Converting to LED Turn Signals - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
  • 1 Post By DEcosse
post #1 of 7 (permalink) Old 07-22-2019, 03:51 PM Thread Starter
Main Motorcycle: 2007 Speed Triple
$hporty's Avatar
Other Motorcycle: 1998 Daytona T595
Hi Everyone, I just purchased a 98 T595 Daytona (I already have an 07 Speedy) and may want to replace the turn signals with LED's. Can anyone confirm...Will LED turn signals work with properly if you simply replace the flasher relay with a LED unit (such as the CF13GL02)? Or are other wiring modifications needed?
I know that's all that was needed on my speed triple. Not sure on the older bikes though.
Thanks in advance.
$hporty is offline
post #2 of 7 (permalink) Old 07-22-2019, 04:16 PM
Supernova
DEcosse's Avatar
Originally Posted by $hporty View Post
...Will LED turn signals work with properly if you simply replace the flasher relay with a LED unit (such as the CF13GL02)? Or are other wiring modifications needed? .
You also need a mod to the instrument cluster warning light
(any common rectifier diode will do)
If you don't do this mod, all 4 signals will flash regardless of which side you select
DEcosse is online now
post #3 of 7 (permalink) Old 07-22-2019, 05:00 PM Thread Starter
$hporty's Avatar
Bummer!!! I'll just stick with regular bulbs....I'll spend that time riding it!
Thank you for the information though. Maybe a winter project.
$hporty is offline
post #4 of 7 (permalink) Old 07-22-2019, 05:26 PM
Main Motorcycle: 2004 Triumph Daytona 955i
AdventureJunkie's Avatar
I put a set of these on and they have worked perfect without any major rewiring. Pretty much plug and play
http://www.hightechspeed.com/product...0/triumph.html
Sent from my SM-G975U using Tapatalk
AdventureJunkie is offline
post #5 of 7 (permalink) Old 07-22-2019, 08:53 PM
Supernova
DEcosse's Avatar
@AdventureJunkie - with the 97-01 it needs the diode mod (or below).
@$hporty - you can alternatively add parallel load resistors (in which case you can keep the OEM relay) - but the diode mod is not that difficult.
AdventureJunkie likes this.
post #6 of 7 (permalink) Old 07-23-2019, 01:26 PM Thread Starter
$hporty's Avatar
@DEcosse Thanks for the info. It doesn't look difficult. I just got this bike so I'm trying to focus just on getting up to speed mechanically. Pretty cool bike I must say.
$hporty is offline
post #7 of 7 (permalink) Old 08-08-2019, 09:51 PM Thread Starter
$hporty's Avatar
Who needs LEDs when they make these bad boys!
$hporty is offline
