Thread size for 2002 955i fuel connector - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 6 (permalink) Old 09-22-2016, 02:03 PM Thread Starter
RME
Main Motorcycle: Daytona 955i 2002 CE
RME's Avatar
On the off chance someone knows the answer to this question.
Some previous mechanic stripped the threads on a plastic fuel connector and the metal where that connector screws into the fuel plate assembly, then tried to fix the mistake with epoxy, eventually causing fuel to drip onto the exhaust line. Which is not desirable. And apparently the plastic connectors have been replaced with metal connectors.
If the mechanic can figure out thread size of fuel plate assembly hole then he can tap it, and all I need will be a new connector.
If he cant, I will need a new fuel plate (a lot more expensive and probably hard to find.)
So if anyone knows what size and type of thread / tap is needed it would be helpful. A good and fast source for the parts would also be helpful (I am in Saratoga Springs NY and not close to any Triumph dealer.)
I am not certain why he cant try random metric bolts to determine thread size. But then again I am not a mechanic.
RME is offline
post #2 of 6 (permalink) Old 09-22-2016, 02:26 PM
Supernova
DEcosse's Avatar
This thread is in the stickies under "mods, upgrades & fixes" and contains all the info you need
https://www.triumphrat.net/daytona-de...placement.html
The short answer is - it's 1/4" BSPT
DEcosse is online now
post #3 of 6 (permalink) Old 09-22-2016, 02:32 PM Thread Starter
RME
RME's Avatar
Thanks and will look there with other questions before posting.
Sent from my LG-H830 using Tapatalk
RME is offline
post #4 of 6 (permalink) Old 09-22-2016, 03:16 PM
Supernova
DEcosse's Avatar
Note that 1/4" BSPT tap is not easy to come across in the US - I do see one listed in EBay (US listing), you will likely have to purchase for your mechanic.
Don't have him to be tempted to use an NPT tap which is 'close' but NOT correct - however sounds like he was smart enough to NOT "try random threads" so will likely wait for the correct tool.
post #5 of 6 (permalink) Old 09-22-2016, 03:48 PM Thread Starter
RME
RME's Avatar
Thanks again. Again, am not a mechanic. But would this work from Amazon https://www.amazon.com/Dormer-High-S...PP%7CBSPT&th=1 ?
I need to verify labor for tapping and replacing versus replacing assembly plate. The plate seems to be about 250 (again, assuming I can get one), so if its an hour or two of extra shop time salvaging current plate then I am not saving much.
RME is offline
post #6 of 6 (permalink) Old 09-22-2016, 03:52 PM
Supernova
DEcosse's Avatar
FuelBot - Fuel Level & MPG Gauge DEcosse Speed Triple Forum 53 02-10-2018 02:11 PM
The Most Accurate Fuel Gauge you will ever find - Fuelbot2.0 DEcosse Speed Triple Forum 55 02-15-2017 03:08 PM
thread size question steelwheels Air Cooled Twins Technical Talk 5 09-15-2015 11:05 PM
lucas chrome indicators thread size wol Classic, Vintage & Veteran 4 08-14-2015 05:27 PM
E9501 Filter Cap (plug) oil sump thread size Madfred Classic, Vintage & Veteran 3 04-04-2015 07:14 AM
