Brake line discoloration - Triumph Forum: Triumph Rat Motorcycle Forums
 2Likes
  • 2 Post By lemmings999
post #1 of 8 (permalink) Old 06-22-2019, 12:58 PM Thread Starter
Main Motorcycle: 2002 daytona 955i
Just rebuilt the calipers and put new lines on the other week. Not used the bike yet since and noticed a discoloration in on if the hose covers, any guesses as to what it is, hoping not fluid as that would mean the new line is faulty, looks too dark for new fluid tho.
lemmings999 is offline
post #2 of 8 (permalink) Old 06-22-2019, 03:09 PM
Supernova
Main Motorcycle: 2011 Sprint GT 1050
DaveM's Avatar
Other Motorcycle: 2004 Daytona 955i
Extra Motorcycle: Previously - Many
Question a mystery indeed my dear Watson.........
I have no idea how, but could oil have gotten on there, is it dry?
One of the resident clever tech people here with a few clues will have a decent idea I'm sure.
Sure looks a bit odd.
Can I ask why you changed from the stock rubber coated braided lines though?
Whatever the case, good luck mate.
DaveM is offline
post #3 of 8 (permalink) Old 06-22-2019, 03:14 PM Thread Starter
It's inside the plastic coating so not able to tell if its dry or not, had braided lines on it when i got it but the ends where it joined the calipers were corroding so needed replacement.
post #4 of 8 (permalink) Old 06-22-2019, 08:27 PM
Main Motorcycle: 2001 Daytona 955i
andrewb's Avatar
Other Motorcycle: '97 Hot Rod Sporty
More out of curiosity; when you pump up the brake, does it hold?
OOh looke a custom signature !
andrewb is offline
post #5 of 8 (permalink) Old 06-23-2019, 02:37 AM Thread Starter
Yeah there seems to be full pressure in the system
post #6 of 8 (permalink) Old 06-26-2019, 02:21 AM Thread Starter
Emailed the manufacturer, this was the reply,
Apologies for the discolouration of your brake line.
When the hose is made it is pressure tested using water. It appears in these unusual cases the water has got trapped between the braid and PVC cover.
The braid is stainless steel, but there are many different grades of stainless. Most grades of stainless contain small amounts of Iron and Nickel. The small amount of Iron content can cause your line to discolour, essentially it’s rust that could be wiped off if you were to remove the outer coating. Although, this might be unsightly, it’s perfectly safe.
We will cover this defect with your warranty*and send you a replacement.
24 hours later a replacement arrived, no mention of wanting the old one back.
Now to fit it.
DaveM and andrewb like this.
post #7 of 8 (permalink) Old 06-26-2019, 04:58 AM
Supernova
DaveM's Avatar
Thumbs up Nice one
Well Watson that was...... well elementry my dear chap!
Great result mate, that's what I call customer service and smart business behaviour.
DaveM is offline
post #8 of 8 (permalink) Old 06-26-2019, 03:31 PM
Main Motorcycle: ThruxtonR,
pmorritt's Avatar
Other Motorcycle: BMWR1100RT
Acceptable explanation, poor quality control.
Masquerading every day as a normal person is exhausting.
pmorritt is online now
