Ducati rear wheel torque - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
  • 1 Post By JBC
post #1 of 7 (permalink) Old 09-06-2019, 08:26 AM Thread Starter
JBC
Can anyone advise on the torque setting that's best to use? Triumph uses a conical washer & 146nm but ducati don't use the conical washer but tightens the nut to 174nm. I'm thinking of continuing to use the triumph conical washer, flat washer & nut but the ducati wheel could be magnesium so I'm unsure if I go 146 or 174nm thanks
JBC is offline
post #2 of 7 (permalink) Old 09-06-2019, 08:46 AM
Main Motorcycle: 2006 Sprint ST 1050
Stevienh's Avatar
Other Motorcycle: 2009 BMW R1200R
Extra Motorcycle: Son's 2010 Street Triple
Just my opinion, but I would stick with the Triumph torque spec because that is what the fasteners and bearings are rated for. . Although it's unlikely the additional 28 nm would cause damage, I would hate to discover that the hard way. Just be sure to use the lock ring to prevent the nut from backing off, and zip tie the ends together so the lock ring can't fall off, either. That has been known to happen. The dealers in my area consider it SOP.
Good luck.
Stevienh is offline
post #3 of 7 (permalink) Old 09-06-2019, 12:43 PM Thread Starter
JBC
Ah good call I hadn't thought about that. I'm thinking the conical shaped washer is designed to flatten out when tightened & will allow a little discrepancy.
JBC is offline
post #4 of 7 (permalink) Old 09-08-2019, 03:26 PM Thread Starter
JBC
Spacer is almost done
JBC is offline
post #5 of 7 (permalink) Old 09-08-2019, 08:05 PM
Main Motorcycle: 2004 Daytona 955i
Other Motorcycle: 2006 1050 Speed Triple
Extra Motorcycle: Vespa PX200
I'm surprised the Ducati wheel will fit on a Triumph. I'd have thought the offset would be different.
Terry Colley is online now
post #6 of 7 (permalink) Old 09-09-2019, 01:38 AM Thread Starter
JBC
Yes your right, normally a 15mm spacer behind the wheel will sort that out.
andrewb likes this.
JBC is offline
post #7 of 7 (permalink) Old 09-10-2019, 04:23 AM
Main Motorcycle: Daytona 955i
That washer is a Belleville or disc spring washer. Use the triumph torque because thatís whatís designed to flatten it to make it it work. The Ducati flat washer needs extra because it has no self locking mechanism but I would guess that the axle is a bit little bit beefier.
DonTheMan is offline
