Triumph Forum: Triumph Rat Motorcycle Forums (https://www.triumphrat.net/forum.php)
-   Daytona Deliberations (https://www.triumphrat.net/daytona-deliberations/)
-   -   Converting to LED Turn Signals (https://www.triumphrat.net/daytona-deliberations/957528-converting-to-led-turn-signals.html)
$hporty 07-22-2019 03:51 PM
Hi Everyone, I just purchased a 98 T595 Daytona (I already have an 07 Speedy) and may want to replace the turn signals with LED's. Can anyone confirm...Will LED turn signals work with properly if you simply replace the flasher relay with a LED unit (such as the CF13GL02)? Or are other wiring modifications needed?
I know that's all that was needed on my speed triple. Not sure on the older bikes though.
Thanks in advance.
DEcosse 07-22-2019 04:16 PM
Originally Posted by $hporty (Post 2003971114)
...Will LED turn signals work with properly if you simply replace the flasher relay with a LED unit (such as the CF13GL02)? Or are other wiring modifications needed? .
You also need a mod to the instrument cluster warning light
(any common rectifier diode will do)
If you don't do this mod, all 4 signals will flash regardless of which side you select
https://www.triumphrat.net/memberalb...signal_mod.JPG
$hporty 07-22-2019 05:00 PM
Bummer!!! I'll just stick with regular bulbs....I'll spend that time riding it!
Thank you for the information though. Maybe a winter project.
AdventureJunkie 07-22-2019 05:26 PM
I put a set of these on and they have worked perfect without any major rewiring. Pretty much plug and play
http://www.hightechspeed.com/product...0/triumph.html
Sent from my SM-G975U using Tapatalk
DEcosse 07-22-2019 08:53 PM
@AdventureJunkie - with the 97-01 it needs the diode mod (or below).
@$hporty - you can alternatively add parallel load resistors (in which case you can keep the OEM relay) - but the diode mod is not that difficult.
$hporty 07-23-2019 01:26 PM
@DEcosse Thanks for the info. It doesn't look difficult. I just got this bike so I'm trying to focus just on getting up to speed mechanically. Pretty cool bike I must say.
$hporty 08-08-2019 09:51 PM
1 Attachment(s)
Who needs LEDs when they make these bad boys!
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
