaded the latest Tuneecu software and updated the drivers from Lonelecs website. However I find I am unable to connect my laptop to my bikes ecu (2002 Sprint ST). I get the messege "ECU not responding. Check cable connection, turn ignition off and on". I have no such issues with my Android tablet, I was able to read and clear error codes with out a problem. Can anybody advise on how to solve this issue please? Thanks and regards, Alistair.
Which version of Windows are you running? Device manager sees the cable, correct?
tkhov is offline
post #302 of 336 (permalink) Old 09-07-2016, 03:00 PM
Main Motorcycle: 2011 Street Triple R
I'm getting a ecu not responding error as well.
2011 street triple
Amazon cable confirmed correct chipset with FT prog
Windows xp with .net framework 1.1, 2.0, 3.0, 3.5, 4
Tune ecu 2.5.7
Tried driver versions 32 bit cdm 2.08.24 and 2.12.18
Battery connected to tender, 20a fuse pulled, kill switch in run, gear is neutral.
I just keep getting ecu not responding. Any suggestions? I'm stuck
Sent from my SM-N910V using Tapatalk
2013 Ninja ZX6R with ABS
SOLD 2011 Matte Graphite STR ::: OEM Fork Sliders - Case Protectors - Rear Spools - Bar End Mirrors - Frame Sliders / TechSpec SS Pads / Cox Radiator Guard / SoCal Suspension Tuned / GPR V4 Stabilizer
chomorro is online now
post #303 of 336 (permalink) Old 09-07-2016, 03:31 PM
Figured it out. Needed to pull the 5a fuse too. My trickle charger isn't enough charge for tune ecu.
Finally connected and I think the oem arrow map I have on the bike is exactly the same as the one I downloaded from the site. 20590. Can anyone Confirm this? We're there any changes that would make a difference?
post #304 of 336 (permalink) Old 09-08-2016, 02:51 PM
Main Motorcycle: Triumph speed four 600
Hi could someone give me some help please I have recently purchased a tuneECU,
I have had a link sent to me to download from warehousedianostics that I have downloaded to my PC the dashboard is showing on screen but even when I select usb in option and connect to my bike the dash panel on PC stays inoperative ie rev counter not working on screen ??
I have windows 8.1 64bit OS will tuneECU work on my computer or not ? if it will is there any other checks I can do before sending it back for a refund
Thanks you in advance for any help you can give me.
pcuk007 is offline
post #305 of 336 (permalink) Old 09-19-2016, 06:38 PM
Main Motorcycle: 06 Sprint R.I.P. 2017
kubbie's Avatar
Other Motorcycle: 00 TT600
Extra Motorcycle: 16 Griso
I'm at a loss.
I've used TuneECU before, with my last laptop that has since died, and the cheap $10 cable.
Loaded TuneECU v2.5.7 into my new laptop running Windows 10 and my old cable will not connect to the bike. Kept getting the "ECU not responding". So I bought a brand new Lonelec cable that arrived today.
Not sure about the drivers. I have a CDM v2.12.10 WHQL Certified downloaded into my computer. That sound right?
But everything I have read states that with Windows 10 "your lead should automatically install".
"To check if installed correctly select Device Manager". It's there, showing up as USB Serial Port (Com3) just like it is supposed to.
What am I missing?
Do I need to delete all of it and start over? it's driving me crazy.
kubbie
"I'll call you if you need me"
kubbie is offline
post #306 of 336 (permalink) Old 09-19-2016, 06:44 PM
Originally Posted by kubbie View Post
I'm at a loss.
What am I missing?
It was probably the same problem mine had. Hook your bike up to a car battery and see if it reads the ecu then. Should work
post #307 of 336 (permalink) Old 09-20-2016, 06:31 AM
Main Motorcycle: 2014 mag Bonneville
petronila's Avatar
And with TuneECU running check to make sure under Options\Interface, that "USB" is selected and not "Serial". A while ago mine unexpectedly flipped to 'serial', don't know why, and I started getting messages can't connect check cable etc.
Tom
2012 Street Triple (sold) / 1977 Yamaha XS500 (yea but it was cheap, r.i.p.) / 1967 Yamaha YR1-350 (r.i.p.)
petronila is offline
post #308 of 336 (permalink) Old 09-22-2016, 04:30 AM
I have checked that on mine and has a tick against USB FT 232 R but still no go ??
pcuk007 is offline
post #309 of 336 (permalink) Old 09-22-2016, 06:33 AM
petronila's Avatar
Check the driver. Did Windows 8 choose the existing driver ? With the cable plugged into the USB port on the PC, go: Control Panel - Device Manager - Ports (COM & LPT) - USB Serial Port (COM4) - Properties - Driver. What is the "Driver Version" showing ? According to TuneECU for Windows 8/8.1 it should be one of: Vers.2.08.28_64bit, CDMv2_08_30WHQL_Certified, CDMv2.10.00WHQL_Certified, CDMv2_12_00WHQL_Certified, CDMv2.12.06WHQLCertified, CDMv2.12.16WHQLCertified.
Failing that it might be time to send that cable back and get a Lonelec.
Tom
post #310 of 336 (permalink) Old 09-24-2016, 08:06 AM
kubbie's Avatar
Think your right.... Left bike on Battery Tender overnight, showing 12.6V on the voltmeter. Connected first try.
Came back little while later to proof it wasn't a fluke, would not connect. Voltmeter showing 12.3.
This was a "test " so didn't pull any fuses or attach the Tender. Will test again later.
Thanks for the help.
chomorro likes this.
kubbie
kubbie is offline
Oversize valve guide installation 1943MB Classic, Vintage & Veteran 4 04-07-2014 10:58 PM
Rizoma Zero turn signals installation for the dummies? Max_NYC Speed Triple Forum 19 05-29-2011 07:10 PM
Exhaust Installation Guide? Existence_Inc Air Cooled Twins Technical Talk 4 04-07-2010 10:14 PM
Film a R&G Installation Guide? Tattoed Red Head Sprint Forum 0 01-18-2009 08:12 PM
Which ARK? And the Installation Guide? rstover Air Cooled Twins Technical Talk 10 03-13-2007 09:24 PM
