Sleeping Beauty; resurrecting a sleeping Daytona - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
 28Likes
post #11 of 33 (permalink) Old 05-08-2019, 01:16 PM Thread Starter
Main Motorcycle: 97 Hot rod sportster
andrewb's Avatar
Other Motorcycle: 2001 Daytona 955i
A pleasant surprise yesterday, beat the weather home while picking up supplies. The radiator and cooling system are fine, the sludge at the filler neck did not permeate the system. Spoke to a friend at NAPA, he confirms that the little there will reabsorb into the system once it is running.
I pulled the lower radiator hose and was rewarded with blue coolant, put it together and noted to refill and flush the system once running.
New fuel pump and filter will be here tomorrow, so there is a distinct possibility again of having a running bike this weekend. Though I'll not hold my breath.
Action photo of coolant, and a clothes off pic of the bike.
ID:	641922   Click image for larger version
OOh looke a custom signature !
andrewb is online now
post #12 of 33 (permalink) Old 05-08-2019, 06:46 PM
Main Motorcycle: '08 Sprint ST
sussurf's Avatar
Other Motorcycle: '06 Daytona 955i
Extra Motorcycle: Husqvarna Terra 650
Send a message via Skype™ to sussurf
Don't forget to adjust the chain!
DaveM, andrewb, freck and 1 others like this.
cheers,
Phil
sussurf is offline
post #13 of 33 (permalink) Old 05-08-2019, 07:20 PM Thread Starter
andrewb's Avatar
Yep, I have to stake the master link too!
Pulled the fuel pump plate out this afternoon, varnish....so cool. Tested the fuel pump, has continuity, but no rotation. I partially disassembled the plate for service and cleaning. I'll get it finished tomorrow with new parts.
Decided to wait on pulling the injectors for cleaning. My friends garage will do them if I ask.
Despite how cruddy the tank looks the varnish is very thin, not too sure about trying to clean it beyond removing the debris. Hate to melt it.
Note: Stabil may have prevented the varnishing, but only if the bike was stored with a full tank. As it is there was only 3/4 gallon in there and it was 13 years....
ID:	641954   Click image for larger version
ID:	641956   Click image for larger version
ID:	641958   Click image for larger version
ID:	641960   Click image for larger version
Andrea_70 likes this.
post #14 of 33 (permalink) Old 05-09-2019, 06:06 PM
sussurf's Avatar
I'm currently doing an old car fuel tank 35 years old. This time I'm using apple cider vinegar. I dropped about 1 litre in a few days ago and am back to shiny metal on the test spot.
It's an 80 litre tank!
I bought a 20 litre drum from a horse pet supply company but I guess I'll be rotating it for the next few weeks....
DaveM and freck like this.
cheers,
Phil
sussurf is offline
post #15 of 33 (permalink) Old 05-09-2019, 09:49 PM Thread Starter
andrewb's Avatar
Life happens quick, you leave for work smiles, hugs and come home to getting served, or after watching the texting dingbat in front of you you break and go to pass, next it's sun, shade, sun, shade why am I on my back..
Other times its a....well I'll stop there.
I hit the lotto today, metaphorically that is, otherwise I'd be moving into my 4000sq foot garage with a bedroom and bath. La vida loca baby. Reality settles in. I pulled the fuel pump and flushed it with carb spray. Hooked it to a power source, while giving it a little rotational encouragement with a dental pick......vrrrrrrr it works. Make and break power, it cycles each time. That's good because ebay failed to deliver my new one.
Reinstall it and the new Mahle K-145 that felony suggested, nice and clean. Cleaned up the plate gasket, and removed the crud from inside the tank. A quick flush with fresh gas, then reassemble. A kindly reminder, just beyond finger tight seals the tank.
I had filled the fuel rail with seafoam a few days ago, cycled power, and filled it again. I think this likely saved me from having to have the injectors 'cleaned' or outright trying to replace them. Not many options for those parts.
Reinstall the tank, and add a gallon of what passes for fresh petrol. Now the fun.
