Daytona 955i Constant Priming Fuel Pump - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
  • 1 Post By DEcosse
post #1 of 8 (permalink) Old 10-06-2019, 09:40 AM Thread Starter
Newbie
Exclamation Daytona 955i Constant Priming Fuel Pump
Hello I'm in away a new member to this Forum,
The issue I have with my Triumph Daytona 955i 2000 model is:-
Started the bike in the garage on the paddock stand to just check everything over, and forget that I drained the tank of fuel, bike started (must have been on minimum amount and vapour), then of course stop running!!
I realised that fuel was the issue (after a few goes at restarting) but then noticed:-
a) the Fuel Pump was constantly priming
b) Engine Management Light was on continually
So after a while I pulled in the clutch and pressed the starter & the bike started and ran (at first with a bit of a sputter) but then perfectly & rev's cleanly.
But I still have the problems of:-
a)the Fuel Pump constantly priming
b) Engine Management Light being continually on (even after 4 heat cycles)
Would I be correct (with out a diagnostic check) that the pump & fuel filter could be causing these issues.
Also just to throw another spanner in the works I removed the fuel pump relay, and the fuel pump still constantly primed, the bike started and ran perfectly??????
Wantabe is offline
post #2 of 8 (permalink) Old 10-06-2019, 05:43 PM
Main Motorcycle: 08 FLHTCU Electra Glide
andrewb's Avatar
Other Motorcycle: '97 Hot Rod Sporty
Pre-02 fuel pumps are switched in the ecu, no external relay for it.
I'm dealing with a variation of this problem, for me both the wiring and ecu check out. But the issue started when I added a heated vest harness to the battery. Currently, the bike runs fine, no 'mil' light. Matter of fact the 'mil' only comes on when I turn the vest on.
Changed ecu, and reprogrammed, no change.
I'll have it apart in a week or two for maintenance, going to dig deeper into the wiring then. Let you know if I find anything else.
OOh looke a custom signature !
andrewb is offline
post #3 of 8 (permalink) Old 10-06-2019, 08:09 PM
Main Motorcycle: '98 T595 Daytona
Other Motorcycle: 2014 Ninja 1000ABS
Did you check to see what error code is present when the MIL goes off when using the vest?
Felony is online now
post #4 of 8 (permalink) Old 10-07-2019, 05:08 PM
Supernova
DEcosse's Avatar
Assuming has std wiring and has not been modified, you are most likely looking at an ECU failure on the pump drive circuit.
Not as horrendous as might seem - ECU are quite cheap on EBay - generally very robust too with only a few failures of that pump or fan drive being vulnerable but chances more likely used one will be good than not.
DaveM likes this.
DEcosse is offline
post #5 of 8 (permalink) Old 10-13-2019, 11:22 AM Thread Starter
Newbie
Question
Further update to Fuel Pump Constantly Priming Issue.
MIL Light has gone off (after third continued heat cycle),
Reset fault codes,
Fault diagnostic (TuneECU) shows:-
P0230 FUEL PUMP RELAY DEFAULT
P1231 FUEL PUMP RELAY OPEN CIRCUIT OR SHORT TO GROUND
Do we still presume that this the ECU?
That the fuel pump is the issue?
Wantabe is offline
post #6 of 8 (permalink) Old 10-14-2019, 01:02 PM
Supernova
DEcosse's Avatar
There is no relay on your system
The fuel pump cannot run without power (and ground) and cannot generate its own (!!!!!), therefor has to be the ECU (with the aforementioned caveat that it is still the OEM configuration)
DEcosse is offline
post #7 of 8 (permalink) Old 10-15-2019, 05:10 PM Thread Starter
Newbie
Thumbs up
The Bike has OEM wiring, only additions High Level tail pipe (MHP) and K&N filter.
So any model ECU as long as it's a Sagem MC1000 (S1000T3, T1291000).
Shame really as mine as only done 17,600 miles.
Is there anyone who does repair these units? because at some point we'll run out of second hand ones!!!! as I intend to keep mine for many years more.
thanks Ken for your help (download of map still to do!).
Wantabe is offline
post #8 of 8 (permalink) Old 10-15-2019, 06:55 PM
The ECU is not repairable. I had to replace mine for my '98 Daytona which has less than 20K on it. For different reasons. At some point, old bikes with old FI systems will become stationary objects to admire, not to ride. Probably easier to keep a Daytona 1200 going than a 955i. I sometimes wish my T595 had carbs vs FI.
