‘15 D675R Slip On - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
  • 1 Post By Mr_nobody
post #1 of 4 (permalink) Old 11-11-2018, 05:49 PM Thread Starter
Newbie
‘15 D675R Slip On
I just installed an SC Project slip on and went to the dealer to get the slip on map installed. I had to remove the servo motor, which threw a CEL.
The new map got rid of the CEL and the dealer told me if it didn’t come back then I wouldn’t need a servo buddy or ESRM.
I have only ridden it back from the dealer, about 10 miles, and the CEL is still gone. I didn’t think a map would clear it.
Is this normal? I’m happy that I don’t have to buy something else.
Mr_nobody is offline
post #2 of 4 (permalink) Old 11-12-2018, 01:13 PM
Main Motorcycle: Very fast 675
Official Leathers Tester
Will's Avatar
Other Motorcycle: DRZ 400 Bad Idea
I'm not sure how the exhaust on a 2015 is configured, but it doesn't surprise me too much. The servo operates a flapper in the exhaust. There was plenty of room for that equipment in earlier models with an underseat exhaust. But 2015, it may have been located in the end can, which means the TOR map would solve the problem. Or, maybe I don't know at all. Either way, if the map worked, then it's great.
Will
Will is offline
post #3 of 4 (permalink) Old 11-13-2018, 02:06 AM Thread Starter
Newbie
The map took care of the CEL, I’ve only ridden it twice so far.
wpanik likes this.
post #4 of 4 (permalink) Old 05-21-2019, 01:16 PM
wpanik's Avatar
Originally Posted by Mr_nobody View Post
The map took care of the CEL, Iíve only ridden it twice so far.
That map likely just told the ECU to ignore input from the flapper. You should be set!
Sent from my iPhone using Tapatalk
wpanik is offline
Comp Werks slip on for 2013+ stock exhaust WordisBond Street Triple Forum 11 05-10-2018 12:21 PM
Vance and Hines Slip on's on my Thruxton R...Map?? CRFan250 Water Cooled Twins Technical Talk 2 03-05-2018 04:44 PM
2013 Street Triple trouble starting + possible clutch slip? erkishhorde Street Triple Forum 4 02-03-2017 01:46 AM
Arrow Slip On Install - gasket Hyperlite Street Triple Forum 8 06-29-2016 01:13 AM