It took about 10 power cycles to get the rail primed, brute force, letting the bike do the work. First press of the starter, got a kind of British harrumph from it, a upper class snort. The second, a pop and fizz. The third, well there's magic in the third! A hearty vroom, and an immediate settle into fast idle. Wow !
Let it run while checking for leaks and anomalies, spiders bail ship, a weasel takes off, the ghost of Thatcher leaves. Getting good heat from the oil cooler, then the radiator, a nice cloudy aroma fills the garage as she slides into regular idle, the coolant gauge reads good. Idle for another ten minutes, shut down and off to grill steak.
MIL is still on, but I think it'll clear after a few more cycles. I am impressed with how well this has gone, there's still work to be done. Now that she's running investing in tires and other small work is definitely well in budget.
Short list is:
Tires
chain
flush&fill radiator
oil change and filter I had used synth oil I had 'laying' around, now to mobil1 15w-50
removing the slider hardware from the front (maybe)
a full cleaning and wax
Get it registered.
A quick video
DaveM, freck, rnmdad and 2 others like this.
post #16 of 33 (permalink) Old 05-10-2019, 04:45 AM
Supernova
Main Motorcycle: 2011 Sprint GT 1050
DaveM's Avatar
Other Motorcycle: 2004 Daytona 955i
Extra Motorcycle: Previously - Many
Thumbs up Nice one Andrew
Nice mate, good for you
that had to be extremely rewarding, well done buddy it sounds nice.
cheers
DaveM
DaveM is offline
post #17 of 33 (permalink) Old 05-10-2019, 11:29 AM Thread Starter
andrewb's Avatar
Originally Posted by DaveM View Post
I am, and was rather surprised at the bikes willingness to fire up after its slumber. Oy, and the sound of a trippple I'd forgot the intoxication of the FI motors. Well not really, as last year a mate and I traded off for a blast; he on my sporty and me on his 1050 Tiger.
The 'modern' 1050 is nice, a bit more refined. He and I will get together later this year and perhaps trade off again. I owe him some work so I know I'll be seeing him sooner.
Originally Posted by freck View Post
I can't stress strongly enough, that the fuel must have Stabil in it for storage past a few months, and either topped off or drained dry if she's put away longer than that.
post #18 of 33 (permalink) Old 05-10-2019, 07:04 PM Thread Starter
andrewb's Avatar
Master link staked, chain adjusted....
Another full heat cycle, bike fired right up and settled in....
Adjusted handlebars and controls...
Took it up and down my street, uncovered two important points: Hard to shift in work boots, not enough flexibility. More importantly, no rear brake. The shaft barely moves in the master cylinder, off to ebay to research replacements.
Happy to say my old carcass found the position comfortable.
Any suggestions for 10,000 mile tires? Was looking at Pirelli Angels, had them on my Trophy and liked them enough.
post #19 of 33 (permalink) Old 05-10-2019, 08:05 PM
Main Motorcycle: 1996 Daytona 900
I swear by pilots. Canít speak for durability over time though. Always heard good things about the pirelli stuff.
Sent from my iPhone using Tapatalk
Nitrous on a bike is like a hot chick with STDs, you want to hit it, but you're just not sure of the consequences...
Ex 1998 955i, MIG high mount, best bike ever built
Current 1996 900 speedtona project to be reverted back to Daytona.
rnmdad is offline
post #20 of 33 (permalink) Old 05-11-2019, 03:15 AM
Supernova
DaveM's Avatar
I'm a big fan of the Michelin PR 4 or 5's, they steer quickly due to shape, first class wet and dry grip, pretty durable for road riding in all weathers.
Don't have any nasty habits and don't give scary surprises.
andrewb likes this.
DaveM is offline
Daytona in an RS... kredge Sprint Forum 26 02-21-2010 10:46 AM
2010 Triumph Daytona 675 a1fa- Daytona675 Forum 1 10-05-2009 03:41 AM
New 675 Race Team Forming for Daytona 200 Ryan7771 Daytona675 Forum 7 03-13-2009 09:09 AM
Differences across 955/1050 models kludge Sprint Forum 13 07-09-2008 11:02 PM
