TuneECU - Discussion, Q and A - Page 69 - Triumph Forum: Triumph Rat Motorcycle Forums
ECM and FI Tuning - Help, Tips & Tricks We invite members from across TriumphRat.net to post your questions, or share your expertise or experiences on TuneBoy, TuneECU and PowerCommander (etc).
post #681 of 879 (permalink) Old 02-10-2012, 04:28 AM
Main Motorcycle: Thruxton 1200
Other Motorcycle: Thruxton 900
Thanks for the reply Tom, I'm using current TuneECU 2.0.
I ended up fiddling around with the program some more. I re-downloaded the tune, turned key on off like 20 times went through every setting possible in TuneECU figured out that you can only clear codes in diagnostics/tests buttons and found it in the menu like you described not sure how I finally ended up clearing the light but everything is a go.
Cold/weird weather here Michigan but not cold enough to take her on a lil joy ride... Great tune by TTP!!!!
dskatkov is offline
post #682 of 879 (permalink) Old 03-04-2012, 09:38 AM
Main Motorcycle: 07 Sprint ST 1050
jpitchford's Avatar
Other Motorcycle: 05 Thruxton
Send a message via Skype™ to jpitchford
I purchased this cable. http://www.amazon.com/gp/product/B002WIN8VQ/ref=oh_o02_s00_i00_details
I opened it to check the chip and it is a FTDI chip inside. I am having issues connecting to the bike. I am running driver version 2.8.14.0. The bike is an 07 Sprint ST. This is my first time attempting this on a bike. I have used similar software for cars before.
jpitchford is offline
post #683 of 879 (permalink) Old 03-04-2012, 12:28 PM
That's the same cable I bought, but I never went as far as opening it up to find out if it really is an ftdi. Anyway, plug your bike battery into a charger dude you need to be above 12.5v I believe. If you have already done that then I'm not sure what to suggest. Maybe someone else will respond with some better suggestions.
Plug in battery
Start tuneECU
Plugin USB then OBD2
Battery - <12.5v (the higher the better)
dskatkov is offline
post #684 of 879 (permalink) Old 03-04-2012, 01:13 PM
Main Motorcycle: 2012 800XC
Other Motorcycle: 2008 WRR
Extra Motorcycle: XR200/250 Hybrid
Originally Posted by jpitchford View Post
I bought the same cable, saw it referenced here and elsewhere. Bought it from Amazon rather than eBay just in case of problems...easy returns.
Which as it turns out, was a good idea - I'm fairly certain mine is defective, and am sending it back and ordering another. The FTDI drivers won't load - same symptom every time, on each PC. It starts off as it should - plug in the cable, adaptor light goes on, get the Windows new hardware prompt, then point it at the downloaded drivers linked to at the TuneECU site.
However it starts to install, then fails with an error indicating no hardware can be found to match the drivers. All three boxes I tried are XP+SP3, one of which was a fresh install - nada.
Here's to hoping cable #2 is better...
syspig is offline
post #685 of 879 (permalink) Old 03-04-2012, 02:33 PM
Well...there's likely no problem with the adaptor I ordered, other than the fact it's not compatible. Did a little research - nerd stuff ahead.
The important part being, that the Amazon adaptor doesn't necessarily use the FTDI chipset that is mandatory for TuneECU compatibility. I discovered this after reading the following in a troubleshooting guide at FTDI - it described my problem with loading the drivers exactly:
4.1 Windows XP Cannot Find Drivers For My Device
This error can occur if the VID and PID programmed into the device EEPROM do not match those listed in the INF files for the driver. The VID and PID programmed into the device EEPROM may be found by using the USBView utility from the FTDI web site. These can then be checked against the VID and PID entries in
the driver INF files. If they do not match, that driver cannot be installed for that device without either reprogramming the device EEPROM or modifying the list of VID and PID numbers in the INF files.
Please note that only your own company VID and PID or FTDI's VID (0x0403) and FTDI PID issued for use by your company should be used in the EEPROM and INF/INI files.
So, armed with the above I downloaded the usbview utility from the FTDI web site. Fired it up with the Amazon cable attached, and it showed the following:
The critical bits are the idVendor (0x1A86) and idProduct (0x7523) numbers - they don't match FTDI numbers listed in the troubleshooting guide.
A quick search for USB vendor ID's turned up this page - which shows the codes on my Amazon adaptor belong to QinHeng Electronics, and the adaptor is using their HL-340 USB-Serial adapter chipset - not FTDI's.
So, the short version - if you encounter errors loading the drivers for your cable, download the usbview utility which will verify whether you have an FTDI chipset or not. Unfortunately, with the Amazon supplied cable - who knows whether you'll get one with an FTDI chipset or not.
syspig is offline
post #686 of 879 (permalink) Old 03-04-2012, 03:11 PM
dskatkov is offline
post #687 of 879 (permalink) Old 03-04-2012, 03:21 PM
Main Motorcycle: Triumph Speed Triple 1050
Tom_Hamburg's Avatar
Other Motorcycle: Triumph Rocket Roadster
Hi syspig,
Many thanks to you for this useful tip.
BR, Tom
Tom_Hamburg is offline
post #688 of 879 (permalink) Old 03-04-2012, 03:30 PM
Originally Posted by dskatkov View Post
You can do a million years of research but carelessly buying things off amazon is just plane ignorant.
Speaking of ignorance - perhaps you meant "plain".
Insults aside, I did plenty of research - and if you took the time to read the reviews for the cable I linked to, you'll see plenty of people are successfully using it with TuneECU. You'll also find plenty of folks here and at the UK site who linked to that cable who had no problem with it.
The issue is obviously with the supplier - they are not consistently shipping this cable with the FTDI chipsets. It's a roll of the dice.
Don't be a cheap skate and buy this one.
http://www.amazon.com/gp/aw/d/B003ZK...0891789&sr=8-2
One step ahead of you - that's the first one that popped up at Google when I searched "tuneecu cable ftdi". It's on the way.
syspig is offline
post #689 of 879 (permalink) Old 03-04-2012, 06:25 PM
Supernova
Forchetto's Avatar
I've tested several cables. The ones that are consistently good are the ones that TuneECU site advises, here:
http://www.lonelec.co.uk/index.php?m...mab3r7pv424s63
Forchetto is offline
post #690 of 879 (permalink) Old 03-05-2012, 12:47 AM
dskatkov is offline
TuneEcu mforget ECM and FI Tuning - Help, Tips & Tricks 16 06-29-2015 01:39 AM
TuneECU DEcosse ECM and FI Tuning - Help, Tips & Tricks 2 09-22-2014 02:31 AM
Now let's get down to some deep discussion ruscook Biker Hang-Out 12 06-18-2008 07:20 PM
More Snorklectomy Discussion zighawk Air Cooled Twins Talk 16 02-15-2006 08:09 PM
Yet another screen discussion... vgermani Sprint Forum 24 10-29-2004 09:31 AM
