Need help no start when warm - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 17 (permalink) Old 05-09-2019, 03:48 AM Thread Starter
Onyx0621's Avatar
Hi I am a car mechanic who bought first bike. It's a 1999 Daytona 955i it sounds great feels healthly besides a slight low end hesitation up till 4k rpm and smells rich. It runs fine no overheating or funny sounds. I rode it for 4hrs without any issues till I turned it off it wont start till 30-60min have passed n is cold again. Cranks just fine just no start. If I give it some throttle it will kinda start then I start again with lil more gas and. Boom on again. Just changed plugs and oil I got no idea what to do from here all vacuum lines have been changed but no luck on it starting when warm
No check engine light , 91 octane gas
Well I just discovered I can get it to turn on when at operating temp. By giving some throttle maybe on the 2nd or 3rd itll start , that's latest update. is there any way to test the crank sensor. Would a bad crank sensor cause it to run rich give slight power hesitation at lower rpms ?
And your right on the fuel pump/regulator. I only thought maybe it wasn't providing enough pressure to start the bike when hot but yet I can start it with more throttle. I can post a video a little later I'm planning on going for a ride
Last question. Wouldn't that crank sensor cause it to not turn on at all ? Maybe running rough ? At least that's what I would expect in a car
Do these bikes use 87 or 91 octane. ?
I have managed to get it to turn on while hot couple times in a row by giving it some throttle as I press the start button I will upload video shortly
Lol well I got a cold start video since its night right now it actually back stabbed me and turned right on after I shut it off ....soo tomorrow during the day I'll ride it and shoot a video again XD. this is the YouTube link.
https://youtu.be/OUKrdjh-auk
Finally got a chance to catch the bike slipping. Lol. So this is a video fresh after I did a 2hr ride on first try it actually started right up because it was cold out I noticed itll start on cold weather.
https://youtu.be/xwvdZFC8FA0.
And finally on the 2nd attempt to start it didn't start. This is part 2 of the other link I just posted . I attempted to turn it on by playing with throttle but no luck since I was recording. You can hear it kinda wanting to turn on as I use a bit of throttle after 2nd or 3rd start
https://youtu.be/SvcJbHb9zIU
Onyx0621 is offline
post #2 of 17 (permalink) Old 05-09-2019, 03:48 AM Thread Starter
Onyx0621's Avatar
Onyx0621 is offline
post #3 of 17 (permalink) Old 07-17-2019, 02:35 AM Thread Starter
Onyx0621's Avatar
Like the title says I can turn on the bike anytime of the day itll start on first crank. I can go on a 4 hr drive just fine no stalls or misfiring. Soon as I shut it off it wont start anymore , it cranks strong, fuel pump prime is there and relays click, I replaced spark plugs , new battery 320cca agm battery .....lately I've discovered I can get it to start by applying some throttle basically bumping the throttle will sometimes get it to start , or push start will do the trick. any tips greatly appreciated. Kick stand and N switch work fine. 91 octane ran only
Onyx0621 is offline
post #4 of 17 (permalink) Old 07-17-2019, 03:00 AM Thread Starter
Onyx0621's Avatar
Sorry forgot to include model.
Its. A 1999 daytona 955i. 28k miles
Onyx0621 is offline
post #5 of 17 (permalink) Old 07-17-2019, 10:15 AM
Supernova
DEcosse's Avatar
Put it in your profile please, along with your location
DEcosse is online now
post #6 of 17 (permalink) Old 07-17-2019, 10:26 AM
Supernova
DEcosse's Avatar
.. . 91 octane ran only
Should be running 89
Other symptoms:
Does it idle correctly when it is warmed up (1250 rpm)?
Does it smell 'rich' ?
When you replaced plugs how did they look (colour) - were they black/sooty or nice light tan colour?
Do you have an MIL light?
Does Temperature gauge read 'normal'?
Have you had this bike a long time - did this just get progressively worse, or have you not had it long enough to know historically when this began?
post #7 of 17 (permalink) Old 07-17-2019, 10:29 AM
Supernova
DEcosse's Avatar
Looked back your posting history and found your intro thread - https://www.triumphrat.net/the-welco...warm-955i.html
It would have been good if you had included a lot of that information here!
I'm going to move all those posts here - all of that from the Welcome Thread now appears as the FIRST post here
post #8 of 17 (permalink) Old 07-17-2019, 10:38 AM
Supernova
DEcosse's Avatar
Suggestions on that other thread referenced the CPS which is a very good suggestion regarding hot start issues - you should start by checking the gap - should be 1mm (0.040)
post #9 of 17 (permalink) Old 07-17-2019, 12:07 PM
Main Motorcycle: 2001 Triumph Tiger
Other Motorcycle: 1997 Triumph Daytona
Extra Motorcycle: 2001 KTM LC4-E
Another issue based on your clue that it smelled rich. I played with the tunes on my 97 and found all but one of the available online tunes to be VERY rich. Previous owner could have messed with the tunes. I would look at what was installed.
AdventurePS is offline
post #10 of 17 (permalink) Old 07-17-2019, 04:27 PM Thread Starter
Onyx0621's Avatar
I have had this bike for about 2 months now and problem is not getting better or worse. , I changed new battery agm 320cca. It starts with a bit of throttle sometimes. And I'm driving it in the fwy now and the check engine light comes on when I go WOT. it always smells rich does not misfire. just a bit of boom! Backfire when i let of the gass from time to time. the old injectors where pretty black.....
Onyx0621 is offline
